Sometimes its minor, sometimes serious, sometimes your dealer/importer/producer let you know, sometimes not ... So here everything I get aware of, starting from 2017. To be continued. 7/8/17 HUSQVARNA 125, Model year 2018 The Hazard Due to deviations in the manufacturing process at Husqvarna Motorcycles’ official supplier, brake caliper assemblies front and rear might be incomplete with the anti-rattle plates and cotters possibly missing. Therefore, both front and rear calipers on all affected Husqvarna Motorcycles must be inspected for completeness by fully trained technicians at authorised Husqvarna Motorcycle. What to do These affected models and vin’s are not released to customers (end users). Affected vins are to be checked and corrected accordingly to be prepared before sale to customers. 24/7/17 BMW R1200GS, Model years 2013-2017 The Hazard Clearance developing in the fork tube caps. What to do Seek your local dealer for further information and a check to be carried out on your bike. 22/5/17 HUSQVARNA TR650, Model years 2013-2014 The Hazard Market monitoring has shown isolated cases of occasional stalling in the engines of TR 650 Terra and TR 650 Strada model vehicles. If the engine stalls, this could lead to dangerous riding conditions and pose a safety hazard to the rider and other road users. What to do Owners will be sent a letter to advise them of the recall. Owners should contact an authorised Husqvarna Motorcycles dealer to arrange a booking as the ECU of the vehicle has to be remapped at an external supplier's facility. 15/5/17 Yamaha MT09 and XSR900 Motorcycles The Hazard If an external impact occurs on the lower handle bar, engine vibration may cause the lower handlebar stud to loosen and fall off. If the lower handlebar stud loosens and falls off, it may result in loss of control and a potential crash hazard. What to do Consumers will be contacted by direct mail. Consumers should contact their local Yamaha dealer to arrange an inspection and repair of the motorcycle. If you no longer own your motorcycle, please advise Yamaha Motors 27/2/17 KTM 1290 Super Duke GT, Model years 2016-2017 The Hazard Due to leaks or potential leaks in the fuel hose used in specific vin production, it has led KTM to demand replacement of the fuel hoses. What to do Contact an authorised KTM dealer without delay to make a booking where the fuel hose will be replaced free of charge 9/1/17 KTM 690 Duke, 690 Duke R, Various years 2012-2016 The Hazard Due to deviations in the assembly process, contact may occur between the wiring harness and the ABS modulator. As a result and in certain situations an electrical connection may be created via the brake line, between the ABS modulator and the vehicle ground. A conductive brake line can overheat and ultimately melt which can result in failure of a brake system circuit. What to do Consumers will be contacted by direct mail. Consumers should contact an authorised KTM dealer to arrange an appointment for an inspection of their motorcycle. Unless visiting your dealership for inspection, avoid riding the vehicle until inspected. The vehicle will be checked and repaired free of charge as per the manufacturers guidelines.
About 2 out of 3 bikes around the globe being affected isn't really "isolated"...the next major hurdle being to find a Husky/KTM/ BMW dealer who is a) able b) authorized c) equipped do do the job. ECU has to be mailed to Italy (for NZ+AUS/Pacific) to be flashed. Don't wait for any possible letter (they might not arrive this century), get onto a dealer quick-smart. BMW+KTM were rather "monitoring" their corporate bank balance than monitoring the market....action was solely brought by the pressure of owner groups. The recall affects ALL TR's (Terra+ Stradas) ever built/ sold. Thanks for posting this up.
KAWASAKI KLE, Model year 2017 The Hazard The tail lamp socket could loosen allowing the light bulb to fall out. The tail lamp would then not illuminate. What to do Contact your Kawasaki dealer to arrange to have the lamp socket replaced
Renthal Motorcycle clip-on handlebars The Hazard The affected parts can fail due to stress corrosion cracking. If the parts fail while riding the handlebar clamps can become loose on the fork leg causing the rider to lose control and crash. What to do Stop using the handlebar clamps and return the part to Renthal for a free of charge replacement set.
DUCATI MULTISTRADA, Model years 2016-2017 The Hazard An intensive off-road use of the motorcycle could result in a breakage of the lower eyelet of the rear shock absorber fastening to the swing arm. What to do Please get in touch with your Ducati Service as soon as possible to schedule an appointment for checking and, if necessary, replacing the rear shock absorber assembled on your bike. This check requires few minutes. If the shock is required to be replaced, this operation requires a few hours. Please be reminded that the upgrade will be absolutely free of charge. Honda GL1800 Goldwing, Model years 2001-2010 The Hazard A problem may exist with the braking system of some GL1800 Goldwing models. The rear brake may drag without the brakes being applied. What to do If you receive a letter indicating you may have an affected motorcycle, please contact your local Honda dealer an arrange for your Goldwing to be inspected.
INDIAN 8-BALL, Model years 2010-2017 The Hazard Victory engineering has determined that, in certain circumstances, some Cross Country, Cross Country Tour, Cross Roads, Magnum and Hard Ball models may experience damage to the rear brake line. Motorcycles experiencing prolonged misfire conditions may produce increased catalytic converter temperatures causing the retention clip securing the rear brake line to melt. In extreme cases, the retention clip may melt onto the catalytic converter, increasing the risk of brake line damage. What to do Contact your nearest dealer to arrange bulletin completion. INDIAN CHIEF, CHIEFTAIN, CLASSIC, ROADMASTER... Model years 2017-2018 The Hazard Indian Motorcycle has determined that some motorcycles equipped with halogen headlights may have been assembled using a non-compliant headlight not matching destination market requirements. Affected motorcycles, designated for sale in North America, may be equipped with an E4 (European) headlight assembly and are not considered compliant per NHTSA standards. Conversely, certain International models may be equipped with an SAE (North America spec) headlight, which is considered non-compliant per ECE standards. What to do Contact your nearest Indian Motorcycle Dealer to arrange bulletin completion.
TRIUMPH PR3, Model year 2016 The Hazard A bracket introduced at start of production for the affected models may interfere with the link lead, resulting in damage to the outer protective sheathing and, over time, potentially exposing the wire. Contact between the bracket and the exposed wire may lead to an electrical short. What to do The original Link Lead will be removed and replaced with a new identical part, which will be routed so as to avoid possible contact with the bracket edge. Owners to contact nearest Triumph Dealer to have recall rectification carried out.
DUCATI 1299 PANIGALE, 1299 PANIGALE... Various years 2015-2018 The Hazard Due to a possible fault of the floating piston of the Brembo front brake radial master cylinder installed to the motorcycle, as a precaution it is necessary to replace the faulty piston with a redesigned and fully reliable component. What to do Please, contact your local Authorized Ducati Service as soon as possible to make an appointment for the update. For further information on the recall you can contact an Authorized Ducati dealer or emailinfo@ducati.com.au
KAWASAKI ZR, Model year 2017 The Hazard The holes in the rear shock absorber tie-rod frame mounts can become elongated if the rear shock absorber bottoms out. This can prevent the rear shock absorber from operating properly and could result in an accident. What to do Contact your Kawasaki dealer to arrange to have a bracket kit fitted
KTM 1050 in 1993 ? More 2013 Anyway, KTM's downgraded models are never a good idea. KTM 1050, Model year 1993 The Hazard The Piston material, located in Hand brake master cylinder (Front Brake), may crack. Should that occur it can adversely affect front brake function or performance. What to do Consumers will be contacted by direct mail or by an authorised dealer notifying them of the recall. Consumers should contact an authorised Husqvarna dealer to arrange an appointment for their motorcycle where the piston in the handbrake cylinder will be replaced with an updated part Free of Charge.
KTM/Husqvarna 2016-2018 Meltdown Don't wait for KTM do contact you (KTM NZ does in my experience not) - Go after them and make sure your bike is safe ! KTM 690, 1290 Super , 1290, 1290, Model years 2016-2018 The Hazard The Piston material, located in Hand brake master cylinder (Front Brake), may crack. Should that occur it can adversely affect front brake function or performance. What to do Consumers will be contacted by direct mail or by an authorised dealer notifying them of the recall. Consumers should contact an authorised Husqvarna dealer to arrange an appointment for their motorcycle where the piston in the handbrake cylinder will be replaced with an updated part Free of Charge. HUSQVARNA FS 450, Model years 2016-2018 The Hazard The Piston material, located in Hand brake master cylinder (Front Brake), may crack. Should that occur it can adversely affect front brake function or performance. What to do Consumers will be contacted by direct mail or by an authorised dealer notifying them of the recall. Consumers should contact an authorised Husqvarna dealer to arrange an appointment for their motorcycle where the piston in the handbrake cylinder will be replaced with an updated part Free of Charge.
More KTM .... KTM 690, Model years 2016-2017 The Hazard Due to tolerance variations, the system comprising the fuel tank, fuel tank filler neck and fuel tank filler neck gasket may leak and fuel may escape. What to do Consumers will be contacted by direct mail notifying them of the recall. Consumers should contact an authorised KTM dealer to arrange an appointment for their motorcycle. Authorised dealers will complete replacement of existing components to modified components - free of charge. Customers can find an authorised dealer using the dealer search on the KTM website.
KAWASAKI ZX1000, Model years 2016-2018 The Hazard On eligible units, the strength of the gear in the transmission is not sufficient so that the gear may be broken by excessive impact force depending on the shifting manner in use. In the worst case, it could lead to the potential for a crash. What to do Contact your Kawasaki Dealer to verify if your motorcycle is eligible and to arrange to have the repair work carried out.
HARLEY DAVIDSON SOFTAIL, Model year 2018 The Hazard Latching arm on Harley–Davidson Accessory 2018 Softail Detachable ™ Saddlebag Kits may have inadequate engagement to the saddlebag mounting plate/bracket. This may allow the latching arm to rotate out of the locked position. What to do Owners to contact a Harley-Davidson dealer to schedule an appointment to bring the saddlebags to the dealer and have the parts from the recall repair kit installed on the saddlebags, at no cost to the customer.
HONDA SXS1000 (2016-18) The Hazard With prolonged use in a misfire condition the muffler heat shield can overheat the plastic cover. There is a risk of the plastic cover melting and catching fire. What to do Contact your nearest Honda Motorcycle Dealer. A list of dealers can be found on the Honda Motorbikes website listed below.
INDIAN CHIEF, Model year 2018 The Hazard Indian Motorcycle has identified that some 2018 111 ci motorcycles have been manufactured with a right-hand switch cube that does not meet quality standards. Affected switch cubes may develop corrosion within the Stop/Run/Start circuit. If the key fob is stored on or near the motorcycle and all other safety interlocks are met, this condition could lead to unintentional vehicle power-up or start sequence. What to do Contact your nearest dealer.
DUCATI SUPERSPORT, SUPERSPORT S, Model years 2017-2018 The Hazard Due to a possible interference of the fuel tank and Airbox drain hoses with the horizontal cylinder exhaust manifold, in certain remote instances said hoses may melt in the bike lower left area (under the battery) resulting in a potential risk of fire. What to do Please, contact your local Authorized Ducati Service as soon as possible to make an appointment for the update. For further information on the recall you can contact an Authorized Ducati dealer or email info@ducati.com.au TRIUMPH STREET TRIPLE, Model years 2017-2018 The Hazard Due to incorrectly sealed electrical circuits in the left-hand switch cube, water may contaminate the component and, as a consequence, the turn signal indicator and headlamp control switches may not function correctly. What to do Vehicle owners to contact Triumph Dealer ASAP to have their bikes rectified by replacing the original left hand switch cube with a new version. DUCATI PANIGALE, Model year 2018 The Hazard Due to a problem with the fuel tank seal and ventilation system on the Panigale V4, a fuel leak may occur from the filler plug (when opening it) or from the area under the rider seat (both when riding the bike or when it is parked). What to do Please, contact your local Authorized Ducati Service as soon as possible to make an appointment for the update. For further information on the recall you can contact an Authorized Ducati dealer or email info@ducati.com.au.
Indian Scout Models 2017-2018 The Hazard Indian Motorcycle has determined that 2017 and 2018 Scout / Scout Sixty and Scout Bobber models, equipped with Anti-Lock Brakes (ABS), experience decreased brake performance resulting from the presence of air in the brake circuit. Affected models have had a small amount of air present in the system, which after time, cause a soft brake lever / pedal feel and a decrease in brake performance. What to do Contact your nearest Indian Motorcycle Dealer Honda CRF1000 Model Years 2016-2017 The Hazard Honda has identified an issue with the retaining circlip for the accessory center stand kit for the 2016 and 2017 model year CRF1000. The circlip can break and the center stand can become detached. What to do If you own a 2016-2017 model year CRF1000 fitted with the accessory center stand kit, contact your nearest Honda Motorcycle dealer. BMW G310, Model Years 2017-2018 The Hazard In the course of quality analysis, BMW Motorrad has determined that the side stand connection can bend, or in an extreme case even break. The side stand connection will be checked for preliminary damage and an additional reinforcement will be installed as the side stand becoming unsafe cannot be ruled out in the case that this fault should occur. What to do Contact your authorised BMW dealer.
Hello I am looking to buy a 2013 Terra ABS and wanted to asl if you can tell me if I can contact the company in Italy to reflesh the ECU? The bike I am looking at has no p problems so far I could see but i did not tested it yet to know if ithas or not the stackling problem. The local Husky dealer is no help as they just got the dealership in the country and the former dealer who imported this bikes does not exist any more here in the Domninican Republic. Do you think its worth doing the reflash or getting me into such a bike. It has only about 17,000km on the dash which by the way already has the buttons worn out. So what can you recommend me. Thanks.
