BMW F800GS 2010 engine cooling system problem
Discussion in 'Parallel Universe' started by michael205, Mar 1, 2020.
  1. michael205
    michael205 Adventurer
    Mar 24, 2017
    17
    Hi, first and foremost, english is my second language so i might write weird sh * t. bear with me :)
    I have a problem with cooling system. It's NOT overheating, it's the opposite...
    It's allways with 2 "lines", sometimes 3 but only on intersections.
    From what i know there are two "circuits" for coolant to take, small one and big one with radiator.
    It looks like it allways use big circuit and with temp 4-10*C (40*F ?) it never reach engine normal work temp.
    It might not be a problem in summer but not it is.
    What should change to get it work as it should ?
  2. Indy Unlimited
    Indy Unlimited Long timer
    Jan 21, 2007
    1,941
    Parker, CO
  3. JRWooden
    JRWooden Homeless motorcycle vagabond ... and ... loving it
    Jul 5, 2008
    6,230
    The great state of confusion
    I have a similar problem and will be replacing my thermostat soon.
    From feeling the radiator it appears the thermostat is stuck open or partly so.
    I need to sit down with the parts list to see what o-rings and other parts are needed.
    Also I will replace the radiator cap as well just because it's the original unit.
    The thermostat is item #3
    https://shop.maxbmw.com/fiche/DiagramsMain.aspx?vid=51596&rnd=07242017
  4. michael205
    Mar 24, 2017
    17
    Thanks for fast replays,
    I will check termostat and if it's not it then sensor.
    When i leave motorcycle running idle it will get hot 3-4 "lines" , only when riding will temp go down so i would bet that thermostat is faulty.
    https://boxer-parts.eu/radiator-thermostat , it's not expensive 37 euro + 5 euro o-ring.
