BMW 450 enduro (merged) threadfest...
Discussion in 'Thumpers' started by Max Kool, Mar 4, 2007.
  1. djroszina
    djroszina Long timer Supporter
    Jan 30, 2006
    2,835
    Midwest
    I may take you up on that. My other dualsport is a F650gs Dakar that has reworked forks with monorate springs and Race Tech Gold Valves and a Hyper Pro on the rear. She is still on the heavy side, and that’s why I snagged the 450. The 650 is now being setup for Alaska next year. 65B37EA6-1C10-4F9A-9E85-567BC79C080D.jpeg C0CA943B-BD76-4BAA-9C8C-29CA8DD0414A.jpeg
    cgguy09 likes this.
  2. Denny Mann
    Denny Mann Long timer
    May 18, 2011
    1,387
    South Central Pennsylvania
    I had WER rework my shock and I ran the fork compression all the way out for east coast woods riding. The suspension worked good in the rocky single track but the motor and ignition mapping were a hand full at low speed. After a year of trying to make the 450x something it wasn't made for I rode it on thousands of miles of dirt and jeep roads. I had the bike for 5 years and put 16500 miles on it. I only weigh 155 lbs and I did not change any springs. With all of the fuel your bike will hold you should not need stiffer springs in my opinion. You might want a 2010 ignition to smooth out the bottom end.
  3. cgguy09
    cgguy09 Scientiæ Cedit Mare
    May 25, 2010
    1,747
    Astoria, OR
    So to re-ask my question...how much do these bad-boys go for? Lets assume it's stock, not a garage queen, with reasonable hours on it. (I don't have a bike in mind, just throwing out the hypothetical).
  4. djroszina
    Jan 30, 2006
    2,835
    Midwest
    3500 to 4000
    cgguy09 likes this.
  5. djroszina
    Jan 30, 2006
    2,835
    Midwest
    I looked on bike bandit and all the bikes share the same ecm 2007 thru 2010... what am I missing and should look for?
  6. Denny Mann
    May 18, 2011
    1,387
    The 09 was not programmable but 10 is. Even with the 13 tooth counter shaft sprocket the bike would flame out in the tight rocky trails. It would jerk and lunge so much it would tire me out on a long trail ride. I replaced it with a more mellow DRZ which is not as thrilling to ride but more controllable. So for the wide open 2 track the 450X was a blast and I rode it that way for years saving the technical riding for my Beta 2 smoke.
  7. Denny Mann
    May 18, 2011
    1,387
    $225.jpg If anyone is looking for a front wheel, sub frame and/or fuel injection system. I am cleaning out the garage. Just PM me if interested.
  8. ErwinE
    ErwinE Adventurer
    Aug 27, 2016
    14
    The Netherlands
    Hi - this is my 2010 G450X I purchased recently, and which is technically brand new: no kilometers and only a few running minutes. Not sure what to do with it: ride or not. Will decide early spring.
    cgguy09 and djroszina like this.
  9. djroszina
    Jan 30, 2006
    2,835
    Midwest
    Nice score. If money were no object I would run out and buy a Beta 390 RR and keep the G450X pristine with zero miles. If not, then ride it, they are way too much fun to not experience.
    ErwinE likes this.
  10. ErwinE
    ErwinE Adventurer
    Aug 27, 2016
    14
    The Netherlands
    The BMW is the third in the garage, so I am not going buy another one, even if it were a nice Beta. Generally, I think motorcycles are for riding, so that is probably what I will be doing with the BMW as well. I bought it because I feel very attracted to it.
    djroszina likes this.
  11. ErwinE
    ErwinE Adventurer
    Aug 27, 2016
    14
    The Netherlands
    In the future, historians will call the era we're living in the "aluminium age". Mounted the bash plate and hand protectors today.
  12. djroszina
    Jan 30, 2006
    2,835
    Midwest
    My bike lacks the barkbuster style hand protectors. How were the Acerbis to install, any mods required?
  13. ErwinE
    ErwinE Adventurer
    Aug 27, 2016
    14
    The Netherlands
    The cables on the handlebar might need minor re-routing, but nothing serious. On the left hand side, the handlebar grip needs to be cut. On the right hand side the same, and end of the plastic tube (throttle) needs to be sawn off.
  14. decafe
    decafe Been here awhile
    Apr 10, 2008
    863
    new jersey
    itsgunnahurt and ErwinE like this.
  15. decafe
    Apr 10, 2008
    863
    new jersey
    I use a gel seat pad over stock cheap and greatly improves those longer rides
  16. djroszina
    Jan 30, 2006
    2,835
    Midwest
    Who makes that gel pad?
  17. decafe
    Apr 10, 2008
    863
    new jersey
    i got it at Cycle Gear on rt70 in cherry hill nj but pretty common look for one that fits your butt i think $39.00
  18. Louv
    Louv nerd with knobbies
    Nov 20, 2008
    118
    Sillycon Valley
    Riding fire roads, and some single-track near Stonyford, CA.
    31232236_10155350214206835_4494535116072157184_o.jpg 31154355_10155350214901835_7057372054697279488_o.jpg
  19. CRUX
    CRUX Unicorn Tamer
    Apr 13, 2016
    84
    Corvallis
    Okay guys. I need some help! I’ve got an intermittent surging (hiccuping?) happening at low speeds, just barely cracked throttle. It’s like someone is repeatedly twisting the throttle very quickly, creating a jerking motion. If I roll on more throttle, go through the gearbox or use that same throttle position at high speeds, no issue. It basically makes slow in town riding terrible and is obviously an issue that needs correcting. It’s an 09 with only a couple thousand miles. Bike is flawless and very well maintained. Perfect really. To thicken the plot, it will go months sometimes without this issue. Sometimes on trips it will develop after a restart, occasionally I can shut the bike down, let it shut down then restart and issue is gone. This is extremely inconsistent though and in no way have I seen a pattern here.
    Here’s my thoughts. Could this be a TPS that is wearing out in this certain position? Butterfly, fuel pump, efi? My best guess is that it is stemming from an exhaust leak at the mid pipe connection that I can’t seem to shake for some reason, and that is effecting the O2 sensor there? I’m already ordering a replacement mid pipe exhaust gasket, but not confident that will fix this leak.
    Any ideas?
  20. ErwinE
    ErwinE Adventurer
    Aug 27, 2016
    14
    The Netherlands
    This is what I have experienced as well. Slow riding, on a straight trail or tarmac, after more demaning work. Feels like the throttle is closed and immediately reopened, twice per second. Happens more when the engine is hot. Possibly related is that my G450X backfires when changing to a lower gear or generally reducing speed.
