BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. Gedrog
    Gedrog 1000 mile stare a 1000 stories to tell
    Oct 20, 2013
    3,294
    Lost in the Sahara
    What did you do to improve them
  2. Gedrog
    Oct 20, 2013
    3,294
    Lost in the Sahara
  3. SDRiderX
    SDRiderX Adventurer Supporter
    Jul 1, 2015
    14
    Lower left corner
    Thanks for the great review and details on the fork swap. I have also purchased the ebay "WP" forks. Could you share the part number or reference for the KTM caliper adapter plate? I understand it is found on the KTM 950SE, but looking at the parts diagram it appears to be a two-piece unit?
  4. Gravel Seeker
    Gravel Seeker Old, growing older.
    Apr 27, 2002
    9,366
    Dreary old Norway, dreaming of adventures past
    I used 6011 3049 100 on my Dakar. I think you need the same part, but better doublecheck. The KTM 950 has two brake discs, so only needed the left side caliper hanger.
    Post #7 here
    From KTM for a 2004 950
    LEFT HAND caliper hanger and mounting screws (keep in mind the 950 has two discs so you need the left side hanger only)
    Qty....Part no...............Part. name
    1.......60113049100......BRAKE CALIPER SUPPORT FR. L/S
    2.......0015080353........HH COLLAR SCREW M 8X35 WS=10
    Snake Oiler and Ndarko like this.
  5. Gedrog
    Oct 20, 2013
    3,294
    Lost in the Sahara
  6. SDRiderX
    Jul 1, 2015
    14
    Lower left corner
    Excellent! Thank you, sir!
  7. Ndarko
    Ndarko MotoTrip
    Feb 11, 2012
    51
    Croatia
    Not to repeat, exactly what Gravel Seeker replied below your post.
    The part is 1 peice unit; and it's the same on many KTM bikes, including Husqvarnas.
  8. Ndarko
    Ndarko MotoTrip
    Feb 11, 2012
    51
    Croatia
    Went the easier way, I got that new set of forks :)
  9. Gedrog
    Oct 20, 2013
    3,294
    Lost in the Sahara
    Not sure I follow, did you buy a brand new set from KTM?
  10. gr8grins
    gr8grins Been here awhile Supporter
    Nov 6, 2011
    444
    PNW Dry
  11. snooker
    snooker AttitudeIsEverything
    Feb 19, 2010
    2,042
    Loveland, Colorado
    Checking in on you X guys every now and then.
    All this detailed sprocket talk brings back memories. I was definitely one who had a problem with my JT sprocket and vowed that was one part I would only by from BMW. I too ran JT's on many motorcycles without any problems, but not this time... LINKY
  12. waylongway
    waylongway madmax Supporter
    Dec 16, 2009
    4,137
    NorCal
  13. HooliganD
    HooliganD Been here awhile
    Jan 24, 2011
    299
    The Centre of it all...no, not Toronto
    FUDGE! Bent my bars in a low-speed get off. Of course I had to hit one of the only big rocks on the way down. What are you all running for bars? Looking to replace my stock bars and re-use my barkbusters.
    CoatsEast likes this.
  14. Bli55
    Bli55 -
    Mar 7, 2012
    625
    Russia, N56 E49.
  15. uski
    uski Been here awhile
    Mar 19, 2018
    168
    San Jose, CA, USA
  16. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    5,070
    Mesa, AZ
    They are the same for all of the G650X bikes. Check the Husqvarna 650 Terra as well. EBC makes a kit as well.
  17. Meriden
    Meriden Yea whatever
    Oct 26, 2010
    1,276
    In the garden behind the dacha
    Hope I don't start a fight here, but might want to change the oil first. I put some high end synthetic in my X and the clutch slipped any time I was on the throttle hard. It took a couple of changes before it stopped slipping completely. Just a thought if you're going to change the oil in your new bike anyway.
    m
  18. MirthfulThylacinator
    MirthfulThylacinator Tinker
    Feb 21, 2018
    597
    Tassie
    Any xchallenges in Tassie?
    I'm considering buying my mate's which doesn't get much use, around 6000km, excellent condition.
  19. Gravel Seeker
    Apr 27, 2002
    9,366
    Louis lists the same kit for both Xcountry and Xchallenge
    €60 for friction plates only, springs are like €12 and a complete set of friction and steel plates with springs start at €76
    https://www.louis.eu/artikel/trw-fr...0043800?list=51186e9cb3ac66f8b4ebf50401c42f5e
    gnarlynate24 likes this.
  20. Gravel Seeker
    Apr 27, 2002
    9,366
    High end ok, but was in MA, MA1 or MA2 rated? (Wet clutch compatible).
    ArcticRider likes this.
