Big Wheel Dual Range dune climbing desert bike
Discussion in 'Some Assembly Required' started by WILL_S, Feb 19, 2015.
  1. GR0NK
    GR0NK Got some screws loose!
    Sep 24, 2006
    10,109
    Stuck in 80s
    That's my reasoning with the BigFat. I just used whatever was available and it happened to 200cc. But I have three Honda ATC125M that I could have used instead. But those motors (ironically) are earmarked for a CT90 I'm bulding. (stalled, will return to it eventually)
    I was just checking out some Rokons the other day and came across this little gem. Seems there are plenty of these little horizontal motor swaps into Rokons. This one seems to run good.
    Sean :bmwrider
    #61
    smilin jack, ondrej91 and WILL_S like this.
  2. RedRaptor22
    RedRaptor22 Been here awhile
    Jan 24, 2012
    200
    Louisiana
    #62
    WILL_S likes this.
  3. Pezz_gs
    Pezz_gs Cant ride for crap
    Nov 13, 2004
    5,526
    Sydney Skunkworks
    So @WILL_S
    How about an update . . . . . :photog
    Im about to get busier on my Big Wheel bike :D
    #63
  4. WILL_S
    WILL_S OUTLAW POSTIE 001
    Feb 16, 2009
    3,599
    goodly satisfactory place, qld
    Um
    I brought another bike and aquire some more projects lol
    I reckon you are moving quicker
    #64
    GR0NK and Pezz_gs like this.
  5. WILL_S
    Feb 16, 2009
    3,599
    Righto in anticipation of this crusty swingarm turning up i pulled my finger out and painted the rims
    I am going to cheat for a bit and bolt it up to my going postie .So a offset sprocket of 35mm is required.Time to find a old mainshaft and a couple of stuffed sprockets and cobble up a outrigger.
    #65
    Te Hopo, DRool and DRjoe like this.
  6. WILL_S
    Feb 16, 2009
    3,599
    Well the swingarm turned up.
    Description before i seen it ,should clean up all right with a coat of paint. Hmmmm
    At least the bolt is ready to use .
    Will start the cleaning process and see if it's salvageable or just a donor for axle plates and setting up a jig.
    The plan is to add 50mm in length and some points for a jackshaft to be bolted up.
    #66
    smilin jack likes this.
  7. WILL_S
    Feb 16, 2009
    3,599
    Had success with vinegar and rust before.Nothing to lose soaking the swingarm.I give it a couple days and see whats left
    #67
    smilin jack and Te Hopo like this.
  8. griffo1962
    griffo1962 Long timer
    Oct 24, 2006
    1,927
    Boonah, Qld, Australia
    lol, a little surface rust......... fml, some people have no idea!
    #68
    WILL_S likes this.
  9. Pezz_gs
    Nov 13, 2004
    5,526
    Sydney Skunkworks
    Oh crap Will . . . . like you said it will give you the design and plates.
    I added 100mm and think that could work better than 50mm especially if you are looking to add a jackshaft down the track. Im running a 25x8x12
    I just ordered a headlight from him and it was a wee bit rusty too LOL
    It looked better on the phone than the PC :lol3
    #69
  10. WILL_S
    Feb 16, 2009
    3,599
    Yes i can see how 100mm would work.I will see where everything sits guard wise.Might roll the edge a bit to give me more room for tyre.
    How thin is the bush mounts on your swingarm Perry ?The one i got the bush sleeve is thicker than whats on the swingarm lol.Found new bushes cheap and it looks like a couple of alternator bearings could be used as to convert to bearings if needed.
    I now have 4 different swingarms to chop up :drif and a 4 month timetable to complete the thing :imaposer
    Probably should pull the dual range down will the swinger is soaking
    #70
  11. Pezz_gs
    Nov 13, 2004
    5,526
    Sydney Skunkworks
    Thought I woud post this here as others are following @WILL_S
    Looks to be around 2.5mm wall thickness
    #71
    smilin jack and WILL_S like this.
  12. WILL_S
    Feb 16, 2009
    3,599
    Couple days in vinegar and we have a hole.One of the shock mounts is stripped too.Looks like i can use the back half not to much metal fatigue there.
    Slowly slowly.
    #72
  13. Pezz_gs
    Nov 13, 2004
    5,526
    Sydney Skunkworks
    It did clean up ok. Impressive how the vinegar worked
    The RV125 swingarm is all light gage steel Will. The frame is too. So puting 30HP through mine should be fun :1drink
    There was a guy who put a TS400cc two stroke into an RV125 . . . . dont think the frame will last long on that :muutt
    #73
    WILL_S likes this.
  14. WILL_S
    Feb 16, 2009
    3,599
    Chopped the swinger
    Needs 75mm added
    Now to use new tube up front or cut out the crossbrace,rusted thru in a couple of spots,and use the front part of the rails.......
    #74
    smilin jack and Pezz_gs like this.
  15. WILL_S
    Feb 16, 2009
    3,599
    Half a swingarm....
    Turned a bit of tube to take some bushes and made the extension a press fit over the last bit of the rv swingarm
    Next is workout where the jackshaft will sit then go visit @DRjoe for some bits to make a bearing carrier .
    #75
  16. WILL_S
    Feb 16, 2009
    3,599
    #76
  17. WILL_S
    Feb 16, 2009
    3,599
    How good is to have a mate like @DRjoe .
    Few conversations today with some ideas about jackshaft and location.
    Pretty cool idea of running the jackshaft on the swingarm pivot bolt.
    Would work great and have no chain issues with tension and travel.Only problem is the dual range box doesn't allow enough room ...bummer.Talking offsets etc and then a bit later Joe sends some pics through of the jackshaft sprocket he knocked up out bits he had.Freakin Awesome mate thanks, i know your busy lad and probably should of been laying glass mucho appreciated.
    #77
    smilin jack, Pezz_gs and DRool like this.
  18. WILL_S
    Feb 16, 2009
    3,599
    20170123_172251.jpg 20170122_165101.jpg 20170122_164701.jpg More work done.Looks like mounting the jackshaft on the swingarm can stay.Clears a single range motor great ,chain tension is good and a nice clean system.Hits the dual range box but the solution to that is to make a set of engine mounts and push the motor forward to give sprocket clearance.
    #78
    smilin jack, GR0NK and Pezz_gs like this.
  19. WILL_S
    Feb 16, 2009
    3,599
    Some you might get a laugh out of this,brain fart moment.
    One of the shock studs was stripped.Turned up a new one and welded it in.Can you see whats wrong ? 20170122_154955.jpg
    #79
  20. griffo1962
    Oct 24, 2006
    1,927
    on the inside??
    #80
    DRjoe likes this.
