BETA 2-Stroke Thread. 250RR, 300RR, X-Trainer
Discussion in 'Thumpers' started by ToriMish, Feb 4, 2017.
  1. Traveller128
    Traveller128 Long timer
    Feb 11, 2015
    2,649
    SW Idaho
    Some of the other levers available from Beta are longer, both Hammerhead and their "HD" shifter. I wear size 12 boots, and went with the Hammerhead (they have them on the Beta website). I had the "HD" on my last 300RR and it was okay, but like the Hammerhead better. They're listed as "0", "10", and "20". The 10 lever is 5mm longer than stock, the 20 is 15mm longer (arm length). Both have longer tips than stock, and sit about 15-20mm further out from the side cover. I used the "20" lever. Plenty of space, but have to be careful where you index it or you'll touch the chain on the upshift with a 15 tooth countershaft (stock on the 200RR). I indexed mine one tooth too high and moved it down one tooth initially. Works fine, and it was great when I raced it. It holds up to drops very well. So far, no complaints with large boots.
    Mow-ree likes this.
  2. wwguy
    wwguy Been here awhile
    Apr 29, 2015
    620
    Boise, ID
    I've got 250 hours or so riding my 2016 Xtrainer with size 12 Gaerne boots. I run Fastway footpegs mounted in the "lowboy" position, which puts them a bit lower and rearward compared to stock. I don't have any issues shifting with this setup, but then again I don't remember any shifting problems with the stock setup either. My primary reason for going to the Fastway pegs was to drop them a bit to accommodate my long legs. But I probably do hit a few more rocks with the lower pegs.
    Bitingdog and Traveller128 like this.
  3. aleksbaron
    aleksbaron Blessed with Purpose Supporter
    Jan 31, 2015
    210
    Sierra Vista, AZ
    Can you share the fitment and pegs part numbers? I am 6'1 and have the long leg issue too, so I could definitely use a drop, any bits helps.]
  4. aleksbaron
    Jan 31, 2015
    210
    Sierra Vista, AZ
    I was thinking I would go with the hammerhead as well, with the pegs lowered and this it should help. Feet are huge with the boots on, I have to use the edge up of the boot to shift.
  5. Traveller128
    Feb 11, 2015
    2,649
    SW Idaho
    Don't like using the edge of my boot, did that with the stock shifter.
    I have the same set WWguy has on my 450 and really like them, along with a slightly longer shifter which works very well. I'm still debating lowering the pegs on the 200, and if I do I'll be using the same ones. I like the Fastway pegs.
    Bitingdog and Mow-ree like this.
  6. wwguy
    Apr 29, 2015
    620
    Boise, ID
    Here's the link for the pegs that fit my bike. I'm pretty sure that all Beta pegs are the same, but if unsure you can choose your specific model year from the dropdown menu.
    I prefer the Evolution 4 pegs for style and durability, but all feature the adjustable feature I mentioned.
  7. aleksbaron
    Jan 31, 2015
    210
    Sierra Vista, AZ
    THANK YOU!
    wwguy likes this.
  8. shrubitup
    shrubitup Uncouth Sloth
    Mar 20, 2009
    1,305
    Kitsapolis WA
    Size 13 boot here, 300RR, get the Trojan magnum (hammerhead +20).
    aleksbaron likes this.
  9. N8
    N8 I prefer my pumpkin with a blue & white mask. Supporter
    Dec 27, 2012
    5,636
    Lancaster, PA
    If you're wearing SG-10's, the toe box is significantly larger than SG-12's. Don't tell @Navin but I used to get many more miss-shifts with the SG-10's. Disclaimer, I ride a Husky, but the SG-12's & SG-10's are quite a bit different in the toes.
    Navin likes this.
  10. shortman
    shortman Beta 390rr, XT300 Supporter
    Jun 14, 2013
    1,398
    Cumming Georgia
    A/C
  11. aleksbaron
    Jan 31, 2015
    210
    Sierra Vista, AZ
    I have SG12s but if the 10s have a bigger toe box, but holy crap I thought the SG12s were huge.
  12. B00ST00
    B00ST00 Been here awhile
    Jul 28, 2013
    192
    Maryland
    Who is the go to for beta suspensions? Looking to respring/ revalve my 17’ 300rr. I’m in MD but shipping isn’t an issue.
  13. shrubitup
    Mar 20, 2009
    1,305
    Kitsapolis WA
    after hours cycle
  14. Bucho
    Bucho DAMNrider
    Dec 10, 2006
    4,063
    Maryland
    There is a place near Westminster MD. Some of the DAMN guys that race use them. I can't remember the name of the place. Ask over on the DAMNsite and they will tell you.
    B00ST00 likes this.
  15. aleksbaron
    Jan 31, 2015
    210
    Sierra Vista, AZ
    Preface:
    I am attempting these pop wheelies on my xtrainer and am having great difficulty. Other than practice is there something I can do mechanically that would help ie throttle cable, clutch adjustment. I feel like from compressing the fork I can't get the throttle up fast enough or the clutch to grab snappier to pop the front wheel.
  16. Bucho
    Bucho DAMNrider
    Dec 10, 2006
    4,063
    Maryland
    Im very familiar w/ that video, I found it very helpful.
    I also have an Xtrainer. I can bring the front wheel up fairly well just like the video instructs. I dont use any clutch at all.
    It might be helpful to have someone video you practicing. Sometimes when learning something new you THINK you are following the steps/doing it right. But the video may show something very diffrrent.
    Goodluck, keep it up. It might just be the timing. When you get it right, its great!
    Bitingdog and NJ-Bill like this.
  17. rickypanecatyl
    rickypanecatyl SE Asia adventure tours
    Jan 21, 2008
    1,872
    Kuala Lumpur, Malaysia
    Opinions on using the X-Trainer for transportation connecting 2 difficult points
    Quick scenario: There's a camp in the jungle and it's about 50 miles/80KM to "civilization" and we often need to go back and forth. The journey is mostly single track, twice we cross deep rivers using bamboo rafts, often we have to drag a bike on it's side when the "road" is blocked by massive clumps of bamboo falling down making a canopy about 4' high covering the trail.
    My question/goal isn't so much about having fun, (though I do! :lol3) but what's the fastest/most practical way to connect the 2 points?
    Currently the locals often walk - 2-3 long days, take mules (seriously) - 2 days. The fastest common way for the locals to do the route is using their 100kg, 100-125cc local scooters with knobby tires on them. Typically 6 guys will ride 3 bikes - 2 per bike. When it gets a bit rough, the passenger gets off and walks or pushes. When it gets really rough, there are 6 guys to get each bike over, thru or around the obstacle. They usually get it done in 6 hours or so. (I've never seen locals do it on mountain bikes but imagine it wouldn't be much slower.)
    When I do it I'm on my +/- 320 lb, KLX250. (With 351cc bb/KX250 suspension, 4 gallon tank and beefy subframe/pannier racks). Alone it usually takes me about 3 hours if I'm pushing it, but compared to the locals I'm tall, strong and a good rider. My bike is too tall (custom KX suspension makes it about 2 1/2" taller than stock) and heavy for the majority of them - men probably average 5'5".
    Anyways - sorry for the long question! A good deal came up on a thrashed 2016 in Thailand and I was contemplating getting it and leaving it with them as an emergency vehicle for getting in and out fast. Looking at the numbers it seems like an ideal bike for tough routes like that. But issues I wonder about are reliability - they're not known for taking good care of stuff and fuel is low quality, range? Options to increase range? Also I know they'd want to pack it down with lots of stuff :lol3
    Any thoughts?
  18. NJ-Bill
    NJ-Bill Life is good Supporter
    Jun 11, 2005
    1,853
    08003
    Here is what concerns me. - But issues I wonder about are reliability - they're not known for taking good care of stuff and fuel is low quality, range? Options to increase range? Also I know they'd want to pack it down with lots of stuff :lol3
    I own a XT and never put low quality fuel in it. I don't think it is designed for that. If they don't stay on top of adding oil to the tank, you know what happens. Given these conditions, I think a CRF230 or KLX140 would be safer options.
    Bucho, rickypanecatyl and mode12 like this.
  19. Rob578
    Rob578 Long timer Supporter
    Dec 29, 2011
    1,362
    Atlanta
    Practice on soft ground.............
    mode12 and aleksbaron like this.
  20. aleksbaron
    Jan 31, 2015
    210
    Sierra Vista, AZ
    I'm confused, is it not a quick blip of throttle so clutch control is critical here? I assume a quick release of the clutch and then pull in after I have the wheel up to prevent a full backward tipover.
