BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. Gravel Seeker
    Gravel Seeker Old, growing older.
    Apr 27, 2002
    11,251
    Dreary old Norway, dreaming of adventures past
    And a bunch of other makes (KTM, Ducati etc). Any bike using Brembo brakes.
    crossroadz.com.au lists brake parts and Brembo numbers along with KTM numbers at least. I ordered service kits for my calipers from a local KTM shop to me using the numbers I found on WayneC's site.
    hansi likes this.
  2. hansi
    hansi Teurer Abenteurer Supporter
    Jan 1, 2010
    1,443
    State of Jefferson, Southern OR
  3. WayneC
    WayneC Long timer
    Oct 3, 2008
    6,008
    Sydney, Australia
    Part No is different to the 650GS & fiche does not state it is 11mm, looking at the fiche pics the difference GS to X seems to be the GS one comes with the actuating rod & the X does not, there will be Brembo Part No info on it & from that it should be able to work out it is the same as the GS plus what repair kits can be purchased from non BMW sources, if anyone gets the info from the MC I can look at the Brembo info I have
    Koof and hansi like this.
  4. CarstenB
    CarstenB Been here awhile
    Jun 9, 2015
    635
    NL
    looks like it's the Brembo 4888 MC.
  5. konleo
    konleo zboutsam
    Oct 24, 2010
    30
    greece
    Hi to all,
    I have an xch 08 and a friend is doing the clutch bushing installation for me (great info btw).
    My question is when the clutch case is to be installed, does it need a gasket seal or something or is it just the oring, screws and youre done?
    Thanks in advance.
  6. underontop
    underontop Been here awhile
    Jan 2, 2008
    218
    Nelson, NZ
    Just the rubber & torque it up.
    eaglescan likes this.
  7. konleo
    konleo zboutsam
    Oct 24, 2010
    30
    greece
  8. Darth_Maga
    Darth_Maga Adventurer
    Aug 3, 2020
    14
    Madrid
    Not yet. I am in the final stages of giving up and ordering a new front master cylinder.....
  9. Darth_Maga
    Aug 3, 2020
    14
    Madrid
    Got there. Arrives next week.
  10. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    5,670
    Mesa, AZ
    Cleaning out my shop and I found a KTM axel nut and 27mm Motion Pro combo tire lever.
    I turned the OD of the nut down so it will fit the rear of the XChallenge.
    Items are on their way to a new home.
    cyclopathic and Dutchgit like this.
  11. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    2,231
    Герма́ния
    Turned the front nut as well and took the end cap off so I can interchange them and the front axle doesn't hold water when parked.
  12. tbarstow
    Jul 9, 2007
    5,670
    Mesa, AZ
    I can take the end cap off if needed.
  13. MotoWarrior
    MotoWarrior n00b
    Jul 21, 2021
    3
    Los Angeles CA
  14. DonM
    DonM Do-dah Do-dah Supporter
    Jan 13, 2008
    4,059
    Atlanta, GA
    Hi MotoW,
    Did you use an 09 bmw cover? Also did it come with the bearing and such already installed? Who did you source it from?
    Lotta questions I know but thanks!
  15. underontop
    Jan 2, 2008
    218
    Nelson, NZ
    Clutch cover here : https://m.aliexpress.com/item/32893766529.html
    Loncin used to make them for BMW, they may still have some BMW branded ones if you ask. They have the steel insert but do not come with anything else. You need to buy & fit your own wee needle bearings, and re-use the spindle thingy and large 0 -ring. See snooker's website ..
    cyclopathic and DGR like this.
  16. Natgeo14
    Natgeo14 Long timer
    Mar 30, 2019
    1,817
    Des Moines, IA
    Posting the link to the Alli Express clutch cover just confuses people.
    Please test alli express's website next time and make sure that the product can be added to the cart before posting it.
  17. Natgeo14
    Natgeo14 Long timer
    Mar 30, 2019
    1,817
    Des Moines, IA
    I'm still looking for a shifter lever to replace the stock one.
    I bought a XR650l and a DRZ shifter lever but they both look like they stick out too far.
    Any ideas on an inexpensive solution?
  18. tbarstow
    Jul 9, 2007
    5,670
    Mesa, AZ
    WR450 shifters fit with no issues. I had a Moose Racing aluminum one.
    Natgeo14 likes this.
  19. underontop
    Jan 2, 2008
    218
    Nelson, NZ
    Yes you're absolutely right I should have noticed the html file sorry. Turns out they're not available on AliX anymore.
  20. underontop
    Jan 2, 2008
    218
    Nelson, NZ
    Any lever off a previous 650 single F or G will fit.
