BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. XallengeXccepted
    XallengeXccepted Been here awhile
    Jun 30, 2014
    399
    SF Bay Area
    See, I knew that before I said to myself "I know about how much 10 nm is".
    I'm just glad to have it fixed without too much pain and frustration. It turned out to be a really good thing I didn't just leave it broken off. Because I replaced all the screws with new ones, and one of the other ones I pulled out on the same side of the broken one was only 1/2 the length it was supposed to be! Some idiot put a short screw in there.
    Dutchgit likes this.
  2. Humphery
    Humphery Adventurer
    Mar 6, 2016
    17
    ma
  3. Butters
    Butters Kwyjibo Supporter
    Oct 10, 2008
    6,638
    NoVA
  4. Len
    Len Long timer Supporter
    Apr 3, 2015
    6,452
    North Alabama
    That is F'ing scary!
    Never screw in a spark plug into a hot aluminum head without being REALLY careful, that's how I got my initiation into the ooops club, 2 stroke Kawasaki in 1968 in the middle of nowhere, that lesson stuck.
  5. Len
    Apr 3, 2015
    6,452
    North Alabama
    I have a problem with my low beam, no power at the bulb and I traced it back to the switch. The high beam works so it has to be in there. Before I take it apart, has anybody had one apart and at what point does the spring shoot the little steel ball across the garage and in to the abyss with the other sock and the ink pens you just laid down?
    Edit: I found a write up on F650.com that shows a problem with the low beam getting hot and recessing into the switch. This is the fix I will try rather than spending $140 for a new one.
    http://f650.com/forum/faq.php?faq=gs_63_lighting#faq_gs_headlamp_switch_repair
    keepshoveling likes this.
  6. Tommy90
    Tommy90 Adventurer
    Jan 21, 2016
    74
    North Italy
    This is my BMW xchallenge !
    Via del sale ,sardegna,passo dordona (italy)
    flying.moto, jdwhite, DGR and 3 others like this.
  7. Tommy90
    Tommy90 Adventurer
    Jan 21, 2016
    74
    North Italy
    DGR, keepshoveling and Bli55 like this.
  8. Tommy90
    Tommy90 Adventurer
    Jan 21, 2016
    74
    North Italy
    Nice bike!
  9. Tommy90
    Tommy90 Adventurer
    Jan 21, 2016
    74
    North Italy
    Passo dordona and home
    Len, keepshoveling and Bli55 like this.
  10. Tommy90
    Tommy90 Adventurer
    Jan 21, 2016
    74
    North Italy
  11. trailrider71us
    trailrider71us I can't b fired,only sold
    Jul 1, 2008
    218
    Wisconsin
    Bli-- I was looking at your build thread and noticed that you used a non standard seal when you rebuilt your water pump.
    I would replace those seals w/ the factory supplied ones, They may make the leak go away, The ones you used may not be compatable w/
    heat,antifreeze,etc.
    Sean
  12. XallengeXccepted
    Jun 30, 2014
    399
    SF Bay Area
    That looks like sooooo much fun! Thanks for sharing the photos. I'm so glad riding season is opening up here in California.
    Tommy90 likes this.
  13. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    1,816
    Герма́ния
    It's put down in my notes that ! It's not even that more expensive than an injector.
    I had Megasquirt EFI on my Range Rover. Switchable maps and everything. That LC-2 might be the closest to that.
  14. Humphery
    Humphery Adventurer
    Mar 6, 2016
    17
    ma
  15. Sh4ft
    Sh4ft Beater
    Apr 22, 2011
    127
    SL,UT
    Finally got around to replacing my clutch cover with the 2009 version, getting the larger (top) needle bearing to seat required some persuasion with a heat gun, mallet and socket/socket extension. I found that heating the cover with a heat gun was more effective than boiling it in water but maybe I didn't leave the brand new clutch cover in the saucepan for long enough.
    I did have to grind several millimeters off the end of the operating shaft to get the circlip back on. Shifting is smooth again and I can find neutral from 2nd or 1st easily.
    Note: You do not have to drain the oil to change the clutch cover or replace the friction disks/plates/springs, just make sure the bike is vertical.
  16. XallengeXccepted
    Jun 30, 2014
    399
    SF Bay Area
    I forgot where I got the information at this point, so sorry I can't give proper credit. But the trick to getting the needle bearings to slip in is to freeze them first. And then just run the cover under hot water. Hot tap water from the faucet was actually hot enough for me. Then the frozen needle bearings slipped right in with a little socket/hammer tapping.
  17. jdwhite
    jdwhite Been here awhile
    Jul 25, 2014
    145
    Lusitanistan
    Finally I made peace with the Leo Vince exhaust.
  18. XallengeXccepted
    Jun 30, 2014
    399
    SF Bay Area
    Very nice! Can you come do mine now? :*sip*
    J.chem, Yukon Ho! and jdwhite like this.
  19. seasider
    seasider Just a rider
    Oct 27, 2007
    1,087
    Virginia
    Perfect timing.....my parts just shipped from Max BMW.
    On a side note with the continuing upgrades just installed the Hyperpro rear along with the stainless wheel spacers front and rear. Amazing to see that at 9800 miles the oem spacers were so grooved.
    Very thankful for the info on this thread with the suggested must do improvements.
  20. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    4,771
    NYC
    credit to tbarstow by way of snooker's page, iirc. It's a very good trick. If you have dry ice and you've gotten stuck you can just drop a chip of it on into the bearing and I think that generally works well enough to get it the rest of the way in.
