BETA 2-Stroke Thread. 250RR, 300RR, X-Trainer
Discussion in 'Thumpers' started by ToriMish, Feb 4, 2017.
  1. ChasM
    ChasM Been here awhile
    Nov 27, 2007
    863
    Loomis, CA (Sacramento area)
  2. NorskieRider
    NorskieRider Ultracrepidarian
    Mar 19, 2011
    1,916
    Minnesota
    If you do get the Fisch, you'll want the smaller one. I got the "Kit 25 (25.5mm-29.4mm)" ... IIRC I measured the stock outlet at about 29mm but I suspect it's not perfectly round and had to use a hammer to get it about halfway in and needed to be pried out with a screwdriver. I expect the next smaller size "Kit 20 (20.0mm-25.4mm)" would be much easier to remove and insert but will also restrict the exhaust even more.
    I didn't use it long enough for it to clog, and as I usually don't have any splooge I'm not sure there would be much in there to clog it. Either way, if it's easy to remove it's easy to put a torch to it and burn off the oil once in a while.
    Rob578 and CDN Rick like this.
  3. Bitingdog
    Bitingdog That's not my dog
    Apr 2, 2015
    19,526
    The bad side of the PNW
    You have a Keihin PWK carburetor. There's nothing easier to tune, and the 300 isn't really finicky anyhow. The book gets you pretty darned close. But as someone else suggested, set your float properly, 98% chance it's too high. Better to go 1-2 mm lower than specced for a woods bike, otherwise you'll be too blubbery off idle, stall when pointing steep downhill, and likely spilling more fuel than you burn
  4. Rob578
    Rob578 Long timer Supporter
    Dec 29, 2011
    1,780
    Atlanta
    I second the PWK, might want to try a NECJ or NECK needle. Some folks swear by the JD needles but I've never had any luck with them.
  5. Bitingdog
    Apr 2, 2015
    19,526
    Love the linear throttle response of the NECJ Suzuki needle
  6. justBert
    justBert Been here awhile Supporter
    Nov 28, 2013
    522
    Robbinsville, NC
    It's beginning to look like this 2 stroke business is a lot more complicated than I knew.....lots to learn so keep it coming.
  7. Rob578
    Dec 29, 2011
    1,780
    Atlanta
    Are you in the 2T business now?
  8. justBert
    Nov 28, 2013
    522
    Robbinsville, NC
    I picked up a 2019 X-Trainer a couple of weeks ago and I am trying to get sorted out by Perry Mountain. I may do some riding at Brown Mountain this weekend since I'll be in the neighborhood. I'm thinking I need to put you and @shortman on my speed dial.
  9. shortman
    shortman Beta 500 RS, X-Trainer 250 Supporter
    Jun 14, 2013
    1,781
    Cumming Georgia
    I'm around Bert so gimme a holler.... I'll gladly help anyway I can....
    justBert likes this.
  10. Rob578
    Dec 29, 2011
    1,780
    Atlanta
    No problem!
  11. CDN Rick
    CDN Rick Canoodia Eh?
    Jan 8, 2015
    30,595
    Niagara, Canada
    I know you know this BD, but just a note since some here aren’t as familiar with smokers. That needle **may** work fine in many 300’s. Please do NOT suggest it for 250cc Beta bikes. It’s way too lean for them. I personally do not find it works well in my terrain or riding.
    Either way it is NOT a “one size fits all solution”
    Optimal carburetor settings vary based on altitude, temperature, and humidity, as well as rider style and preference. There is no right size fits all, unless the other rider is riding the same terrain as you on the same day, right beside you, on the identical bike.
    Bitingdog likes this.
  12. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    5,507
    Upper Michigan
    Not really, don't fix what is not broken.Many of us on these forums are gear heads and like fine tuning our bikes.Only thing I have done to mine so far is put proper suspension springs on, sticky tires for my riding conditions and protection pieces because when I crash I do it right.Its riding season and bike works decent out of the box so I'm burning gas and hauling ass till snow fly,s.Ride it as much as possible before you go changing stuff so you can zero in on things you want better for the condition,s you ride.The X is a awesome bike out of the box if your riding knarly stuff.
  13. Rob578
    Dec 29, 2011
    1,780
    Atlanta
    I thought it went without saying that you need to match the main and pilot to the needle you're using especially if you switch to a completely different series. The PWK's aren't nearly as finicky as the Mikunis, there's no need to rejet just because the wind changes direction.
    Bitingdog, Junglejeff1 and CDN Rick like this.
  14. mtbdemon
    mtbdemon Long timer
    Nov 16, 2007
    1,501
    Sweet Home, Oregon I need a home
    I rode my first Beta's over the weekend 200, 250, 300 Race and Xtrainer. I thought I would like the 200 more, but I have to admit that both 300's I really liked. Now I want one, but which one? I'm leaning for the Xtrainer as I am old and slow, but dong that 300 race was so nice!!!
    GlennR, justBert and Junglejeff1 like this.
  15. Bitingdog
    Apr 2, 2015
    19,526
    Too right. Definitely not good on a 250 unless it's in the Colorado Rockies
    CDN Rick and BobcatSig like this.
  16. Marley'sDad
    Marley'sDad Adventurer
    Apr 12, 2013
    77
    Beulah, Colorado's sweetspot
    I bought the 2021 300 RR and I can say without reservation that it is the perfect bike. I am in Colorado, and I ride single track, rocky high mountain passes, and easier stuff like dirt mesas around Pueblo. That bike does it all soooo well. I love it! You can't go wrong with the 300RR.
  17. Bitingdog
    Apr 2, 2015
    19,526
    Trying to replace the starter on my friend's X-Trainer 300. Trying to do it without dropping the engine 20210912_215951.jpg
  18. St.AndrewsRider
    St.AndrewsRider Adventurer
    Jan 2, 2013
    59
    Columbia Basin
    Rehashing this thought after a few days and noting some of the other carburetor replies since then. So what are a few main jet sizes and needles to have on hand for the PWK carb JIC? Typically gonna be riding 2500-4500' elevation milder cooler temps going into fall. Been out of the loop for a while my current bike is EFI and my last carb bike was mikuni vm.
    BTW, got the call last week! My x-trainer is in! Gonna pick it up in a couple days when my sparky arrives and some other goodies.
    Junglejeff1 likes this.
  19. Bitingdog
    Apr 2, 2015
    19,526
    I'd ballpark it at 38 pilot, NECJ needle 3rd clip, 155 main jet. 1.5-2.0 turns out on the air screw, with float height verified
  20. St.AndrewsRider
    Jan 2, 2013
    59
    Columbia Basin
    Very good! I'll give that a shot. Gonna check the float when I get it home. Thanks
