BMW G310GS Thread
Discussion in 'Thumpers' started by Eddy Alvarez, Apr 22, 2016.
  1. Oilhed
    Oilhed MarkF Supporter
    Oct 17, 2003
    17,122
    Connecticut
    Looks like nobody's looking for a lil GS, at least in the northeast, this spring.
  2. shreddr
    shreddr No try, do or not do
    May 5, 2009
    285
    Exit 19, NJ :)
    What do you mean?
  3. Oilhed
    Oct 17, 2003
    17,122
    Connecticut
    I posted mine up For Sale and there has been very little interest. I thought with the price of new 2021 models and the lack of 2020s a barely used 2019 would go fast.
  4. BMWzenrider
    BMWzenrider Older & Slower Supporter
    May 9, 2003
    1,722
    CheeseHead Land
    I guess that the updates to the 2021 model are enough to drive down the desirability of the earlier models.
    - Full LED lighting, including the headlight.
    - Ride by Wire Throttle including the anti-stall programing in the ECU.
    - Slipper Clutch.
    - Adjustable levers.
    (and apparently it got porked up by an additional 12 pounds versus the original specs for the 2018 model year)
    GLWS
  5. bwallca
    bwallca Been here awhile
    Aug 4, 2007
    228
    Edmonton, Alberta Canada
    Wow, a 12lb increase is huge, maybe they made the bars out of real steel instead of cheese alloy.
  6. BMWzenrider
    May 9, 2003
    1,722
    CheeseHead Land
    2018 spec is/was 374 pounds curb weight.
    2021 spec is now 386 pounds curb weight.
  7. AEsco48
    AEsco48 Adventurer
    Dec 3, 2007
    70
    Denver, CO
    Did you ever go with the Monsoon 3 Panniers w/o a rack?
  8. WoodWorks
    WoodWorks House Ape
    Feb 11, 2003
    3,012
    Ashland, OR, USA
    No, I went with their Blizzard L bags. It’s been a long time, but if I recall correctly, the Monsoon bags were too big to fit over the exhaust pipe.
    AEsco48 likes this.
  9. OleShep
    OleShep Been here awhile
    Mar 6, 2020
    330
    Colorado
    Just ordered some XL Blizzards so I will let everyone know how they fit. I think they will still clear the exhaust but we will see. :-)
    WoodWorks likes this.
  10. AEsco48
    AEsco48 Adventurer
    Dec 3, 2007
    70
    Denver, CO
    Awesome! Did you order from https://www.enduristan-usa.com/ ?
  11. OleShep
    Mar 6, 2020
    330
    Colorado
    No they popped in-stock on Revzilla. Got notice they already shipped today..
  12. jonasj
    jonasj 2018 BMW G310GS
    Jul 21, 2017
    82
    Denmark
    Have anyone made a list of tools needed for the G310GS if stranded in the woods?
    I am thinking doing a two split kit:
    1) Small essential kit to fit under the seat, with everything needed for the shorter rides.
    2) Additional kit to bring for longer rides
    Any tips on what tools to buy to get more than one use out of a tool? For example the Motion Pro tyre irons.
    Thanks guys.
  13. FreeTheBeast
    FreeTheBeast BDR ambassador Supporter
    Jan 23, 2004
    3,576
    +1.603
    I just brought home my new 2021 310GS. It seems BMW have removed the ABS button. Does anyone know of some other way to deactivate the ABS?
    broadcastmarc likes this.
  14. Oilhed
    Oct 17, 2003
    17,122
    Connecticut
    Does the 2021 come with Knobbies?
  15. Oilhed
    Oct 17, 2003
    17,122
    Connecticut
  16. saiyamanman
    saiyamanman n00b
    Sep 9, 2015
    1
    Atlanta, GA
    hey everyone. I bought a 2021 310 GS and just under 60 miles ridden i dropped it as I was dismounting on a slope and broke my brake lever. I saw an OEM brake lever cost ~$90 and was wondering if anyone has had success using an aftermarket brake lever OR if the 2020 and under brake lever is compatible? (It's different part numbers on the bmw parts website BUT the diagrams look identical)
    I ALSO want to buy a handlebar protector so next time i have a tip over I can protect it.
  17. FreeTheBeast
    Jan 23, 2004
    3,576
    +1.603
    No. I had the knobbies installed before I took delivery.
  18. OleShep
    Mar 6, 2020
    330
    Colorado
    Looks like you relocated the turn signals for your install. Did you fab or buy a bracket?
  19. FreeTheBeast
    Jan 23, 2004
    3,576
    +1.603
    FYI - removing fuse #4 for ABS also deactivates speedometer and odometer. My guess is that everything uses the same wheel speed sensor.
  20. WoodWorks
    WoodWorks House Ape
    Feb 11, 2003
    3,012
    Ashland, OR, USA
    No, the turn signal relocation was part of the “tail tidy” swap I did. I got mine from Rally Raid.
