1. ADVRIDER Print Magazine!
    We're doing two more print magazines this year. July & November. 144 pages of high quality adventure riding stories, photography and interviews!
    Click here to purchase both for $35.
    Dismiss Notice
BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. swamp
    swamp Shut up. Ride.
    Feb 14, 2007
    4,746
    lower appalachia, Alabama
    just tried that again after running bike. no work . ideas ? tried tying rope around actuator shaft and pulling , tried tapping with screw driver, tried prying in different ways... hmm
  2. CarstenB
    CarstenB Been here awhile
    Jun 9, 2015
    603
    NL
    or do you have to remove the actuation arm so the splined shaft can rotate freely? I think that was it. I felt like an idiot when i did it the first time and couldn't get the cover off.
  3. CarstenB
    Jun 9, 2015
    603
    NL
  4. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    5,089
    NYC
    twist the shaft. You may have to use a vise grip. If that doesn't work, you can wedge a long piece of wood underneath the actuator shaft and use the frame as a lever. I recommend twisting though.
  5. swamp
    Feb 14, 2007
    4,746
    marred the shit out of actuator shaft with pliers when turning it(have new one)). used screw driver in cover bolt holes to pry , screw driver was bending . bastard finally flew off of there but my fist smashing into foot peg. have new cover. thanks for the moral support
  6. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    5,089
    NYC
    Yeah, I used a 2x4 on mine (also had a new shaft so it helped knowing that) after I went through a similar ordeal. Good news is all my bruises have healed and my seething rage has dissipated so you should be fine in 7-10 days (and it should pop right off now with an easy twist).
  7. eaglescan
    eaglescan Borrego rocks
    Jun 17, 2009
    757
    Langley,B C
    Good choice, I like the E 09 too, but sometimes hard to get & pricey. I do remember how strong they are, ran it flat for miles once.
  8. eaglescan
    Jun 17, 2009
    757
    Langley,B C
    It is the 2 dowels that give all the grief. I usually use a very thin screwdriver to pry next to the dowels.
    Dutchgit likes this.
  9. SteveDennehy
    SteveDennehy Steve
    Jan 15, 2011
    402
    Pretoria, South Africa
    Yeah, they are strong. They are also an absolute bitch to get off. Roadside puncture repair becomes an endurance event with much sweat and swearing, and sacrificing of skin on knuckles.
    :becca
    Boarder06 and XallengeXccepted like this.
  10. DESERT SCORPION
    DESERT SCORPION SINGLE TRACK
    Jul 24, 2008
    210
    SINGLE TRACK IN THE WOODS
    You are hopefully using a new cover O-ring gasket. Mine was very dried out, and cracked and ripped trying to remove it from the old cover.
  11. cgguy09
    cgguy09 Scientiæ Cedit Mare
    May 25, 2010
    1,761
    Astoria, OR
    So, apparently in a drunken fit of passion, I bought a leo vince exhaust yesterday. Should be here by Thursday. I need to block Revzilla and Twisted-Throttle when I drink...
    octopusenvy, PaulyD, Len and 4 others like this.
  12. swamp
    Feb 14, 2007
    4,746
    just finished the clutch cover issue fix. wow what a difference , no walking and I can shift into neutral now.
    I replaced all the parts with BMW parts . shaft, bearings, clip, gasket, seal, cover. the clip went on easily with the new parts .
    when the old cover came off there were aluminum shavings where the clutch shaft meets the shift shaft.
    I havr photos of everything and part numbers that ill put up later tonight .
    octopusenvy, Len and keepshoveling like this.
  13. XallengeXccepted
    XallengeXccepted Been here awhile
    Jun 30, 2014
    399
    SF Bay Area
    7-10 days!!? Sheesh, hold a grudge much?
    keepshoveling likes this.
  14. XallengeXccepted
    Jun 30, 2014
    399
    SF Bay Area
    That's part of the reason I LOVE the Pirelli Scorpion XCMH. They slip right on and off with minimal fuss.
    I swear there was iron rebar in the bead of my Mitas rear tire. There is NO WAY it was ever going to be repaired in the field had I gotten a flat. Never again.
  15. seasider
    seasider Just a rider Supporter
    Oct 27, 2007
    1,252
    Virginia
    Bought mine with 9500 miles and sure the plugs were original. Vibes made me crazy and as a matter of coincidence I asked the dealer to change them while I have the valves checked (just barely out of spec on this the first check ever). First ride after picking the bike up and the difference was dramatic. Love how the motor is now. I never rev it to the moon anyway but it it very smooth and enjoyable with fresh plugs.
    Hope it helps your situation.
    keepshoveling, jonnyc21 and cgguy09 like this.
  16. swamp
    Feb 14, 2007
    4,746
    photos from clutch cover, shaft, bearings, gasket fix.
    all bmw parts: i think if you zoom in you can get the part numbers off the bags
    aluminum shavings from clutch cover. my bike has 14,000 miles on it. Already it was eating itself.
    inside the hole there is a shiny spot. im pretty sure thats where the shavings came from
    the new cover with gasket, bearings , clip , seal and shaft installed . no need to grind anything. the new cover has a slot which the o-ring gasket fits inside. i put the bearings in the freezer for about two hours then used an 8mm attached to an extender and a hammer to tap in the small bearing and a 12mm to tap in the larger one.
    i torqued the cover bolts to 10NM , not sure if thats correct but it felt ok.
    one thing that i noticed: i ordered two sets of bearings, one set from bmw and the other set from the part numbers that were given for the amazon.com bearings. the small bearing from amazon is just a little fatter than the bmw one. probably doesnt matter but its worth noting.
    the hardest part was removing that bastard cover. i definitely suggest purchasing a new actuator shaft before doing this just in case you need to grab the old one with pliers and twist the hell out of it. also, you wont have to grind anything. i know this has been covered a hundred times .. here's 101.
    rockydog, Dutchgit, Len and 1 other person like this.
  17. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    2,190
    Герма́ния
    You could have put your shifter on the shaft to help get the cover off, it has the same dimension and teeth.
  18. rockydog
    rockydog just a guy
    Feb 11, 2007
    1,297
    okieland
    Swamp, what was the total cost? Just an estimate will work..thanks, Stephen
  19. jdwhite
    jdwhite Been here awhile
    Jul 25, 2014
    260
    Lusitanistan
    I use the rear E09, along with MT21 front. I`m on my 3rd set now and like this combo a lot for my mix of tarmac and dirt which is about 50/50. They last me about 5 to 6000 km depending on temperatures
    My first E09 was stock size 140/80 18. But for the next ones I went with size 130/80 because it´s much easier to put on and off and a bit cheaper too. I didn´t notice any difference in how the bike handles.
    keepshoveling and Boarder06 like this.
  20. Len
    Len Long timer Supporter
    Apr 3, 2015
    9,635
    North Alabama
    Very clever
