Discussion in 'Some Assembly Required' started by Hondo, Apr 26, 2018.
  1. JimVonBaden
    JimVonBaden "Cool" Aid!
    Feb 11, 2005
    101,524
    Alexandria, VA
    Is it 3M trim tape? If so, it will stay on.
    #41
    StevieVVet likes this.
  2. JimVonBaden
    Feb 11, 2005
    101,524
    Alexandria, VA
    Yeah, the rubber side can be an issue. I would get some wide 3M tape and maybe either redo it, or have it ready to redo. I use a light rub of acetone on the rubber and alcohol on the aluminum to ensure adhesion.
    #42
  3. Sic Semper Tyrannis
    Sic Semper Tyrannis Plays with Banjos, Boats and Bikes...
    Aug 9, 2009
    2,544
    RVa
    I grabbed one of those too. Works surprisingly well.
    #43
    JagLite likes this.
  4. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    13,122
    Anchorage Alaska
    I have one too and it really helps :thumb
    #44
  5. kevlar930
    kevlar930 Been here awhile
    Jul 3, 2008
    576
    Philly
    Thanks for the link. $20 is a lot cheaper than a new shield, so I thought I would try this first.
    #45
    randypower likes this.
  6. richard cabesa
    richard cabesa The Mayor Supporter
    Jul 24, 2003
    9,699
    Santa Cabesa
    Is there not space to use the soft straps around each fork leg at the bottom triple clamp? Maybe even pulling to opposit sides to clear the plastics? I
    I'm planing on putting this bike on the back of the Sprinter
    #46
  7. richard cabesa
    Jul 24, 2003
    9,699
    Santa Cabesa
    Thanks, and I have your other thread. I am taking off tomorrow with the Grom on my modified rack. The rack was rated at 400 lbs and used only the center receiver. I raised it up 4" and out 6" and then added two more support bars at the out side of the van hitch structure
    I'll be hauling the Grom (150 lbs lighter than the 310GS ) for the next week
    #47
    JagLite likes this.
  8. TTGator
    TTGator 2016 BMW S1000 XR, 2018 G310 GS
    Jun 14, 2016
    343
    Kernersville, NC
    I was able to strap over the forks easily with noting touching the plastics...
    #48
    JagLite likes this.
  9. MichaelJ
    MichaelJ Long timer Supporter
    Jul 17, 2003
    6,392
    Northern Virginia
    Tried to figure out what the grab rail on the seat was :hmmmmm- and then I realized that it was the van's spare tire housing.
    Nice positioning.
    Sorry that I didn't get a chance to say hi when I was out in Denver.
    #49
  10. GsVs
    GsVs Goin' Somewhere
    Dec 30, 2002
    1,910
    (TN) USA
    Hondo,
    Thanks for all the great information and pictures ….
    #50
  11. JMo (& piglet)
    JMo (& piglet) Unicorn breeder
    Apr 1, 2007
    10,532
    California
    Looks great Hondo!
    I presume there is no catalytic converter in the system now (which together with the shorter header, undoubtably adds to the overall noise output) - and with this style of pipe you could also now remove the pillion peg hangers if you wanted?
    I think this set-up combined with the R&G tail-tidy and the R grab-handles (rather than the GS rack) would look kick-ass!
    Looking forward to following your ongoing mods!
    Jx
    #51
  12. Oilhed
    Oilhed MarkF
    Oct 17, 2003
    19,050
    Connecticut
    Can you remove the grab rail/luggage rack and ride without it? Or is there some small minimalist grab rail that can replace it? Thinking with the tail tidy and without the rack it would look cleaner.
    #52
  13. ovlaicu
    ovlaicu Noob
    Apr 8, 2018
    367
    Ontario, Canada
    You can use the g310r grab handles. 200$
    Sent from my SM-G950W using Tapatalk
    #53
  14. MichaelJ
    Jul 17, 2003
    6,392
    Northern Virginia
    Plenty of "R" owners wanting the GS rack - just sayin'...
    Look here: https://www.g310rforum.com/
    #54
  15. JMo (& piglet)
    Apr 1, 2007
    10,532
    California
    They are actually cheaper than that:
    Grab Handles - item #1 & #2 on diagram #46-1848:
    https://shop.maxbmw.com/fiche/DiagramsMain.aspx?vid=58311&rnd=07242017
    Plus ideally you'd also fit the plastic trim for between the seat side-panels (not essential, but to keep things looking tidy):
    Tail trim panel - item #2 on diagram #46-1866:
    So little more than $100 - and note the existing hardware can be used to mount them, although you will also need a handful of penny washers to stop the edge of the grab-handles rubbing on the underside of the GS side panels (as they are a slightly different profile to the R panels).
    Alternatively, as Micheal suggests - it ought to be pretty easy to find an R owner who might be willing to swap (especially as the rack retails for around $250 in comparison) - that is what I did at my dealer when I bought the bike.
    Hope that helps someone, even if Hondo needs to keep his rack for the top-box of course.
    Jx
    #55
  16. Corsair84
    Corsair84 Adventurer
    May 28, 2019
    49
    Mass
    Any links to the clips that go on the fairings? those metal tabs that bend oh so easily?
    Beautiful write-up btw, enjoyed following this thread, any new updates?
    #56
  17. Corsair84
    May 28, 2019
    49
    Mass
    @Hondo Didn't like the Remus? Will you let us know how the seat is? Any particular reason selling the bike?
    #57
