BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. 84ceejay
    84ceejay Been here awhile Supporter
    Nov 2, 2014
    117
    Who Knows?
    I like the way you think cpallen. Trying to figure out which way to go on the sprocket, any suggestions? The one that was on there was a 14 tooth.
  2. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    2,001
    Герма́ния
    Looks like someone mounted the wrong sprocket. It has happened before.
    Welding one on is possible and the quickest and cheapest solution.
    You can also fit the shaft of a 650 GS (single cylinder) bike. Those can be had used on Ebay for a lot less money.
    eaglescan likes this.
  3. MJS
    MJS Long timer
    Dec 23, 2005
    2,891
    Off the grid in San Felipe, Baja
    "Looks like someone mounted the sprocket without grease. "
    Fixed
  4. 84ceejay
    Nov 2, 2014
    117
    Who Knows?
    Yeah, definitely no grease at all.
  5. cpallen
    cpallen Nearly Adventurer
    May 26, 2003
    1,896
    Panora, IA
    I’m going to add checking mine to my pm tasks. My bike also has an aftermarket 14 tooth sprocket on it.
  6. Sparqq
    Sparqq Been here awhile
    May 25, 2011
    406
    Amsterdam -> Hong Kong
  7. Gravel Seeker
    Gravel Seeker Old, growing older.
    Apr 27, 2002
    9,582
    Dreary old Norway, dreaming of adventures past
    -- WARNING --
    That's not entirely accurate;
    A new replacement now is the same across all years, but as you can see from the fische, the part you link to superseeds the old ones.
    The old ones (mine among them) have a huge ass nut on the outside of the shaft to secure the sprocket rather than the internal bolt like on the current shaft. Nothing wrong with that shaft really other than carrying the tools to remove it on the road takes alot of room (27mm I think it is).
    So before buying the first shaft/ engine you come across check which shaft it is.
    Supersedes:
    23007663805
    (09/11/2000 — 09/15/2006)
    Pics from internet
  8. 84ceejay
    Nov 2, 2014
    117
    Who Knows?
    Same size as the axle nuts?
  9. Sparqq
    May 25, 2011
    406
    Different, size 30
  10. eaglescan
    eaglescan Borrego rocks Supporter
    Jun 17, 2009
    708
    Langley,B C
    If it was me, I would try and see if a new sprocket will go on the old shaft and have any grip at all. If yes , then it could be welded on, suggest tig . Next thing is to make a large washer to suit and drill about 4 holes , (start small, like 3/16 , in that around the perimeter that clear the bolt head. The sprocket may be soft enough to allow drilling , using the washer holes as a guide. I would then use roll pins to help drive the sprocket along with the weld. I will try drilling a used sprocket I have to see how soft it is.
    OK, forget the drill idea, but if the washer is thick enough, say 1/4 ", you could weld around the perimeter to the sprocket. After welding sprocket to shaft, install the washer , and tighten bolt. Now weld around the washer to sprocket and around the bolt head to the washer. Yes this means grinding weld away when removing , but could be done.
    Of course this is not for a bike that is going on long adventures.
    84ceejay likes this.
  11. Sparqq
    May 25, 2011
    406
    Welding a sprocket onto it won't be easy without melting that seal. If that happens you have to grind the sprocket of it, to replace the seal. I would go for an older (cheaper) countershaft and accept the size 30 nut and spend some winter weekends on splitting the engine.
    cyclopathic likes this.
  12. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    8,134
    In addition I would look around for machine shop which could do repairs either weld on and cut splines or cut shaft and weld replacement.
  13. Sparqq
    May 25, 2011
    406
    It seems a Chinese guy is selling them for about $175 used and $350 new:
  14. Gravel Seeker
    Apr 27, 2002
    9,582
    Actually, come to think of it you're correct - it is a 30mm nut. Internally the nut is an M20x1.5.
    (It's my KTM steering stem nut that is 27mm)
  15. Sparqq
    May 25, 2011
    406
    The bolt (25) on the sprocket requires socket size 30. The axle bolts on my F650GS require socket 19 and 24 if I remember correctly, for sure it's not a size 30.
  16. Gravel Seeker
    Apr 27, 2002
    9,582
    I know, but this is the G650X thread and that might :lol3
    Our axles are 17mm, theirs are 24 or 26 or something fancy like that.
    Sparqq likes this.
  17. OzAnt
    OzAnt Still searching
    Mar 12, 2010
    305
    Sandgroper Central, WA, Australia
    Ok been there and done that with the striped counter shaft sprocket.
    You start by sticking the bike in a crane and removing the back wheel and move forward until you are left with the front frame member and front end intact. I was luck to get hold of a hospital patient crane to work on my bike, worked really well.
    The motor is relatively easy to do with the manual and a few you tube videos.
    Have lots of part trays and zip lock bags and tape to mark up all the fittings, connection and parts for reassembly
    Get the parts before hand with new seal kits and water pump kit while you are in there. I end up using OEM parts as I got trade prices for the parts.
    Set aside 1 day to get the motor out, 1 day to strip motor, 1 day to assemble motor and 1 day to install motor, you can do it quicker but then you risk dong something wrong.
    My bolt would not come out, end up using a 3/4" drive rattle gun and that moved it. Problem is some people use the nut torque on the bolt instead of the bolt torque which is about 1/3 of the nut so it makes it really hard to get the bolt out. You can stick in the crank lock bolt to help hold the motor to undo the bolt on the counter shaft. You can make these yourself, some post on ADV ride about doing the motor show you how.
    It is not that hard a job if you prepare yourself well for the task.
    Some good write ups on ADV rider to do the work as well.
    https://advrider.com/f/threads/ocr-...ck-august-13-14.1082462/page-42#post-30765053
    Some pics of mine and a few words.
    cyclopathic, eaglescan and Sparqq like this.
  18. Gravel Seeker
    Apr 27, 2002
    9,582
    Not sure exactly which bolt you mean since you don't specify, but (general) you might try to loosen the bolt at the very beginning when you still have the wheel on. Depress brake to lock rear wheel = "lock" engine. Once it's loose continue with your steps.
  19. cpallen
    May 26, 2003
    1,896
    Panora, IA
    He is talking about the fastener on the end of the countershaft that secures the sprocket. In early models, apparently it is a big 30mm nut on external threads and in later models a bolt in a threaded hole,
    Sparqq likes this.
  20. eaglescan
    Jun 17, 2009
    708
    Langley,B C
    And it is a RIGHT HAND thread ( normal) , I just pulled my sprocket and greased. I guess the grease is to prevent rusting, which would cause more wear?
