BMW G310GS Thread
Discussion in 'Thumpers' started by Eddy Alvarez, Apr 22, 2016.
  1. GreatNorthRider
    GreatNorthRider Adventurer Supporter
    Jul 10, 2008
    66
    Northern Michigan
    :clapOk, 15t fit and quick test accomplished. I like this mod, in fact the bike probably should have come this way from the factory. Some findings from a brief road test both on and off road....
    - Much better start off from full stop. Don’t have to rev the engine as much to get rolling and less tendency for the bike to feel like it is going to stall. Almost feels like I have a bigger flywheel. More tractor less two stroke.
    - In high speed riding, there is indeed a 275-300 rpm difference noted at common cruising speed...55-62mph. Also noticed maybe a little more buzz in the seat area. Could this be from odd/even sprockets?
    I only got up to 62 mph on our deer infested roads so I’m not sure how freeway speeds will be but with such a small RPM increase, I doubt it will make any difference in rideability.
    -Roll on in 5th and 6th gear feels better.
    - In low speed riding, I feel like I have reduced the lower limit of confidante low speed handling from 9 to 7mph. This makes a big difference when trying to crawl up loose surface hills. Didnt feel the need to feather the clutch as much. (Remember, short test ride of 5 miles paved to 3 miles two track. )
    I was really looking for better low speed power and rideability and have found it with this simple mod! I see no reason not to do it.
    I’m going to ride around like this for awhile and continue testing. Not sure when I’ll try the 41 rear.
    sonmaix, AdvHunter, Tyler123 and 8 others like this.
  2. JMo (& piglet)
    JMo (& piglet) Unicorn breeder
    Apr 1, 2007
    8,995
    California
    Thanks for the quick reply GNR' - for info (and for anyone else wondering), I know someone posted a link to a gearing calculator before, but I found this simple site here that helps to work out the difference in ratios (plus how many +/- links in the chain length are likely to be required too).
    Based on the stock gearing being 16/40 - that equals a 2.5 ratio...
    15/40 = 2.67 = -6.3% (GNRs bike currently)
    16/43 = 2.69 = -7.0% (My bike currently)
    15/41 = 2.73 = -8.5%
    15/43 = 2.87 = -12.8%
    ...the percentage change is the drop in speed for the same amount of RPM, or conversely the % increase in torque.
    So in summary, changing the front sprocket by -1 tooth (as GNR has just done) offers a little less % change than adding +3 teeth to the rear (as I currently have on my bike), while going to 15/41 offers more of a drop, and is, as I suspected, probably the best combo for more serious off-road use, while retaining reasonable on-road performance too. Any more than that (eg. 15/43) would be too much of a compromise on road I imagine.
    for info. the rear sprocket PCD on the G310GS is the same as the twin-cylinder F650GS, so technically you could grab an OEM rear sprocket from that bike (47T) and go crazy - however, 16/47 = 2.94 = 14.9% - so probably way too extreme for most owners.
    Hope that helps...
    Jenny x
    ps. I'm going to hang onto the 43T rear though to pair with a 15T front - just in case I decide to ride the Rubicon on this bike too ;o)
  3. ChappyADVR
    ChappyADVR Adventurer
    Apr 27, 2018
    92
    Melbourne, Australia
    That really does help - breaks it down nicely! Thanks @JMo (& piglet)!
    Richarde1605 and randypower like this.
  4. rwiles
    rwiles Been here awhile
    Jan 5, 2006
    517
    Losck some vice grips on a spring at the bottom of the hook, in line with the spring, good and tight. Lay down to get pull leverage. Pull the spring hook over the stud to the furthest groove first, and pop off the vice grips. If a weak old man like me can do that pretty easily, anyone can.
  5. Jeepster360
    Jeepster360 Been here awhile
    Nov 8, 2017
    289
    Idaho
    Ok, so the 15 tooth front is in. Took about 30 min to install and adjust the chain. Took a 45 min ride around town and down river road. First off.........anyone who has this bike should consider this modification. We have a lot of 35mph roads in my town. With stock gearing, on the flat and level, 5th gear was ok at 35mph but just under 4000rpm. There wasn't much torque available at that speed. 4th gear was fine but if traffic moved up to 40mph it felt a little too low. 5th gear now fits the 33 to 40mph traffic perfectly for me. Pulling away from stop lights is much better. Feels much more "normal" to me. Out on the river road at 60mph the tach looks like 6100-6200rpm. I do have a 804 tire fitted to the front so keep that in mind if the Speed/rpm is off alittle. I can't believe highway travel will be diminished at all. The bike might even pull this gearing to a higher top speed overall in 6th gear.(slightly higher RPM of course). After this short ride I see no down side to this 15t front sprocket. Off road it should be a little better(could use more I'm thinking). In town it is better for sure. Highway is just as good up to 65mph atleast and maybe 70. I don't ride faster then that myself so YMMV. Best $35 I have spent on this bike for sure.
    This is the gearing BMW should have gone with from the factory. In fact, it's almost not noticable yet better in every way.
    John
  6. ovlaicu
    ovlaicu Noob
    Apr 8, 2018
    367
    Ontario, Canada
    Where did you guys order the 15 tooth sprocket from?
    Sent from my SM-G950W using Tapatalk
  7. Citizen
    Citizen Been here awhile
    Oct 16, 2017
    201
    USA
    Supplier in Illinois somewhere I believe.
    It's back a few pages.
  8. GreatNorthRider
    Jul 10, 2008
    66
    Northern Michigan
    The 15t sprocket is ordered from KHS Bicycle Parts....http://www.khsbicycleparts.com/
    The Esjot part number for the 15t front is: 50-32184-15S
    The Esjot part number for the 41t rear is: 50-32050-41
    You’ll want to talk to Betty @ 618-393-2955. I have warned her that she may be getting a few more orders. :lol3
  9. ovlaicu
    ovlaicu Noob
    Apr 8, 2018
    367
    Ontario, Canada
    Thanks a lot.
  10. sonmaix
    sonmaix n00b
    Mar 10, 2018
    3
    Estonia
    What about acceleration? Is 1-60 better with 15T sprocket?
  11. Jeepster360
    Nov 8, 2017
    289
    Idaho
    I don't really know if 0 to 60mph is faster or not. I'm not into that part of the game with this bike and what I use it for. I can tell you if you are cruising down a street at 35mph in 5th gear acceleration is better. 0 to 60 could be better, it depemds on the shift points or number of shifts vs the old gearing. If both take the same number of shifts then the 15 tooth is most likely faster.
    John
  12. HorakCM
    HorakCM Been here awhile
    Nov 13, 2012
    125
    Maryland
    Also put the 15t on, nothing really new to add the other members haven't already said, does exactly what you'd expect. Easier to lift or deweight the front wheel, less throttle input to chug along at low speed. Highly recommended if you ride tight trails.
    I wonder if a similar ratio was considered from the factory but changed to a higher option to lower revs/noise at speed? Will consider going larger on the rear after a few hundred miles. I try to avoid it but sometimes need 70+ to keep up with highway speed limits/traffic. Per gearing commander, a 15/41 will have a top speed of around 88mph, 15/43 will max out at around 84mph and may require a longer chain.
  13. stevetheb
    stevetheb mashed potatoes
    Dec 13, 2017
    93
    Bend, OR
    It's extremely hard to go past 84 with the RR lvl 2 suspension and tall windscreen on. You can do it, after WOT for a long period of time and proper conditions (new top with RR kit of 88mph). Maybe I'll consider the 15t.
    HorakCM likes this.
  14. richard cabesa
    richard cabesa The Mayor Supporter
    Jul 24, 2003
    9,632
    Santa Cabesa
    HEY !!! Look what followed me home :clap
    Just hit 200 miles so next ride out I get to twist the grip a little further :wings
  15. HorakCM
    Nov 13, 2012
    125
    Maryland
    I'm waiting on a Level 1 from RR. Today it managed to hit 80 with the 15t on flat highway, although it felt like it was already maxed out so I wouldn't be surprised if the actual speed is 5-10mph lower than on paper.
    Then I found the baby GS's limit.
    ...hillclimbs. And now it gets to live in the woods through a thunderstorm, until it dries out.
    But at least it has a key and steering lock to deter any thieving deer? ‍
    stevetheb, randypower and ChappyADVR like this.
  16. ChappyADVR
    Apr 27, 2018
    92
    Do I recall that you were on Shinkos? Because that was my exact problem. Muddy hillclimbs. Except first thing in the morning, no storm, and fewer deer.
    HorakCM likes this.
  17. HorakCM
    Nov 13, 2012
    125
    Maryland
    Yup! Shinko 804/805. I've been very impressed with how well they've been working and they've made that climb before, but that slick clay did them in. With both brakes locked up it still slid backwards downhill. :fpalm
  18. ChappyADVR
    Apr 27, 2018
    92
    Haha, yes, that's *exactly* what happened to me. At least you managed to keep yours upright. I wasn't so skilled... :muutt
    stevetheb and HorakCM like this.
  19. sonmaix
    sonmaix n00b
    Mar 10, 2018
    3
    Estonia
    Maybe I'm in a wrong topic, but I have a few concerns with my GS.
    Sometimes throttle becomes jerky from idle. Like then closing throttle to decelerate and then opening it up just a tiny bit, it is jerky. Other times it's smooth again.
    I have this strange feeling with rear suspension. Then going over bigger whoops or holes, sometimes the rear is like diving and for a fracture of moment, it almost feels like I lose torque or wheel is stuck. I'm 67 kg without gear, have added 6 klicks of preload and it's better, but not completely eliminated. Also I get occasional very slight rear wheel wobbling.
    1 month and 600 km.
  20. ChappyADVR
    Apr 27, 2018
    92
    Hmmmm, if I were you, I'd be seeing my dealer about that. Could be something loose or binding in the rear end? Someone else might have better insight though...
