Big Wheel Dual Range dune climbing desert bike
Discussion in 'Some Assembly Required' started by WILL_S, Feb 19, 2015.
  1. WILL_S
    WILL_S OUTLAW POSTIE 001
    Feb 16, 2009
    3,655
    goodly satisfactory place, qld
    Yeah lol
    I was looking at it thinking why are there axle aligning marks on the inside.....
    #81
  2. WILL_S
    Feb 16, 2009
    3,655
    Back getting closer.
    Welded in crossbrace on swingarm and mounted a tyre.Time to work on repositioning the dual range motor.The gbox housing will hit the jackshaft.
    #82
    smilin jack, GR0NK and Pezz_gs like this.
  3. WILL_S
    Feb 16, 2009
    3,655
    Fun times getting the dual range to clear the jackshaft.
    It looks like by taking the bottom engine mount bolt out and tilting the motor up it will clear enough to run a 14 tooth outer sprocket.This leaves me with having to make engine mount adapter ,probably like the ones you use when fitting a china motor in a ct .
    #83
    smilin jack and Te Hopo like this.
  4. WILL_S
    Feb 16, 2009
    3,655
    Fat tyres require wide shock spacing . I suppose you could always just angle them in .In my dodgy mockup i used wheel nuts screwed onto the standard top mounts and ran a 12mm bolt in.
    Then i thought why not weld a 12mm bolt to the wheel nut and turn it down , use what i have laying round.
    Not quite finished but good enough for testing
    #84
  5. JimVonBaden
    Feb 11, 2005
    96,310
    Alexandria, VA
    I have those shocks. Make sure all of the parts are properly tightened, or they will come apart.
    #85
    WILL_S likes this.
  6. WILL_S
    Feb 16, 2009
    3,655
    I have had these shocks on another bike for awhile,luckily they haven't come apart.
    The only thing i found was they are a bit stiff so i let a bit of gas out.
    #86
  7. JimVonBaden
    Feb 11, 2005
    96,310
    Alexandria, VA
    I lost the lower retaining plate on mine. You are right, pretty stiff, even for my fat ass.
    #87
  8. WILL_S
    Feb 16, 2009
    3,655
    Shock mounts mark 2 roughed up.
    Made out of a piece of solid, thread over original mounts then butt up tight and lock on.
    #88
    smilin jack likes this.
  9. WILL_S
    Feb 16, 2009
    3,655
    Got sent home from work so i didn't have to do any of this :ricky
    Bonus shed time .
    Finished off the shock mounts and knocked up another jackshaft to run 14/15 gearing
    #89
    smilin jack, Pezz_gs, GR0NK and 2 others like this.
  10. Pezz_gs
    Pezz_gs Cant ride for crap
    Nov 13, 2004
    5,556
    Sydney Skunkworks
    Well @WILL_S
    Surely the rain has drained away by now . . . :*sip*
    I have a 57.5mm OD spacer coming this week so I can finally mount my airbox . . . .
    Pezz
    #90
    smilin jack and WILL_S like this.
  11. WILL_S
    Feb 16, 2009
    3,655
    Sure has ...bloody beaut weather atm
    Project sort of on hold again while i try to get husky finished for a dash out to finke in june .
    #91
  12. GR0NK
    GR0NK Got some screws loose!
    Sep 24, 2006
    10,109
    Stuck in 80s
    Any progress on that monster motor?
    I have a few CT90 motors, a few ATC 125M motors and an XL185 motor. I would like to know what the easiest way to use the 185 top-end on horizontal cases would be. Ideally it would be using "whatever I have laying around". :wink:
    Also I resumed work on my Pull-Start CT90. Your ATC front suspension swap showed me how to put the new front suspension on mine so thanks for that. :beer
    Sean :D
    #92
    Pezz_gs likes this.
  13. WILL_S
    Feb 16, 2009
    3,655
    Um no progress atm.
    Need to get back onto it
    The easist way is cut the front of the cases off weld on a block off alloy and machine to suit. There is a bloke in the uk that has built a few variations using c90 .
    #93
  14. WILL_S
    Feb 16, 2009
    3,655
    #94
  15. GR0NK
    Sep 24, 2006
    10,109
    Stuck in 80s
    Tabarnac Jack! I've been reading the Big Bore DIY thread (SPOILER: you have to register to see it) and the technical abilities of those three guys (you know the ones) is incredible. :eekers
    I thought I knew stuff but I realize now I'm just a caveman with hammers and flat screwdrivers. :lol3
    Sean :D
    #95
    Pezz_gs likes this.
  16. Pezz_gs
    Nov 13, 2004
    5,556
    Sydney Skunkworks
    Oh @WILL_S . . . .
    I was hoping you had yours progressing??
    Im now planing my next little Big Wheel effort . . . . . Reg the Wonder RV 125 (PE175 Motor) is being retired
    #96
  17. WILL_S
    Feb 16, 2009
    3,655
    Hammers chisels n screwdrivers could knock this out :photog
    http://www.c90club.co.uk/viewtopic.php?f=13&t=21856
    Things might start moving again. Just got back from the imbil rally and my stroker postie motor is howling down the bigend ...... got me home ...
    Time to find time to pull it down and decide which motor bits i put together can't go back in cc lol
    Chasing a bw80 front hub and maybe rim for the fatcat
    #97
    Pezz_gs and GR0NK like this.
  18. GR0NK
    Sep 24, 2006
    10,109
    Stuck in 80s
    #98
    WILL_S likes this.
  19. WILL_S
    Feb 16, 2009
    3,655
    In my head i keep hearing .....sidecar.....sidecar.....sidecar..
    The trouble with riding 6+hrs a day you have heaps of helmet time and i am really digging sidecars.
    Oh and another one of the coast to coast posties is coming home.
    All of a sudden i have some motivation again .
    #99
    Te Hopo and Pezz_gs like this.
  20. Pezz_gs
    Nov 13, 2004
    5,556
    Sydney Skunkworks
    Dual motors @WILL_S
    I had a mind design using a cut down Postie tub and swing arm on a sidecar and you could use a 110 to drive the sidecar wheel and a Big Bang motor to drive the bike
    Roadracer_Al, GR0NK and WILL_S like this.
