Betor Fork Damper Rod sealing ring needed = 1983 SWM 240
Discussion in 'Trials' started by deBard, Oct 9, 2018.
  1. deBard
    deBard n00b
    Aug 25, 2015
    7
    Millerstown, PA
    Rebuilt the 35 mm Better forks on my SWM and had to drive the damper rod out it was that tight. Both legs.....
    Seems like the fiber ring on the damper rod has swollen over the years. Does anyone have a lead on where to order just this part? Or any suggestions for replacement --
    I did try filing down the ends to increase end gap and reassembled, but they make a lot of noise moving up and down...
  2. lamotovita
    lamotovita DAMN SNOWBIRD!
    Oct 5, 2007
    2,628
    WA/AZ, USA
    Try the Bultaco parts suppliers. You could also turn down the groove that the ring fits into.
  3. PSchrauber
    PSchrauber Long timer
    Jan 3, 2011
    1,256
    Summer: Kemiƶ, Finland; Winter: North Germany
    PTFE rod, that can be milled to the size bushing you need, a bit delicate to handle.
  4. Norman Foley
    Norman Foley Devotee of the Husqvarna Supporter
    Mar 20, 2004
    2,551
    New York... The Finger Lakes
    Brewtus likes this.
