BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    5,037
    NYC
    So I'm finishing up my project and I put the swingarm back on so I could get the bike rolling and get my milk crate stand back for its important job - stool. When I'd taken it off the three little bolts on the right came off as easy as you please and I felt a bit of relief that I didn't have to deal with the nonsense of recalcitrant bolts made of swiss cheese. Last night I went to put the chain on and fast forward through quite a bit of swearing and tonight I'll bring my reverse drill bit out to the garage to get the last one but goddamn what the fuck were you thinking BMW that is not a place for teeny tiny bolts made of cheese. Why not just use the same big beefy bolt you have on the other side? :becca
    That said, the bike starts up and shifts nicely now so even with a few final pieces it's nice to see an end in sight. I certainly know the thing a lot better now than I did before and the sense of relief/accomplishment I felt from replacing such a major component without destroying anything is pretty great.
    And if I ever have to do it again I bet I can do it in 1/3 the time. :hung
    eaglescan, Len and Dutchgit like this.
  2. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    2,142
    Герма́ния
    I know your pain. When I replaced the shifter shaft I cut the gasket before I've put the two halves of the engine together... :becca
    Len and keepshoveling like this.
  3. eaglescan
    eaglescan Borrego rocks
    Jun 17, 2009
    746
    Langley,B C
    Well done on the engine swap. perseverance is a good thing!
    keepshoveling likes this.
  4. seasider
    seasider Just a rider Supporter
    Oct 27, 2007
    1,235
    Virginia
    Have any of you guys successefully used a coyote loop bag on the x with just the standard heat shield provided and the oem exhaust?
    I would hope to go this route with a small additional duffle for some camp weekends.
  5. Yukon Ho!
    Yukon Ho! Vaccinated! But Canada no want our money Supporter
    Oct 2, 2011
    387
    Warshningtun
    I used a Great Basin on my X(Co) with just the heat shield provided by GL, for a few thousand dirt miles. I did need to MacGyver ~10 square inches of additional heat shielding. It's not a big deal, it worked just fine. (And - I'm happier with xrack and wolfman saddlebags.)
  6. MATT0404
    MATT0404 Been here awhile
    Jun 20, 2011
    507
    PA
    I don't have experience with the GL bags, but I run the Mosko Moto R40 with their heat shield and an improvised pop can for additional peace of mind.
    [​IMG]Packed Up by Matt Krepp, on Flickr
    sitz, keepshoveling, Dutchgit and 2 others like this.
  7. advFord
    advFord Long timer
    Jan 16, 2012
    1,168
    Orange County, CA
    $#&*! this valve cover bolt broke off inside.
    How screwed am I?
    I'll probably take it to Lior's shop but checking here first if anyone has any suggestions first. Again the valve cover bolt has broken off inside.
  8. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    5,363
    Mesa, AZ
    Cover everything up well and use a left twist drill bit. I think I still have some of these bolts in the garage.
    flying.moto and blaster11 like this.
  9. advFord
    advFord Long timer
    Jan 16, 2012
    1,168
    Orange County, CA
    Thanks - I could pick something up at the auto store.
    @tbarstow what size would you use?
  10. tbarstow
    Jul 9, 2007
    5,363
    Mesa, AZ
    I would use a 5/32" left twist drill. Looks like AutoZone has a set for $10.
    I will most likely be in LA on Wednesday night and Thursday this week, I can bring you some new valve cover bolts.
    Len, keepshoveling and advFord like this.
  11. advFord
    advFord Long timer
    Jan 16, 2012
    1,168
    Orange County, CA
    Alright if anyone runs into this problem..
    I was able to get the broken valve cover bolt out using the $8 Left Hand Drill Set from Harbor Freight. I started out with a center tap and the smallest bit and after a frustrating half hour of working my way up to larger bits I was finally able to get the bolt out using the 11/64 bit. It didn't come out till I was just about at the very end of the bolt.
    Valve Cover Bolt removed using 11/64th Left Hand Bit from Harbor Freight.
    Thanks @tbarstow for the suggestion! I'll send you a PM.
    Len, keepshoveling, blaster11 and 2 others like this.
  12. Dutchgit
    Jun 24, 2012
    2,142
    Герма́ния
    That was lucky !
    keepshoveling, blaster11 and advFord like this.
  13. seasider
    Oct 27, 2007
    1,235
    Virginia
    Thanks Matt and Yukon Ho regarding the giant loop style use. Now that I have the bike dialed in luggage carrying is the last item to address. Im not crazy about bag frames on the rear and will start with the lesser options.
    Lots of room on the seat on back even with a relaxed riding position. Bigger challenge will be strapping points but it looks feasible in the picture.
    Open to suggestions if others have figured out fastening/lashing solutions that have worked well for road and trail.
  14. BikerBobber
    BikerBobber Trying to get lost
    Feb 28, 2011
    1,308
    Seeleys Bay, Ontario
    Fixed.
    Bob
    Sent from my mobile
    Dutchgit likes this.
  15. trailrider71us
    trailrider71us I can't b fired,only sold
    Jul 1, 2008
    228
    Wisconsin
    Len- Did you get your lowbeam fixed?
    Mine is pulling the same crap. Took the switch apart not much to see.
  16. Cam805
    Cam805 Been here awhile
    May 29, 2012
    133
    Ventura County, California
    Well it finally caught up with me, time to do the water pump...18,000 miles which I believe is right on schedule. It's weeping a bit, and the overtemp MIL comes on at idle, so it's time to change those seals.
    Two questions for the gurus:
    1. The manual says to pull the swingarm, which needs doing anyway. But it also says to pull the oil reservoir. Is this 100% necessary, or can you work around it?
    2. The snooker page suggests that the seals go because the outboard end of the shaft is supported by the waterpump housing. While in there, will I extend the life of the new shaft by replacing the housing too?
    I want to order the parts all in one go, not get in there and find I forgot something.
    Appreciate the help.
  17. Len
    Len Long timer Supporter
    Apr 3, 2015
    9,148
    North Alabama
    Yes, after I looked into the schematic, the power to the low beam isn't fed the same as the high. The 7.5 amp fuse was blown. The PO had done some "creative" wiring to the H4 harness socket and the low beam post was touching the triple clamp to dash mount bolt when things got rough. I insulated the wire connector and replaced the fuse and all was good again.
    I found the switch to be the same as you, all good in there.
  18. tbarstow
    Jul 9, 2007
    5,363
    Mesa, AZ
    #1 - no need to pull the oil reservoir. You will have to take the lower left frame casting off to get access to 1 or 2 bolts holding the left engine housing cover (also called the Clutch Housing on the fiche, 11 14 7 699 387 CLUTCH HOUSING) on. At this point, your bike will probably be laying on its side on the ground unless you can lift it from above.
    #2 - the water pump shaft is not really supported on the outside in the clutch housing. Replacing that part is a bit expensive. Do purchase the water pump shaft kit (11 51 2 343 451 SET: SET, WATER PUMP SHAFT for $58) and check the clutch housing to make sure the hole for the clutch housing is still round and that the housing has not warped (check the flatness of the clutch housing machined surface), as these have been known to warp or wear the impeller hole out of round.
    Somewhere there is a set of photos showing how to do this. It looks scary, but really isn't that bad to do.
  19. Cam805
    May 29, 2012
    133
    Thanks Tim. Your answer was concise and thorough, as always.
  20. opm22
    opm22 n00b
    Mar 15, 2016
    6
    BR
    Hi guys,
    the well known clutch problem here with my 07 G650X Challenge. I've opened the clutch cover yesterday because suddenly I've lost completely the clutch action. Result: lost 1 tooth from operating shaft (that goes on the cover) and 1 tooth from the release bearing. The lost tooth from the cover shaft I was able recover, but I couldn't find the lost tooth from the release bearing (picture below).
    Do you guys think this lost tooth is a problem for the engine? I'm going to do an oil change before starting the engine again but I'm not sure I will find this small piece of metal in it.
    Is this broken teeth caused by the well known cover defect? Should I replace the cover for the '09?
    Any sugestions?
    Thanks!!!
