BMW F650 Funduro ADV Build
Discussion in 'Some Assembly Required' started by donteatmyfood, Jul 30, 2020.
  1. Roadracer_Al
    Roadracer_Al louder, louder, louder!
    Aug 5, 2007
    2,735
    Oakland, CA
    Just repaint everything the same color. Then it will all match.
    #21
    gmk999 likes this.
  2. neppi
    neppi Long timer
    Mar 9, 2017
    1,569
    Tauranga, New Zealand
    If it’s the same as other Beemers, Krylon Dull aluminum + Krylon satin clear would do the trick perfectly. If it was mine, I’d just skip the laquer thou... ;)
    #22
    gmk999 likes this.
  3. okennon
    okennon Been here awhile Supporter
    May 17, 2009
    371
    Surprising and damn flat Suffolk
  4. Lurkio
    Lurkio Adventurer
    Oct 27, 2015
    30
    The Deep South........of Wales
    I had a 2002 F650CS and I painted the gearbox case cover with hammerite smooth silver spray can. It was quite a good match. It was OK with the heat, but if I did it again I'd use a primer as it started to come off after a coupe of years. Hammerite is meant for steel- not alloy.
    #24
    TonyKZ1 and gmk999 like this.
  5. Godoh
    Godoh Adventurer
    Jan 28, 2019
    17
    Australia
    I have a 96 funduro, I have modified it a bit too. It is a bit post apocalyptic, Not being a fantastic metalworker it looks a bit wild but works great for where I ride. Mostly dirt forest trails and roads. I never did like the original look of the bike but love the simplicity and engine.
    Changes I made are,
    Deleted the fairings, Honda Ascot tank, home made fibreglass seat, Mikuni BST40 carburettor with DS650 bombadier manifold. New metal side covers, made a new battery box from metal plus a toolbox under the seat where the air box was. Unifilter foam filter pod.
    Oh new dash too, home made from aluminium. Oh also I drilled and tapped the countershaft to fit a bolt and nut to hold the countershaft sprocket on as mine only had a dodgy circlip holding the sprocket on.
    Pete
    #25
    mikehi, Geschift, tobiism and 4 others like this.
  6. donteatmyfood
    donteatmyfood The Better Idiot.
    Mar 28, 2014
    40
    Cincinnati
    LOL...I would love to see someone improve the Scarver! XD
    #26
    Roadracer_Al likes this.
  7. Hellracer.nl
    Hellracer.nl What the hack???
    Aug 25, 2012
    1,462
    Netherlands
    Nice!
    I've also got a Funduro (must be the goofiest name ever). Mine is a 94 that I bought for €300 (like $250) a few years ago.
    I've slightly modified it and I use it to ride trails and light offroad and camping trips. Works really well although it could use some upgrades suspension wise.
    Good to see some more F650 enthousiasts here, I'm following this thread.
    #27
    TylerWatts and Roadracer_Al like this.
  8. Gedrog
    Gedrog 1000 mile stare a 1000 stories to tell
    Oct 20, 2013
    4,559
    Lost in the Sahara
    When this bike was first launched I went ape and badly wanted one but I just could not afford it I eventually ended up with an 07 F650 Dakar but every time I see these ones I remember my 20 something years dreaming of places I could go with this wee beasty
    #28
    Pezz_gs likes this.
  9. Gedrog
    Oct 20, 2013
    4,559
    Lost in the Sahara
  10. dbarale
    dbarale Squiddly slow
    Oct 20, 2008
    3,049
    Western NC
    Sooooo, how badly do you want it out of your garage? :evil
    I remember lusting all over that bike when I was younger…
    #30
  11. Rufjeep
    Rufjeep Been here awhile
    Jun 9, 2008
    503
    Blue Ridge, GA
    I need to do something with that bike; it's been in the garage for years, and is a basket case right now. I replaced the head gasket several years ago and, on its maiden voyage, the bike jumped time and bent a valve. The piston and head are fine, but it will need a new valve and head gasket. Everything else is there. The bike is still about 80% together: tank seat, fairing, rear fender, head, rear subframe, etc. are off, but the engine is in the frame, wheels, suspension, etc. are still on. I also installed new rear shock shortly before it grenaded.
    Make me an interesting offer....heck, what sort of outdoor man stuff are you willing to barter. You get a project and I get garage space.
    #31
    dbarale likes this.
