1. ADVRIDER Print Magazine!
    We're doing two more print magazines this year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. manybike
    manybike Omnipresent Supporter
    Jan 3, 2010
    1,309
    North America
    The spring may be the issue. I weigh 160 lbs and am not getting much sag even with preload backed right off.
  2. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    5,477
    Pennsylvania, but living in a toy hauler full-time
    Definitely adds to the problem if nothing else
  3. cyclopathic
    cyclopathic Long timer
    Dec 23, 2007
    9,472
    Stock seat is 32.5" the biggest issue is how wide it is; I shaved the insides near tank without touching top and that made the difference. BMW uses their proprietary system for comparing seat height (pant inside from heel to heel when flatfoot) and 32.5" XCo has it higher than 33.5" 800GS. Shaving top wouldn't make much difference unless your SO has exceptionally wide pelvis.
    Other option to get used to footing one side only but she would have to practice making decision before coming to full stop.
    manybike likes this.
  4. cyclopathic
    Dec 23, 2007
    9,472
    What year is it 07 or 09? 09 shouldn't have much sag with 165mm travel. Is it possible that 09 bike had been made taller to 07 spec? Stiffer spring?
  5. manybike
    Jan 3, 2010
    1,309
    North America
    How are you measuring seat height ? , with stock seat mine is over 36 "
  6. manybike
    Jan 3, 2010
    1,309
    North America
    Mine is an 07.
  7. manybike
    Jan 3, 2010
    1,309
    North America
    Also, it has an aftermarket Hyperpro on it, not sure the weight it is set up for.
  8. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    2,190
    Герма́ния
    You could ask Hyperpro for the correct spring, they should ask you about weight and intended use, loaded/unloaded etc.
    Snake Oiler likes this.
  9. cyclopathic
    Dec 23, 2007
    9,472
    Do you have XCo or XCh? 09 XCo 32.5", XCh 37". The -40mm lowering spring number for XCh is SP-BM06-SSA026
  10. manybike
    Jan 3, 2010
    1,309
    North America
    I have the xchallenge
    cyclopathic likes this.
  11. manybike
    Jan 3, 2010
    1,309
    North America
    That number is for the fork springs. I was looking for a lower rear shock spring.
  12. cyclopathic
    Dec 23, 2007
    9,472
    Their kit numbers are SSA for fork springs and SSB for shock spring, but there's no listing for shock spring; it just lists shock. Give them a call Klaus at EPM performance or somebody else should be able to help you.
    https://epmperf.com/hyperpro-high-performance-motorcycle-suspension/
  13. manybike
    Jan 3, 2010
    1,309
    North America
  14. Konnieblaze
    Konnieblaze Adventurer
    Jun 11, 2020
    43
    BC, Canada
  15. manybike
    Jan 3, 2010
    1,309
    North America
    Can you share the routing you did ?
  16. Chrisbarnes1
    Chrisbarnes1 Long timer Supporter
    Dec 28, 2005
    1,273
    Market Deeping, Lincs UK
    I checked out the Seat Concepts site. They do a cover and foam--and its waisted near the front but spreads out in the right place. My concern is comfort on a long trip--height can be sorted much better with rear shock internal length adjustment and dropping the forks through etc. As long as I can get a toe down on one side then that will suit--especially when the bike is laden with panniers etc. I have a Seat Concepts foam and cover on my WR250R--and boy what a difference. I did a 4.5k round trip camping a couple of years ago doing 250 miles or so a day--and the seat was just fine--the key is that its more of a flat horse saddle shape--there isn't that much give in the foam, but it fits!
  17. computer_freak
    computer_freak Been here awhile
    Jun 23, 2016
    355
    Dutch
    Just got my cables. Ordered from Alibaba directly from the factory in Turkey.
    Quality is good, comparable to OEM. The only difference I could find is that the clutch cable is slightly longer on the outside, but the amount of inner cable that sticks out is the same length so there shouldn't be a difference in operation.
    X-Challenge + X-Country throttle cable versus an original X-Country throttle cable:
    Clutch cable versus the original clutch cable:
    Meriden, DGR, Snake Oiler and 3 others like this.
  18. Dutchgit
    Jun 24, 2012
    2,190
    Герма́ния
    I'll see if I can get some pictures when I dig the bike out.
  19. Meriden
    Meriden Yea whatever
    Oct 26, 2010
    1,394
    In the garden behind the dacha
    A couple of looks a Seat Concepts installed. This is one of my favorite modifications and along with a Parabisis makes long pavement rides pretty tolerable. Personally I'm a "take it out of the suspension not the seat" kind of guy. If I'm going to use all of the suspension, like I did with the KTM300, then I'm standing up anyway. For me the X is more of a light adventure bike than something that eats single track. Probably the biggest mistake I made was getting an Ohlins. Jacked the bike up so much I had to find a rock or curb to get a food down. It was like the Continental air shock except it didn't sag when I threw a leg over.
    manybike and Snake Oiler like this.
  20. Dutchgit
    Jun 24, 2012
    2,190
    Герма́ния
    Depending on your weight you might want a different spring on that shock.
    I'd have had the Ohlins rebuilt to make it a little lower. Stock Xco shocks aren't the best.
