BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. andrewgore
    andrewgore Gôremā
    May 5, 2008
    18,820
    brrrrrrlington
    Fresh fork rebuild & adjusted my steering stem (too tight, causing notchy feeling). Bike is 100x better. No more excess dive on braking and the bike will actually make line changes mid-turn. Now I just need some new tires, cause this Heidenau K60 rear tire is total garbage. Might wear like iron, but feels like my rear is on ice. :lol3
    Snake Oiler, Sparqq and advFord like this.
  2. MJS
    MJS Long timer
    Dec 23, 2005
    2,801
    Off the grid in San Felipe, Baja
    Notched feel in the steering usually means it's time for new steering head bearings. Since the steering head bearings never fully rotate the rollers wear in a small area. Loosening the stem is masking the problem and not in a good way. Even a tight bearing will be smooth if it's not worn. Not a hard job to do.
    advFord and andrewgore like this.
  3. andrewgore
    andrewgore Gôremā
    May 5, 2008
    18,820
    brrrrrrlington
    Yah, this was a temporary hold over until I get new parts. It's officially fall today, so my riding season is rapidly closing. Gotta get all the riding in that I can. :lol3
    gnarlynate24 likes this.
  4. Essjay
    Essjay Been here awhile
    Sep 24, 2004
    302
    Dublin, Ireland
    My XCountry has ABS. There's a brake line from the handle into a small box which I assume is something to do with the ABS (here's a photo of one on another thread - https://advrider.com/f/threads/g650x-challenge-how-to-bleed-the-front-brakes-with-abs.796605/). My brake line goes into the left banjo bolt. Coming from the right banjo bolt is some metal piping into a fat pipe (maybe 10-15mm in diameter) and then into more metal piping. The last piece of metal piping is connected to another braided brake hose and down to the caliper.
    Is there any reason that I shouldn't directly connect a new brake line into the right banjo bolt and bypass all the metal piping? Is that required for anything ABS related?
    Also off hand, does anyone know the banjo bolt sizes at the lever, the ABS "box" and the caliper? I want to get some new braided lines made up.
  5. MJS
    MJS Long timer
    Dec 23, 2005
    2,801
    That is simply a junction block for the lines. Lever to ABS unit for one line and ABS to caliper for the other. The metal piping to the rear goes to the ABS unit. IIRC, the caliper line includes some hard line to route the line around the plastic and triple clamp, no other function. Your custom line probably won't include the hard line so you'll have to figure out how to route and secure the lin but yes, you could run a flex line directly from the block to the caliper.
    Banjo bolts are 10mm 10x1.0 thread, a very common size.
    Btw, stock lines are steel braid reinforced so you won't gain much performance from an aftermarket replacement. If you're replacing a damaged line let me know. I've got a good used one you can have for the cost of shipping.
    gnarlynate24, Essjay and CapeMan like this.
  6. Essjay
    Sep 24, 2004
    302
    Dublin, Ireland
    Great information, thank you! Also thanks for your offer but but planning a complete new set of lines so will buy locally.
  7. Matt
    Matt Dirt Virgin
    Apr 11, 2007
    2,176
    Newtown,Sydney
    Thanks mate, that's what I plan to do - even more urgently after I was stranded today. Do you remember what you used to seal around the hole you drilled?
  8. Essjay
    Sep 24, 2004
    302
    Dublin, Ireland
    Does anyone have the part numbers of the KTM caliper support bracket which is needed to swap the front forks? I think it might be from a 950 SE. I did find a part number but cost is $150 which can't be correct.
  9. jjmead1
    jjmead1 now THAT"S a bike!
    Sep 8, 2010
    848
    don't boulder my Golden, CO
    some form of two part epoxy. it does leak when napping.
    Matt likes this.
  10. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    3,579
    Pennsylvania, but living in a toy hauler full-time
    I'll try to remember to look it up for you
  11. Gravel Seeker
    Gravel Seeker Old, growing older.
    Apr 27, 2002
    8,650
    Dreary old Norway, dreaming of adventures past
    WP forks? Single 300 disc on the left?
    I used 60113049100 on the WP 4357MXMA forks I used on my Dakar
    ".........With the forks on the bike and clearances sorted it was time to move on to fitting the wheel and brakes.
    First I ordered a caliper hanger from KTM so I could use the stock Brembo caliper. KTM use the same Brembo caliper on various models and on the 2004 950 they used the same WP4357 MXMA forks and the same size disc as well (300mm).
    From KTM for a 2004 950
    LEFT HAND caliper hanger and mounting screws (keep in mind the 950 has two discs so you need the left side hanger only)
    Qty....Part no...............Part. name
    1.......60113049100......BRAKE CALIPER SUPPORT FR. L/S
    2.......0015080353........HH COLLAR SCREW M 8X35 WS=10"
    Kiharaikido and Snake Oiler like this.
  12. Essjay
    Sep 24, 2004
    302
    Dublin, Ireland
  13. Gravel Seeker
    Apr 27, 2002
    8,650
  14. Essjay
    Sep 24, 2004
    302
    Dublin, Ireland
    I spotted item 254363987930 on eBay (950 990 Adventure Left Caliper). Shipping to Europe expensive but might be my cheapest option.
    Edit: looking at the photos, I think that's a right hand side caliper.
  15. WayneC
    WayneC Long timer
    Oct 3, 2008
    5,116
    Sydney, Australia
    The caliper hangers used on the KTM WP forks are actually a Brembo part & WP were smart in that the 4860 & 4357 forks are designed to use the same caliper hanger.
  16. Powershouse
    Powershouse Flower Sniffer Supporter
    Jul 21, 2006
    2,479
    Minn-knee-sooo-taaa
    New fork seals and putting everything back together. I can’t remember whether the washers for the bolts to fasten the caliper to the fork go under the head of the bolt for between the caliper in the fork. I looked at the parts diagram and shop manual but they really aren't clear. Any help would be appreciated.
    andrewgore likes this.
  17. NZSpokes
    NZSpokes Been here awhile
    Sep 13, 2017
    370
    Auckland New Zealand
    Guessing the little rust marks are the start of a problem. Or is it flux? 20190927_170547.jpg 20190927_170604.jpg
    But if you want to get rid of the ABS light, simple. Its inside a tube, just stuff a rag down on it.
  18. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    1,814
    Герма́ния
    I'd take a magnifying glass to check out the circuit board. I seem to remember seeing faint green traces on mine.
  19. NZSpokes
    Sep 13, 2017
    370
    Great idea. Did that and couldnt find any.
    Dutchgit likes this.
  20. Essjay
    Sep 24, 2004
    302
    Dublin, Ireland
    Does anyone know the height differences between the rear shock on the XCountry and XChallenge? In other words, if I put an XChallenge Hyperpro or Wilbers rear shock on my XCountry, how much would it raise the saddle?
