1. eNewsletter Sign Up
BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. Fasco
    Fasco Adventurer
    Jul 25, 2014
    52
    Northern Italy
    I am also preparing the bike for a big trip. My X has done 50k km and never experienced any water pump failures.... I wanted to replace it as preventive maintenance. I know it's a big job.
    I was thinking of getting part #6 and part #5. Do I also need part #7 #8 #9 ? Any particular thing to keep in mind while doing the job?
    thanks!
  2. rlloyd
    rlloyd Adventurer
    Mar 15, 2016
    89
    Durham, NC
    My gas cap is getting really cranky about giving me my key back, which lead to several dicey moments on a recent road trip. Next time I'll carry a spare key in case it fails to relinquish it, but does anyone have a replacement gas cap that doesn't use a key? I have two gallons of gas in my aux tank most of the time and could care less about the risk of having my gas stolen..
  3. rlloyd
    rlloyd Adventurer
    Mar 15, 2016
    89
    Durham, NC
    Shot of my bike on the trip as preemptive repayment for your sage gas cap advice..
    Bebbs800 and Looksgoodinblack like this.
  4. Looksgoodinblack
    Looksgoodinblack Long timer
    Apr 22, 2009
    3,440
    Putnam County, NY
    There was a cap form Touratech available
  5. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    4,884
    Mesa, AZ
    Just buy the water pump kit from BMW, it has all the parts you need.
    waylongway and Snake Oiler like this.
  6. NZSpokes
    NZSpokes Been here awhile
    Sep 13, 2017
    398
    Auckland New Zealand
    Stromius, gnarlynate24 and CapeMan like this.
  7. NZSpokes
    Sep 13, 2017
    398
    I have a TT one. But hard to get.
    Try some graphite powder in you lock. Will probably fix it.
    Cruz likes this.
  8. NZSpokes
    Sep 13, 2017
    398
    Project new dash is coming along well. Its going to be kinda plug and play. Will do more information once I have it working.
  9. gnarlynate24
    gnarlynate24 Live, love and ride on :D
    Feb 2, 2017
    144
    Oklahoma City
    I had my key break off down in Mexico because some dirt had made its way into the locking mechanism.
    Luckily I had a spare key!I use some gasoline from the gas station to clean out the keyhole and then sprayed some WD40 in there for lubrication and have not had an issue in the last 5 months.
  10. Gravel Seeker
    Gravel Seeker Old, growing older.
    Apr 27, 2002
    8,799
    Dreary old Norway, dreaming of adventures past
    #5 is a reusable rubber gasket, no need to replace (just clean), but I'd get a new main clutch cover gasket as it can tear when you take the cover off.
    The kit tbarstow refers to is #6. You just reuse the other parts from the old shaft.
  11. Essjay
    Essjay Been here awhile
    Sep 24, 2004
    302
    Dublin, Ireland
    Can anyone tell me how long the front brake line is on the XChallenge from the junction box to the caliper? I want to put a similar line on my XCountry. Thanks.
  12. bensgone
    bensgone Been here awhile
    Nov 4, 2009
    611
    nw oregon
    Can anyone direct me toward the correct bleeding procedure for the bikes with ABS? I have replaced the front line on my 07 xmoto but can't get it to cooperate.
  13. miniboxer
    miniboxer Been here awhile
    Jan 15, 2011
    103
    Hi bensgone,
    just change the brake fluid as with old bikes. Make a test-ride and brake hard, so the ABS (front and rear!) is working. This way the whole system pumps the brake fluid through. You only have to shorten the intervall, because the mixed old and new brake fluid gets old quicker.
  14. andrewgore
    andrewgore Gôremā
    May 5, 2008
    18,209
    brrrrrrlington
    http://f650.com/forum/showthread.php?12364-Xc-Brake-Bleeding-(ABS)
    Bleeding brake is same as a normal one, but first you bleed a little valve inside the master cylinder, then proceed with bleeding front brake. Goes pretty quick assuming no leaks\issues in your system. :thumb
  15. MJS
    MJS Long timer
    Dec 23, 2005
    2,826
    Off the grid in San Felipe, Baja
    On the X-Ch, the line runs from the block up to a special pass-through banjo bolt on the MC and then down to the caliper. The double banjo bolt on the MC provides a mounting point for the brake line to run in a conventional dirt bike routing down the forks. There is no fluid exchange between the two lines on the MC.
    You should try and get a good look at a X-Ch to see the line route so you have an idea of what's needed. I'm going by memory since I removed the abs and did custom lines on both my X-Ch and my wife's X-Country.
  16. bensgone
    Nov 4, 2009
    611
    nw oregon
    Thanks for the input! I'm shipping this to my sailor stationed away and want to get all the issues resolved.
  17. Essjay
    Sep 24, 2004
    302
    Dublin, Ireland
    Understood. I know about the mounting point but I was going to bypass that completely. Box to caliper and maybe a cable tie to the line from MC to box.
  18. Looksgoodinblack
    Apr 22, 2009
    3,440
    Putnam County, NY
    bensgone likes this.
  19. gnarlynate24
    Feb 2, 2017
    144
    Oklahoma City
    X'ers I finally figured out how to toggle the anti-lock brake system on & off! After the last 1,300 miles of OPS checking on and off the road here in Ukraine I can report back she works like a charm!
    I cut the front wheel ABS sensor wire right after it enters the quick disconnect under the air box. Then wired in a kill switch on my handlebars This throws a fault code for the anti-lock brake system which causes the bikes computer to disable the ABS immediately. It shows a solid red ABS light the moment you flick the switch
    You can now turn off the ABS while moving! The real reason I did this is to keep the abs off when doing a dirt day. This way you don't have to press the red button on the left side handlebar every time you start the bike. Braaap braaaaaaaaaaap 20191003_123054.jpg 20191012_154224.jpg
  20. MolonLabe
    MolonLabe Adventurer
    Sep 13, 2019
    23
    North Nevada
    Okay: Most likely culprit?
    Even when warm, bike has hard time starting. Gets going, but bogs occasionally. Feels like starving for fuel. Changed sparks and they look solid:
    1. Fuel Filter?
    2. Fuel pump?
    Is the Mahle the go-to replacement? Is the ebay fuel pump kit kosher?
    Incidentally, the Airbox dumped out like a half cup of oil. Is it acting as a catch-can?
    CoatsEast likes this.
