BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. WayneC
    WayneC Long timer
    Oct 3, 2008
    5,117
    Sydney, Australia
    On the GS the water ingress into the snorkel is bad & there was also a recall on the GS OEM paper filter due to collapse & failure to seal
    Using the Unifilter & the US made K&P Stainless Steel washable oil filter I have no reliance on BMW consumables for servicing
  2. waylongway
    waylongway madmax Supporter
    Dec 16, 2009
    3,992
    NorCal
    Look at the air flow graph ( middle on the right)
    Snake Oiler likes this.
  3. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    1,814
    Герма́ния
    Why do people insist on mounting the spring in the Unifilter anyway ? It makes it more prone to damage fitting it/taking it out for cleaning the filter.
    The Twin Air filter is also of the inverted sock type and does not use a spring. It doesn't need one as it (and the Uni one) is not prone to collapse.
  4. advFord
    advFord Long timer
    Jan 16, 2012
    1,070
    Orange County, CA
    I regret asking about the uni filter
    Powershouse likes this.
  5. Gravel Seeker
    Gravel Seeker Old, growing older.
    Apr 27, 2002
    8,653
    Dreary old Norway, dreaming of adventures past
    :photog:lol3
  6. Gravel Seeker
    Apr 27, 2002
    8,653
    If they've (UNI) put in the R&D and concluded the spring is the best solution....I'm not saying (general) you're arrogant if you don't use it, but the performance numbers of the UNI filter might not be applicable anymore.
  7. Gravel Seeker
    Apr 27, 2002
    8,653
    I should add that my experience comes from the GS, so I tend to picture my own air box, filter and snorkel when thinking of air filters and not particularly familiar with the x airbox.
    I use a K&N myself. Bought it in 2005. Had some dust on the inside of the air box a few times, so don't think it's a very good filter, but it up'd the torque of the engine....well...that might've been the Staintune exhaust too as I did both those mods at the same time before doing a DYNO run. Using the foam block in it now and hope that helps a little.
    The UNI filters were just too expensive for me taking shipping into account even when @Aquatic had stocked a small fortune worth.
  8. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    3,580
    Pennsylvania, but living in a toy hauler full-time
    That seems like a good choice in my book.
  9. Sugra
    Sugra Been here awhile Supporter
    Mar 2, 2012
    170
    Jemez Mountains
    eBay. If you search for X Challenge parts you're not going to get many returns. The set I bought were listed for a 2016 F800/F800R. The stalks are slightly shorter than the originals but otherwise identical. Paid $45 for the pair.
    DoubleM likes this.
  10. advFord
    advFord Long timer
    Jan 16, 2012
    1,070
    Orange County, CA
    8DF92E95-9C6C-4987-9D62-14B9FF264F37.jpeg 58FCEBBE-BA8E-46B2-90AF-29F18C0A1B64.jpeg I’m one of the few odd balls that has the stock air shock. The pump is leaking air from the gauge. I can remove the gauge from the pump and it works fine. Is there an o ring or a seal that is missing?
  11. Kiharaikido
    Kiharaikido Long timer Supporter
    Dec 22, 2016
    1,058
    You did your entire trip on the original air shock? I missed that on your ride report.
  12. advFord
    advFord Long timer
    Jan 16, 2012
    1,070
    Orange County, CA
    The choice was easy.. replace the shock or spend an extra month traveling in south america. Plus I've never ridden anything else so I don't have anything to compare it to.
    I'm now in the market for a used replacement. Hyperpro or other. But would also like to get this gauge working again in the short term.
  13. Dutchgit
    Jun 24, 2012
    1,814
    Герма́ния
    It looks like there should be an o-ring in there.
    advFord likes this.
  14. gnarlynate24
    gnarlynate24 Live, love and ride on :D
    Feb 2, 2017
    144
    Oklahoma City
    I would recommend anything but hyperpro with this point is I have blown mine up three times in the last 9 months of travelling. however I do think it would be an improvement over the air shock
    advFord likes this.
  15. NZSpokes
    NZSpokes Been here awhile
    Sep 13, 2017
    370
    Auckland New Zealand
    They are the same pump as a MTB shock pump. So if you cant fix it replacement is easy.
    jonnyc21, advFord and gnarlynate24 like this.
  16. Wyocrawler
    Wyocrawler Been here awhile
    Oct 25, 2013
    844
    Marietta ohio
    I think I might have one still. I’ll look this weekend
  17. NZSpokes
    Sep 13, 2017
    370
    Checked mine this morning. You are missing a oring.
    advFord likes this.
  18. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    3,739
    Boise aria
    Yes missing an o-ring, here should be a small one in there that the gauge side presses against when you tighten it.
    advFord likes this.
  19. snooker
    snooker AttitudeIsEverything
    Feb 19, 2010
    2,027
    Loveland, Colorado
    Just wanted to point out to the group, I recognize your name... Andrew is one of the original group posters on the XCountry thread, going back to when he purchased that bike in August 2008 !!! Too bad the pictures in your old posts are dead now... Andrew I remember reading your posts of the skid plate you were making, the first one I saw anyone make, (long before Scheffelmeier gave us choices). And your videos of jumping the bike over little berms really got me going until I ended up buying mine in March 2010 (but it took me 2 shocks later until I found one that could actually be jumped!).
    Anyhow, I respect your history and wisdom on the X and welcome back. Mine is totaled and still sitting under a tarp on a trailer in my yard, but like I've said I will still keep my website up, though I will not be owning the X again, more than likely. So everybody respect your X "elders", and Andrew is one of them!
  20. MolonLabe
    MolonLabe Adventurer
    Sep 13, 2019
    19
    North Nevada
    Ok, dont see any advice on rear brake pedal replacements. Anybody?
