1. ADVRIDER Print Magazine!
    We're doing two more print magazines this year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. Gravel Seeker
    Gravel Seeker Old, growing older.
    Apr 27, 2002
    10,788
    Dreary old Norway, dreaming of adventures past
    Maybe easier to remove the tank and rear frame instead of the engine from the frame though.
    The frame is attached to the head on the GS as well, but the rear frame attaches to the main frame, not the engine, so it stays on.
  2. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    9,463
    I just hope abs bleed isn't like on 1150; had to do it once in hotel parking lot on buddy's RT after his rear line burst. We spent a couple hours finding hydraulic shop but after he had line made and we put it on it took at least 4hr to get his brakes back. It had been many years but I think I still remember the sequence you have to run those 6 bleeders on the top of servo, plus the ones on the brakes to get them back.. german engineering at best lmao.
    As for dropping the bike on stock shifter have done it many times; sometimes many times a day, no leaks. I would imagine brake cleaner and gasket maker overnight would be the first before going any farther.
  3. cyclopathic
    Dec 23, 2007
    9,463
    I replaced mine as a precautionary measure when I got bike. It didn't leak and there was no lubricant between seals.
    They were normal black nitrile rubber seals and that's what I put back; the one on coolant side was alive and the one on oil side was wooden. I imagine wear is due to seals drying out and becoming hard.
    There was also a persistent rumor that later china black engines had better alignment and/or used better stainless steel shaft; don't know how much truth to this urban legend.
    manybike likes this.
  4. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    2,190
    Герма́ния
    Well, as I already wrote, it was a fault of my own. The gasket that goes between the engine halves was too long, so I cut it short, being flush with the deck where the jug sits. It must have moved down a little during putting it all back together and it leaked oil out, a fair amount actually so I had to do the whole process again to put another new gasket in. This time though, I had learned what my mistake was and only cut the excess off with the engine halves pressed together and bolted down.
    It was rather annoying but a lesson well learned I'll tell you :(:doh
    I think I remember you can't take the head off as it would collide with the front frame on the X.
    Gravel Seeker and cyclopathic like this.
  5. Gravel Seeker
    Apr 27, 2002
    10,788
    I just replaced with a kit from BMW before last season and can't recall the seals being different, but some have talked about using a Viton seal on the oil side.
    Two things to remember is leave a space between the seals for fluid(s) to escape the engine case instead of mixing with the other fluid and to pack the space with grease.
    Dutchgit, manybike and cyclopathic like this.
  6. cyclopathic
    Dec 23, 2007
    9,463
    Also grease engine facing seal. There is very little oil splash on it from inside even if it leaks the only way you find out if bike naps on left side long time.
    IMO really cheap bad design on Rotax account.. makes me wonder if Yamaha/Aprilia doesn't have bearing at pump as well in 655 sibling. Was it designed to accept a sealed bearing and they replaced it with seal down the road?
  7. manybike
    manybike Omnipresent Supporter
    Jan 3, 2010
    1,307
    North America
    Thanks for the info. I have owned 2 650GS's and never had an issue with it. One had 65k miles...just lucky maybe ? I have read where doing a coolant flush every year helps.
  8. manybike
    Jan 3, 2010
    1,307
    North America
    By the way, I did pull the trigger and bought the XC...now...I have to stop reading about all the things that can go wrong !!
    Still not selling my Versys 300x yet, different category but a damn good bike.
    Dutchgit and Snake Oiler like this.
  9. cyclopathic
    Dec 23, 2007
    9,463
    The friend of mine had it fixed several times in 60k he owned 650GS, once in Guatemala, and some owners state it is 20k maintenance item. I took time to make sure new seals were installed perpendicular so there would be no unnecessary side load. I'm guessing if seals are not aligned it will shorten lifespan.
    Nitrile seals are $4-5ea and blue Viton are not much more.. maybe I will try PVC next time.
  10. cyclopathic
    Dec 23, 2007
    9,463
    What kills that bike (VX 3) for me is alot of plastic and 5" suspension.. seriously considered several times.
  11. manybike
    Jan 3, 2010
    1,307
    North America
    Yep, budget suspension. It does gravel very well though, better than I thought it would. Plus, a 12k km valve check is required as they do tend to move. Some shops will charge over $800 to do this...yikes
  12. manybike
    Jan 3, 2010
    1,307
    North America
    My xc has a hyperpro shock with hydraulic preload. Looking at lowering by having spacers installed...unless...someone has a lowered shock who wants to trade. I live in Canada.
  13. manybike
    Jan 3, 2010
    1,307
    North America
    trying to find them in Aliexpress, do you have a link ?
  14. Dutchgit
    Jun 24, 2012
    2,190
    Герма́ния
    Find a good suspension shop in your area, they should be able to help you.
  15. manybike
    Jan 3, 2010
    1,307
    North America
    Yep, will be doing that next week, thanks !
    Dutchgit likes this.
  16. Gravel Seeker
    Apr 27, 2002
    10,788
  17. cyclopathic
    Dec 23, 2007
    9,463
    IIRC HyperPro has -40mm lowering spring listed for application.. part SP-BM06-SSB015.
    IMO just shave foam on seat; rounding edges will give you more standover and would be a welcoming addition from comfort point of view.
  18. Chrisbarnes1
    Chrisbarnes1 Long timer Supporter
    Dec 28, 2005
    1,273
    Market Deeping, Lincs UK
    do seat concepts do a foam and cover kit?
  19. manybike
    Jan 3, 2010
    1,307
    North America
    I checked them out and could only find regular height foam and cover kits.
  20. manybike
    Jan 3, 2010
    1,307
    North America
    Thanks, I will check the spring out. I am working on shaving the seat. Not sure how much foam to leave behind. Went for a test ride and it does make a difference, may have to get a pro to take a look and handle putting the seat cover back on correctly. I could also just peel the foam off , keep it and the OEM cover, and just keep them stored. Take the pan to a shop and have them do a new cover and foam...not sure if that is possible. I believe seat concepts sells foam cover kits but I could only find regular height ones in their website.
