BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. eaglescan
    eaglescan Borrego rocks Supporter
    Jun 17, 2009
    688
    Langley,B C
    Thanks Matt , for sharing that link.
  2. cpallen
    cpallen Nearly Adventurer
    May 26, 2003
    1,884
    Panora, IA
    Also check and make sure the cap is maintaining adequate pressure in the radiator and that you have a proper 50/50 mix of antifreeze and water.
  3. cpallen
    May 26, 2003
    1,884
    Panora, IA
    The same bolts are used to fasten the cover on the rear wheel speed sensor.
  4. Wyocrawler
    Wyocrawler Been here awhile
    Oct 25, 2013
    909
    Marietta ohio
    Just modded the KTM axle nuts. Ground off the flange and then drilled drain holes in the cap so water won’t collect in the axle.
  5. Wyocrawler
    Oct 25, 2013
    909
    Marietta ohio
    I was taking a break from wiring up the bike.
  6. Wyocrawler
    Oct 25, 2013
    909
    Marietta ohio
    Few more pictures of the tower, wiring, and gauge cluster on the mount I fabbed up.
  7. Wyocrawler
    Oct 25, 2013
    909
    Marietta ohio
    Quick release windscreen mounts. Made these from 5/16 clevis pins, rubber grommets and hitch pins.
    Holds the screen nice and tight and comes off with no tools.
  8. hansi
    hansi Teurer Abenteurer Supporter
    Jan 1, 2010
    1,169
    State of Jefferson
    Nice work!
  9. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    4,114
    Pennsylvania, but living in a toy hauler full-time
    Don't worry I will not tell anyone it's twisted a tad. Mom's the word.
  10. Wyocrawler
    Oct 25, 2013
    909
    Marietta ohio
    Uhm. You just did. Ass lol
  11. Snake Oiler
    Apr 22, 2016
    4,114
    No one pays attention to me. Don't worry
    Gravel Seeker likes this.
  12. waylongway
    waylongway madmax Supporter
    Dec 16, 2009
    4,141
    NorCal
    :dirtdog......:thwak.....:nono
    hansi likes this.
  13. Snake Oiler
    Apr 22, 2016
    4,114
    I knew it really bothers him once I noticed it. So I figured that he had worked it out by now. I don't think it's a big deal either way. Barely noticeable. Once it takes a nap or two it will be different anyhow.
  14. Wyocrawler
    Oct 25, 2013
    909
    Marietta ohio
    Yep. It’s fixed.
    eaglescan, Snake Oiler and waylongway like this.
  15. Gedrog
    Gedrog 1000 mile stare a 1000 stories to tell
    Oct 20, 2013
    3,305
    Lost in the Sahara
  16. seasider
    seasider Just a rider Supporter
    Oct 27, 2007
    1,120
    Virginia
    Who is the best source for a replacement clutch cable for the X Challenge? Engine/radiator protection bars?
    Thx
  17. waylongway
    Dec 16, 2009
    4,141
    NorCal
    eaglescan and Snake Oiler like this.
  18. seasider
    Oct 27, 2007
    1,120
    Virginia
    Thanks on the cable, Shows as universal as far as as I can tell. Anyone else use this?
  19. waylongway
    Dec 16, 2009
    4,141
    NorCal
    It gives you all the parts and then some ...YOU need to put it together...
    The Venhill Universal Clutch Cable Kit is a high-quality, "build-your-own" cable kit suitable for generally any motorcycle clutch application.
    The wire is galvanized steel for long life and easy soldering.
    One end of the inner wire is fitted with a barrel nipple (nominally 6mm dia x 10mm). The opposite end will need to be cut to length and the required nipple soldered into place. The ferrules and adjusters are a snug fit. They may be bonded into place if preferred, or you can use a center punch to make a small indention in the side. You will need a basic soldering kit and basic soldering skills to solder the nipple into place.
  20. MJS
    MJS Long timer
    Dec 23, 2005
    2,864
    Off the grid in San Felipe, Baja
    The cable from a husky 650 terra will fit and is a bit longer than the X cable.
    Dutchgit and DGR like this.
