Beta fork seals
Discussion in 'Trials' started by gottadog, Apr 7, 2020.
  1. gottadog
    gottadog Adventurer
    Jul 31, 2011
    23
    I bought an 18 Evo Factory 300 last year. It needs fork seals bad. In the past I've found info on what skf seals I could use from say an older Honda street bike. Is this something anyone still does? I can't believe how expensive the parts are. I was priced $138 for the seals and bushings. Not including dust seals.
    I've had a hard time finding info on the seals. Trials sites suggest two different seals for these bikes and I'm not sure which one. Would like to narrow it down and hopefully source my own parts. Beta aftermarket hasn't been easy to figure out.
    Appreciate your help.
    alpineboard likes this.
  2. Huzband
    Huzband Team Dirt
    Oct 4, 2006
    10,382
    Cowford, Fl.
  3. neilking
    neilking Been here awhile
    Mar 1, 2008
    507
    Austin, TX
    Get the green seals/dust cover from beta. $70 for a full set. You shouldn't need bushings,so that's a waste of money.
    lineaway likes this.
  4. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
    First off, is both sides leaking? And the green ones are the way to go. The 18's are a different fork and they only list quantity, so make sure you drain it good. Both of the 18s I have done had a scratched fork tube.
    alpineboard and Huzband like this.
  5. Junglejeff1
    Junglejeff1 Long timer
    Oct 20, 2016
    4,626
    Upper Michigan
    I sourced seals for my old Paoli forks from race tech.If you go to there parts you most likly will find seals at least.They also have many, many bushings to cross reference.I replace many bearings,seals,Fork parts with better parts than stock at cheaper prices.Stock tech fork bushing and seals are just stupid priced and I see racetech has might have them at a fraction of the cost.
    gottadog likes this.
  6. motobene
    motobene Motoing for 49 years Supporter
    Mar 9, 2013
    7,055
    Wichita Mountains SW Oklahoma
    Measure your seals. Outside diameter X inside diameter X height. Seals usually measure close to millimeter nominals though the B dimensions are going to be a little oversize for a press fit into bores. A dimension is the fork stanchion rod and will be right on a millimeter nominal. The C dimension is sometimes on the half mm or off nominal.
    This might help you get closer in selecting a seal:
    riabma77 and Yinzer Moto like this.
  7. gottadog
    gottadog Adventurer
    Jul 31, 2011
    23
    Guys thanks for the reply's. Good info, but I'm not feeling enough accuracy measuring used seals.
    If its one thing I dislike about Beta its their control on parts. I'm used to the availability of OEM and aftermarket parts for my big bike.
  8. volrider
    volrider Been here awhile
    Aug 4, 2008
    284
    East TN
    I’d contact Ray Peters. I’m sure he’d be willing and able to get you fixed up.
    #8
  9. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
    #9
  10. gottadog
    gottadog Adventurer
    Jul 31, 2011
    23
    Bike: Beta Rev/Evo 01-17
    Maybe it'll take me 10 seconds. I've been told the 18' Factory is different.
    #10
  11. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
    Quick check would be diameter. As long as its 38 your good.
    #11
  12. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
    Same as it's ever been. Just checked Beta parts.
    #12
  13. motobene
    Mar 9, 2013
    7,055
    #13
  14. gottadog
    gottadog Adventurer
    Jul 31, 2011
    23
    Thank you guys. Trials info is definitely more challenging than the big bikes.
    #14
  15. motobene
    Mar 9, 2013
    7,055
    It is. That's why it's only for the few who are willing to take an ass kicking to get to the benefits. Trials is no easy sell, but it is worth it.
    #15
    Cascao, NZRalphy, jonnyc21 and 2 others like this.
  16. gottadog
    gottadog Adventurer
    Jul 31, 2011
    23
    Me again. Where do you guys find Beta fork capacities? I'm not familiar with these forks. Is the oil by volume or level? I went on Beta USA. The service manual is motor only and the owners manual link doesn't work. 404 error.
    Thanks for the help. I definitely want to do my own fishing so if you guys have links or any info that would help with future searches I'd appreciate it all.
    #16
  17. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
  18. gottadog
    gottadog Adventurer
    Jul 31, 2011
    23
    I believe I've translated the correct info. 297 g oil.
    While screwing around translating I saw a forum and the guy suggested ATF instead of fork oil. What are you running in your forks?
    #18
  19. lineaway
    lineaway Long timer
    Oct 1, 2011
    11,322
    nm
    Maximal 5wt.
    #19
  20. Cascao
    Cascao Been here awhile
    Apr 4, 2018
    189
    Brazil
    ATF (around 7W) is used on small motorcycles and should be ok.
    Life is expected to be shorter than syntetic ones.
    #20
