BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    5,140
    Mesa, AZ
    I would get the new cover if you don't have access to a machine shop or a buddy that will cut you a deal doing it for you.
    I don't recall if the missing tooth is magnetic or not, but as long as you have the side of the motor open, I would stick my magnetic pick up tool in there and see what comes out just to be safe.
    keepshoveling likes this.
  2. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    2,007
    Герма́ния
    Thing is, that tooth might be picked up by oil being flung around and could do all sorts of damage.
    I've just split a casing of a KTM 640 where one of the plastic oil gears was broken and it was everywhere (in bearings and oil channels)
    A steel tooth might be picked up with a magnet as Tbarstow says.
  3. advFord
    advFord Long timer
    Jan 16, 2012
    1,095
    Orange County, CA
    My X is at 24,000 miles. Do I spend the $36 for the valve cover/ cylinder cover gasket or reuse the existing one?
  4. gqelements
    gqelements Been here awhile
    Oct 26, 2012
    956
    T-Dot, Canada
    Bli55, J.chem, opm22 and 7 others like this.
  5. mtncrawler
    mtncrawler Long timer Supporter
    May 17, 2003
    1,610
    Fort Collins, CO
    That looks awesome! Curious though, having read the thread you referenced I couldn't quite piece together what was included with the kit. Is it a complete turnkey, plug and play kit? Instrument cluster housing with ignition, tower, lighting, wiring kit/adapters, HDB top clamp, screen...etc. It sounded like the instrument panel mount was still separately sourced, but has that changed? Looking for something like this or the Lynx (but would rather have the LED setup :))
  6. trailrider71us
    trailrider71us I can't b fired,only sold
    Jul 1, 2008
    218
    Wisconsin
    If it is meant to be reused reuse it. Otherwise-
    That bike is barely broken in, spend away on it. They don't make any bikes that are comparable any more. Especially w/o electric nanny stuff. The only thing possibly coming our way
    is the AJP PR7 or the CCM 450. I plan on keeping mine along time. BMW is good about spares.
    Dutchgit likes this.
  7. Dutchgit
    Jun 24, 2012
    2,007
    Герма́ния
    Yep, I re-use mine every time.
    I had a package arriving today ! :clap
    Fits the battery with room for tools :D
    Only need to sell my normal Scheffelmeier bashplate now and the Touratech one.
  8. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    4,814
    NYC
    Are you going to run the loom down there? I assume that's what those two holes on the back are for. How are you making sure it's water tight?
  9. Dutchgit
    Jun 24, 2012
    2,007
    Герма́ния
    It should be water tight. I think i'm going to stick the battery there to get that weight down low.
  10. kito
    kito Been here awhile
    Mar 8, 2009
    508
    cheshire , England
    I'd fit a drain bolt if you plan on any water crossings as my tool box used to fill with water all the time and rusted all my tools
  11. mtncrawler
    May 17, 2003
    1,610
    Fort Collins, CO
    Nice! I have the same skid plate/tool box from SS - not that pretty color though. :)
    I was going to do the same battery placement but the earthx is so light I just stored all tools and flat repair stuff down there (heavier than battery) and kept the battery in its original spot. Agree with Kito, The toolbox isn't quite watertight.
  12. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    4,814
    NYC
    Regular lead acid battery? I only ask because I thought about that after reading colebatch's thread and then decided on keeping tools down there once I bought a LiFePo battery (so I could leave it outside in NYC winter and not worry about it discharging - so far so good) and I think they're actually heavier than the battery. Although there's no reason you couldn't surround it with foam and then put tools around it I suppose.
    FWIW, I've had the opposite experience. No matter how much water I go through the stuff in the toolbox remains dry. I'd certainly test before trusting though.
  13. Dutchgit
    Jun 24, 2012
    2,007
    Герма́ния
    I'll just fit it and keep my tools in there for now so I can see if it really is water tight.
    Knowing my "luck" with water I'll soon find out :hmmmmm
  14. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    4,814
    NYC
    Or you could just put it in a bathtub for a few minutes right now...
  15. sitz
    sitz Been here awhile
    Sep 3, 2011
    100
    FWIW, I've got my clutch cover off for that same upgrade; just tried a magnet against both the the rack and pinion gears; it appears they are both magnetic.
    opm22 likes this.
  16. gqelements
    Oct 26, 2012
    956
    T-Dot, Canada
    Agreed, seems like a lot of work and headache with potential flooding issues for something solved by LiFePo battery. I'm waiting for my battery to kick it to make the switch to LiFePo..
  17. seasider
    seasider Just a rider Supporter
    Oct 27, 2007
    1,124
    Virginia
    Tail tidy help please....
    What are you guys running in place of the oem tail that DOES NOT GET SUCKED IN BY THE REAR TIRE on reasonable jumps like 2 ft drop offs?
    It happened with the air shock and now again with a well set up Hyperpro so I have to assume just bad design. Im only 185 with gear and no other load on bike so this seems ridiculous.
    Best tail bracket/plate holder/ turn signal holder option please? Almost willing to go oem if thats the ticket to alleviate this issue.
    This bike really could be my "if I could only have one bike" bike. Im that close!
    blaster11 likes this.
  18. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    4,814
    NYC
    I would think that Snooker's FARFS mod would do it for you. Makes the stock rear pretty rigid for me.
    http://mattsnook.com/bmw/bmwXCountry/FenderSupport/index.htm
  19. seasider
    Oct 27, 2007
    1,124
    Virginia
    That has been on my list and now that you say it I did not think so much about the mount moving on impact but I think you are right. Thanks.
  20. seasider
    Oct 27, 2007
    1,124
    Virginia
    Anyone have an oem tail they are willing to part with!
    J.chem likes this.
