1. eNewsletter Sign Up
BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. seasider
    seasider Just a rider Supporter
    Oct 27, 2007
    1,104
    Virginia
    Thanks. I will see what the reality of availability is when I try to pay! :-)
    Just did it and it looks like a bit of a wait......we'll see
  2. andrewgore
    andrewgore Gôremā
    May 5, 2008
    18,199
    brrrrrrlington
    Fresh tires scooped up & spooned on my xMoto.
    Gonna be nice not having the crappy heidenau on the back anymore.
    I also got some ODI Rogue V2 lock-on grips. There's a cam that matches the stock pretty well. It still seems my throttle is quite a bit heavier than it should be. Should I just go ahead and get a new throttle cable on order, or anything else I can try to make it more light n snappy like my KTM 350.
  3. eaglescan
    eaglescan Borrego rocks Supporter
    Jun 17, 2009
    612
    Langley,B C
    Just thought about what might happen if the spring broke, gas may be wide open, not good.
  4. Wyocrawler
    Wyocrawler Been here awhile
    Oct 25, 2013
    857
    Marietta ohio
    Just about got her done.
    TobyG, blaster11, DGR and 6 others like this.
  5. hansi
    hansi Teurer Abenteurer Supporter
    Jan 1, 2010
    1,109
    State of Jefferson
    Wyocrawler likes this.
  6. waylongway
    waylongway madmax Supporter
    Dec 16, 2009
    4,044
    NorCal
    Looks Great...! Nice job. These things are a LOT of work and not to be taken on by the faint of heart...:fpalm....:pope....:stupid
  7. andrewgore
    andrewgore Gôremā
    May 5, 2008
    18,199
    brrrrrrlington
    What bags do you run with the dirtbagz rack you have on your X? I couldn't get mine to work with any of the wolfman bags that I have. :dunno Looks great though. :thumb
  8. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    3,715
    Pennsylvania, but living in a toy hauler full-time
    I believe he's running Dirt Bags now. He switch's back and forth with a couple he's tried off eBay tho too
    andrewgore likes this.
  9. rryd
    rryd Adventurer
    Jan 26, 2012
    36
    Arendal, South Norway
    Hi.
    I’m looking for some Bi-Xenon to my TT fairing.
    I have oe Hella (Halogen low beam and Xenon high beam)
    Any idea what I can use who have better light output than oe Hella and is dustproof?
    DGR likes this.
  10. Wyocrawler
    Oct 25, 2013
    857
    Marietta ohio
    I use dirtbagz rangers with a 10 or 20 litter Kreiga US depending on how much crap I want to carry.
    I’ve tried several different bags and I haven’t found any that work as well for me as what I’m using now.
  11. andrewgore
    andrewgore Gôremā
    May 5, 2008
    18,199
    brrrrrrlington
    Mines finally ready to go......although I pulled the racks off.
    DGR likes this.
  12. seasider
    Oct 27, 2007
    1,104
    Virginia
    So I have tried to read up on batteries for the x including snooks page. Given today's tech vs a few years back what battery would be most reliable in the long run with this bike and sensitivity to voltage minimums?
    I don't run more than heated gloves and stock lighting. I like the idea of the lithium ion for weight but not a must.
    Certainly not looking to turn this into an "oil thread" but I do need a battery and appreciate the guidance.
  13. Wyocrawler
    Oct 25, 2013
    857
    Marietta ohio
    I needed a battery last year in a hurry. Did a little research and found out Walmart AMG batteries are made by Johnson controls. It’s been really good for $60. No problems so far a year in.
    CoatsEast likes this.
  14. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    1,838
    Герма́ния
    I got the Hella Module 60 for low beam and it does a good job as far as I am concerned. You can fit a Xenon to that but you might opt for an LED bulb as it's a projector style light. It's dust proof too for it not being a permanently sealed unit.
    I tend to go for the cheapest Gel battery I can find. That has worked well for me in the last 7 or 8 years. (2 batteries so far)
  15. Wyocrawler
    Oct 25, 2013
    857
    Marietta ohio
    I have a plug and play LED light kit from Brittania Composites. Hella housing with cyclops led bulb for the low and Baja squadron pro for high. Really great kit.
  16. Wyocrawler
    Oct 25, 2013
    857
    Marietta ohio
    Gravel Seeker and blaster11 like this.
  17. Gedrog
    Gedrog 1000 mile stare a 1000 stories to tell
    Oct 20, 2013
    2,930
    Lost in the Sahara
    https://dakarparts.com/en_US/p/CFX-Rally-Highlights-2018-street-legal-set-Low-High-Beam/111 also has a video for comparison
    KTM/Hella part numbers:
    - High Beam: 76414001000
    - Low Beam: 76214002000
    These are the same units Hella part numbers US chaps look around I have seen these for as low as $76
    $100 each with or without frame from here
    Low Beam w/o Mounting Frame - 998670021 https://www.ecstuning.com/Search/SiteSearch/998670021/
    High Beam w/o Mounting Frame- 998670031 https://www.ecstuning.com/Search/SiteSearch/998670031/
    Low Beam w/ Mounting Frame - 998670041 https://www.ecstuning.com/Search/SiteSearch/998670041/
    High Beam w Mounting Frame- 998670051 https://www.ecstuning.com/Search/SiteSearch/998670051/
    Product Highlights
    With the new CFX Rally Modul 60 LED, is introducing an ultra-compact headlamp that achieves a high light output despite its size. A specially developed lens system concentrates the light and distributes it to the range of operation.
    Technical information
    • Light function: Low Beam & High Beam
    • Homologation: Premium Version:
    SOP: October 2017
    - ECE R113-D
    - FMVSS108 motorcycle.dot (with LB and HB in combination) Standard Version: ECE R113-B, SAE J 1623,
    • Power consumption: ~16 Watt
    • Operating voltage: 12V (9-16V)
    • Type approval: ECE-R10
    • Integrated HB3 Connector
  18. redape53
    redape53 WetSump’d
    Apr 2, 2009
    63
    New Mexico, USA
    Seaside, Did the same research as you. Having had AGM’s on past bikes I trusted them. The one that came with the bike was 3-years old and I’d get pretty wide volt readings but this time I spent the extra for AntiGravity lithium (8-cell). I do want to emphasize weight reduction that the x-co has a good head start on already. Voltage has varied only a few tenths & always above 13v. Starts faster and hasn’t stalled.
  19. seasider
    Oct 27, 2007
    1,104
    Virginia
    Thanks redape. Leaning to the updated option over oem which has a 2 year warranty.
    I suppose the proper charger makes sense as well.
    Source for your set up?
  20. redape53
    redape53 WetSump’d
    Apr 2, 2009
    63
    New Mexico, USA
    Im just feeling my way thru the fog, but; I got battery off Amazon..$155. I also purchased a Battery Tender branded selectable between lead or lithium on amazon for $35. I find afterward that AntiGravity does not recommend selectable tenders. But I bet it works fine. Also the battery comes fully charged anyway & they HOLD A CHARGE! My voltmeter read 13.4v upon install.
