Beta EVO Thread
Discussion in 'Trials' started by garrett, Sep 6, 2014.
  1. LemmeTry
    LemmeTry Over-thinker...
    Jan 27, 2016
    305
    Bozeman, MT
    LOL I figured. :D What I'm not familiar with is what elevations to run the regular vs the high altitude carb springs; gotta know what point in the trail I need to stop and whip out the other spring. haha
  2. jaylude
    jaylude Been here awhile
    Jul 27, 2010
    322
    Central CT
    Quick question - noticed the front sprocket on my Beta "wobbles" a bit more than I'd expect. I'm mainly experienced with wrenching on dirt bikes, but on them, there's no where near this amount typically. I popped the sprocket off and looked at the countershaft itself, and don't see any suspect wear. Sprocket teeth look decent too. I see that the Beta uses a setup with opposing c-clips to locate the sprocket. I'm wondering if this accounts for the wobble? Do the c-clips themselves wear over time? Or does that system with "non-rigid" c-clips just inherently wobble a bit? Perhaps it just needs a new sprocket and c-clips?
    I uploaded a clip to better show what I'm seeing here:
  3. slicktop
    slicktop Been here awhile
    Oct 20, 2013
    992
    Slicktop Mtn. Ar.
    Buy a aftermarket sprocket.
  4. lineaway
    lineaway Long timer
    Oct 1, 2011
    10,541
    nm
    slicktop likes this.
  5. slicktop
    Oct 20, 2013
    992
    Slicktop Mtn. Ar.
    That's right. And if rear sprocket is side loaded it won't transfer to motor.
  6. jaylude
    Jul 27, 2010
    322
    Central CT
    Thanks for the input. I definitely understand that the sprocket will essentially straighten out once it's loaded by the chain, and only transfer the chain forces to the usual intended contact points between the sprocket and countershaft spline. My brain just tells me that extra slop in the play has a potential to wear the countershaft faster due to rubbing during any axial movement or rotation of the gear, which is why I made the post. I also checked my GasGas 280 Pro and there's only the usual very slight wobble, as with most offroad dirtbikes.
    So are you guys seeing the same wobble on your Beta sprockets as well?
  7. steadfast
    steadfast Been here awhile
    Jan 16, 2017
    105
    What’s everyone’s preferred mix ratio? I just picked up a 2016 evo 250 factory and I believe it was being run at 80:1.
  8. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    14,651
    Dubuque, Iowa
    yes
    wheelieman14, slicktop and Nobade like this.
  9. alpineboard
    alpineboard Been here awhile
    Mar 2, 2016
    679
    New Hampshire
    This has approx. 100 hours of slow ride on it. If found, have one with 200 hours, and looks the same. I looked at it with a magnifier and could not see any wear on the internal tines. I also questioned this movement when getting a beta. Ride it, you will be fine. 0818190855-00.jpg
    jaylude likes this.
  10. jaylude
    Jul 27, 2010
    322
    Central CT
    Thanks for the input. I think it appears to be a function of the double C-clip they use on the countershaft. I might just get new C-Clips next time I place an order and see if it reduces the wobbling any.
  11. rokhopr
    rokhopr 2015 Beta 250 Factory, 2019 TRRS 250
    May 28, 2007
    139
    Owasso, OK
    I gotta say running the JJJ, 52 and 120 worked great for my 2015 Beta 250 2T at 6,600 (Turkey Rock, CO), 8,200-9,200 (Sipapu, NM) and 9,200-11,200 (Ute Cup).
    Nobade and wheelieman14 like this.
  12. lineaway
    lineaway Long timer
    Oct 1, 2011
    10,541
    nm
    2020 models are out.
  13. Gordy
    Gordy SUPPORTER
    Dec 30, 2001
    31,817
    NM
    :snore
    Sting32 likes this.
  14. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    14,651
    Dubuque, Iowa
    Looks like Beta and Honda have the same market philosophy. BNG...
  15. slicktop
    Oct 20, 2013
    992
    Slicktop Mtn. Ar.
    If Honda made a 2t.
  16. alpineboard
    Mar 2, 2016
    679
    New Hampshire
    I broke my 2015 Beta Evo Factory handlebar clamp, it broke at the pin junction (see pic) , I have been searching plenty, am contacting V-Mar, thinking they have a solution of the Non Pin type. The raised ridge on top triple may or may not make a difference, raised ridge flat is 0.625" wide.
    Has any one dealt with this fix, and made it stronger than the pin type? Bike has under 50 hours. 64418628_2526606504037367_4801294612499005440_o.jpg 0920191115-00.jpg Thanks.
  17. Razor85
    Razor85 Adventurer
    Mar 16, 2011
    50
    Why does the kickstarter never line up with the indentation on expansion chamber? Always wanted to know.
  18. rokhopr
    May 28, 2007
    139
    Owasso, OK
    Curious how that happened? I've got 600 hours on 2015 EVO Factory and no issues like that to date.
  19. alpineboard
    Mar 2, 2016
    679
    New Hampshire
    I have been riding some 2 to 3 foot rocks that have a pretty sharp incline, holding pressure and coming down gently, doing this over and over, like 40 times in an evening ride. Over the past 2 weeks every night.
    One small clue was a slightly not tight left hand bottom mount screw, so if the left side mount has a bit of float, the right side which is the pivot point will break....? I could not feel any loose bar/movement, before it broke. I think I will try to replace mount /clamp with a split kind with 2 screws.
    rokhopr likes this.
  20. heffergm
    heffergm Been here awhile
    May 23, 2019
    430
    USA
    The pins are rusty. Rusty metal expands.
