BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. CapeMan
    CapeMan Dirt Duffer Supporter
    Sep 29, 2012
    416
    Prescott, AZ
    G'day folks -
    Well, the time has come for me to bid a fond adieu to the X Challenge thread. Not that I'm unhappy with my X Ch as I just had a fine ride across northern Arizona and southern Utah a couple of weeks ago with Snake Oiler and another rider. But as I get well into my mid 70's, arthritis has been doing a job on my hands so I reckoned I'd best bow out while I'm still smiling.
    So I sold my X Ch. to another, local inmate last week - @4play - who was the fellow that first got me thinking about the X Challenge 6 years ago or so. He's an excellent rider with broad experience and a fine wrench-twiddler as well, so I expect he'll be a net positive addition to the thread in time.
    I'll keep on riding as long as I can, just recently bought a Honda NC750X DCT (the one with the dual clutch "auto tranny") but will concentrate more on slab and well-groomed gravel and forest circus roads. This way, at least my left hand is just along for the ride!
    Good luck to y'all.
  2. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    1,814
    Герма́ния
    Have fun with the Honda Capeman !
    Thanks for being part of the group and do stop by whenever you want !
    Cheers, Ard
    BTW, I got a a few Hondas myself but only one of them is not a bike. It's a HRX 537 ;-)
    CoatsEast, eaglescan and CapeMan like this.
  3. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    7,266
    I'm looking at part numbers and RR is sh532B-12 the same as used in F800GS/650GS and it is rated at 35A.. also stator the same as on 650GS(??) So appears flywheel is all you need?
  4. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    3,590
    Pennsylvania, but living in a toy hauler full-time
    Sorry to see you go @CapeMan . It was a pleasure to meet you in person after our many chats. The master planner you are I found out after the ride you put together. Thanks isn't enough. Your not the best I have to give that award to Mrs Capeman. :-)
    Hopefully we can get together for another visit and see the country side in your area again.
    Don't be a stranger and check in once in a while to keep the youngsters in order.
  5. MJS
    MJS Long timer
    Dec 23, 2005
    2,802
    Off the grid in San Felipe, Baja
    I never checked part numbers except for the RR when I did my conversion. I had F650GS engine that l pulled the parts from for one bike and used fleabay for parts for the second bike. I seem to recall there was a difference in appearance between the two stators (F vs X). I originally changed the stator only but did not see an increase in overall output but did see some change in performance (rpm vs voltage). The F flywheel is deeper and I'm pretty sure the stator is also to take advantage of this and get more output.
    It's been a few years since I did this so my memory might be off. I also upgraded to a mosfet RR and have not had any regrets. After trying a number of LED headlight bulbs with poor results, I went back to halogen. Even running two 65 watt projector headlights I have plenty of electrical power for accessories.
    cyclopathic likes this.
  6. eaglescan
    eaglescan Borrego rocks Supporter
    Jun 17, 2009
    588
    Langley,B C
    Thanks to Capeman for his wisdom, all the best. Now I need help, was checking the valves, within specs. so I closed it up.
    Hit the e start, won't fire up. As i was putting the Battery back in, I always have to do the NEG first because of the short POS wire,,, As I put the POS wire on the term. the dash lit up for an instant. It that normal ?
    I wonder if it affected the ECU? thanks
  7. Dutchgit
    Jun 24, 2012
    1,814
    Герма́ния
    Normal, it would do it too if you were able to connect the negative side last.
    eaglescan likes this.
  8. jjmead1
    jjmead1 now THAT"S a bike!
    Sep 8, 2010
    848
    don't boulder my Golden, CO
    Hey. Lost a key this way. Took apart cap and used dry lube in the mechanism. Graphite. I now do this every oil change. No issues since.
    rlloyd, cyclopathic and gnarlynate24 like this.
  9. NZSpokes
    NZSpokes Been here awhile
    Sep 13, 2017
    370
    Auckland New Zealand
    Good on ya for keeping it going as long as you can. I too suffer the same and am due for surgery on my left hand.
    A DCT Africa could be on the cards if it gets much worse.
    You are not allowed to leave by the way....
    waylongway, CoatsEast and Snake Oiler like this.
  10. eaglescan
    Jun 17, 2009
    588
    Langley,B C
    My bike is fixed, I had loosened the sprocket on the intake cam, and when tightening it back up, I didn't noticed the cam had moved. It is a very short dowel it sits on. I got away this time!
    CoatsEast, Dutchgit and Gravel Seeker like this.
  11. Dutchgit
    Jun 24, 2012
    1,814
    Герма́ния
    You never need to loosen/take off the intake sprockets to adjust the valves.
    What is needed though is blocking the crank with a M8 pointed tip bolt. This allows you to line up the timing marks on the cams without worrying about the crank rotating.
    You do also need to push in the tensioner (or take it out which is a lot of work)
  12. eaglescan
    Jun 17, 2009
    588
    Langley,B C
    I made a bolt to lock the crank, but pushing back the chain tension-er is the challenge. I made a wooden wedge that worked last time, but want something better for next. So you are saying , just tip the cam with sprocket on ,after the chain is backed off?
  13. Dutchgit
    Jun 24, 2012
    1,814
    Герма́ния
    Yep, that's what I do. It's easier and I seem to remember it was described that way in one or other workshop manual years back.
  14. rockydog
    rockydog just a guy
    Feb 11, 2007
    1,237
    okieland
    word to the wise...last spring the connector to the throttle position sensor was crimped badly cause the wire out of the loom was routed wrong, i think at the factory. dealer resoldered and routed it correctly. got it home and same symptoms. more rough running-missing episodes and took it back to the dealer, both times showed no faults on my gs-911. got it home again and it barely ran, wtf? took it to another dealer and left it for 3 months while traveling, asked the tech to test drive it a bunch. pick up the bike and the problem was a loose and corroded negative terminal. duh. which i had never checked cause it's a pita to do but the first thing i always do-check the battery terminals. right. runs like a top and i feel a little dumb.
    Dutchgit, CoatsEast, Bebbs800 and 4 others like this.
  15. Dutchgit
    Jun 24, 2012
    1,814
    Герма́ния
    Sometimes the negative lead on the right side of the engine (sorta below/behind the rectifier) is loose too.
    rockydog, eaglescan and Snake Oiler like this.
  16. dunc
    dunc Coddiwompler Supporter
    Dec 26, 2010
    3,899
    NSW
    would a tank like this
    go onto 1 of these or not
    the seat would be changed also from the look of it
    anyone tried or done it ???????
  17. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    4,801
    Mesa, AZ
    People have done it, just depends on how much money you want to spend. Many parts you may not be able to replace or find.
  18. dunc
    Dec 26, 2010
    3,899
    NSW
    ok thought it may have been just a seat and get the tank
    thanks for that
  19. Dutchgit
    Jun 24, 2012
    1,814
    Герма́ния
    I'd get something (made up) like the X-tank. Why would you want a bike that's heavier on the front than it needs to be ?
    You could make a rack for the right side for a 1.75 Gallon Rotopax. Plumb that in to the vent of the main tank and there you go!
    Meriden likes this.
  20. NZSpokes
    Sep 13, 2017
    370
    There would be a bit that needs changing. Those crash bars for a start.
