1. eNewsletter Sign Up
Bicycles mounted on motorcycle picture thread
Discussion in 'Photos' started by Cavernous, Nov 17, 2011.
  1. TheVermonter
    TheVermonter if it's not dirty ...are you really having fun?
    Aug 13, 2015
    25
    Vermont
    homemade from all the insperation above, thanks
    kiwial and kenstone like this.
  2. FL_biker
    FL_biker 2016 BMW R1200GS Adv
    Oct 12, 2008
    668
    Tampa Bay area
    I'm lazy and just bought the 2x2cycles rack, BUT I used a Jesse QRDP (Quick Release Dual Plate) so that I can swap from Jesse Top box to Bicycle Rack in about a minute
    QRDP below
    lets me go from this
    to this in a minute
    kiwial likes this.
  3. _mtg_
    _mtg_ Been here awhile
    Apr 2, 2016
    351
    Colorado
    Any new ideas? I'm planning on making a mount for my new-to-me R1200RT, looking to do a side mount similar to the fork mount/passenger peg location posted a couple pages ago, but make it mount to the BMW hard case mounts.
  4. mrhunt
    mrhunt Adventurer
    Aug 9, 2008
    25
    Sub-Arctic New York
    A buddy and I fabricated a mount. 3 bolts to the tail rack, goes on in about 2 minutes (including pulling tools from under the seat). Other than a little light in the front when you get after it, can't even tell it's back there. [​IMG]
    kiwial likes this.
  5. fhfr436
    fhfr436 Thirsting for ADV
    May 27, 2009
    164
    Suburb of Motown, Michigan
    Nice. Are the crossbars round so that you can just use standard Yakima hardware?
    Please post some close-ups.
  6. mrhunt
    mrhunt Adventurer
    Aug 9, 2008
    25
    Sub-Arctic New York
    Actually, they're just cut down Yakima bars with the plastic coating cut off (so we could weld) covered back with black tape. The rest is some 1" tubular steel from lowes and some old 1/8" plates. Photos to follow.
  7. mrhunt
    mrhunt Adventurer
    Aug 9, 2008
    25
    Sub-Arctic New York
    To attach: I replaced the two bolts holding the tail rack in place w/ two M8x1.25 65mm bolts going UP through from the storage area - one set of nuts holding the tail rack in place, a second set that hold the bike rack in place. A third bolt is from the back hole in the tail rack. Original plan was to just swap the existing bolts out and put new ones in down through, but after a gravel road get-off, the caribou rack is just tweaked enough that swapping them out often would be a PITA. 70mm bolts up through would be better - the 65mm ones are just a touch short, and with washers the bolts do not extend through the nuts, but that was the only thing I could find a Home Despised at the time.
  8. kenstone
    kenstone worn out
    Mar 3, 2013
    1,879
    Boysee
    Very similar to my design, with a bicycle only weighing 25-30# max, most all of the DIY racks posted here are copies of commercial racks made for cars where weight is not an important consideration.
    Some even use components from commercial auto racks that are way (weigh) over engineered, and ad even more heavy material to the design.
    I used 2x4 scraps as the main components/frame of my rack( no welding), bolted together in a "T" shape, along with a commercial fork clamp, and it has worked for many years and adapted to many different MCs.
    :lol3
    kiwial likes this.
  9. jetdoc2
    jetdoc2 Adventurer
    Aug 3, 2013
    46
    IMG_2056.jpg not "on" the bike....but close
  10. fhfr436
    May 27, 2009
    164
    I wouldn't think that setup won't have a long life. The aluminum wheel tray just isn't strong enough to handle the load on the cantilever and will buckle. I've seen photos of the aftermath, posted here I believe, but couldn't find them today.
    That previous poster retrofitted it with some kind of steel strongback below the tray to provide the necessary flexural strength.
    A simple improvement would be to use a strap from the rear wheel (axle or contact patch), up over the handlebars and down to the rack near the front fork tips. The tension of the strap would provide relief to the downward force on the wheel tray.
    [​IMG][/QUOTE]
  11. Dirt Bag
    Dirt Bag Jesus Hates A Pussy Supporter
    Nov 2, 2016
    51
    Central Missouri
    I really like your setup- very neat fabrication. Not sure about the rigidity of the cantilevered tray, but easy enough to insert a steel strap in the groove under the tray. Since we are close I would buy it but I always ride bikes with my boys. Good job!
  12. rosskeeling
    rosskeeling Adventurer
    Oct 12, 2014
    13
    NC
    I went with the 2x2 Cycles set up as they are right down the road from me. Here is the set up on my F800GS (sold) and getting installed in the new ride, multistrada 1200.
    kiwial likes this.
  13. knobbytracks
    knobbytracks super n00b
    Aug 12, 2007
    78
    Gateway to the Ozarks via Sullivan Mo
    [/QUOTE]
    The 1.5" square stock running down the back side of the tray supports it about half way back and that keeps everything nice and stiff. Add to that the bike only weighs 22 lbs. I've had it downs some gravel roads and bounced it a few times well over my comfort level with no issues. It looks like a ominous mass but probably far lighter than some top cases minus the cantilever effect.
    fhfr436 likes this.
  14. knobbytracks
    Aug 12, 2007
    78
    You live in a great location for this type of 2x2 action.
    rosskeeling likes this.
  15. fhfr436
    May 27, 2009
    164
    Nice and simple - well done.
    Independently, I came up with a similar idea last year, but have yet to move ahead on it.
    My design inspiration was based on the Peg Packer system.
    If I can get it to work, my vision is to have the QR skewer rotated 90ยบ so that the handlebars are out, away from the driver's body. This would be especially important for MTB bars, being quite a bit wider.
    I like the design of the 2x2 system, but don't care for the super-high profile of them.
    I'm also kicking around the idea trying to replicate the 2x2, but as a side-mount like this, rather than a top mount.
    Also, I'd consider taking both wheels off to reduce the overall length.
  16. semper-guzzi
    semper-guzzi Been here awhile
    Oct 1, 2012
    199
    SoCal
    I want to mount my ebike onto the Roadster to ride to some further away singletrack. The issue is, my bike is a bit heavier with the electric motor and battery. About 60lbs or so. I think a side mount would be nice, but maybe I can put the battery and front tire on one side and the bike on the other to help level it out, or try and come up with something mounted on the back to keep it a little more balanced. I like seeing these pictures as they give me some ideas.
    Has anyone here towed their bicycle by having the front wheel lifted and rolling the back tire on the road? I worry about the bearings at fast road speeds tho....
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  17. fhfr436
    May 27, 2009
    164
    I had a friend do that exact thing with his BMW R??? when we were in college 25+ years ago. I don't recall him having any problems due to it, but like you, I'd be worried about the wheel bearings ... and the tires.
  18. Lordendo
    Lordendo Adventurer
    Apr 5, 2013
    55
  19. Canuck403
    Canuck403 Been here awhile
    Oct 6, 2016
    224
    Calgary
    That would be putting a lot of weight very far back. Two bikes plus the rack in that position would be asking for trouble.
    Oh, and I think my Kuat rack looks way better than the NSR!
  20. Jeff@TheQuadShop
    Jeff@TheQuadShop TAT survivor
    Nov 28, 2004
    7,556
    Crestwood, Kentucky
    I took a slightly different approach...
    kiwial and RAGBrian like this.
