BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. Len
    Len Long timer Supporter
    Apr 3, 2015
    5,918
    North Alabama
    That is not far from what I was thinking would work best and also stiffen up the subframe. If I could only figure out a way to incorporate a tank under the tail and down one leg, it would be perfect.
  2. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    4,683
    Mesa, AZ
    Other than putting passenger pegs on a KTM 500? Nope, it sounds like a good plan to me.
    XallengeXccepted likes this.
  3. slide
    slide A nation with a future
    Jul 20, 2003
    21,391
    NM, USA
    A while back I posted that after a coolant change my bike was overheating and also when parked more than a few minutes, it'd reset the trip odo's and clock back to zero. Several inmates here suggested I burp the system to address the overheating and get a new battery.
    It took me a while to get to it, but I finally did. Both remedies addressed the relevant problems and the bike is running well and trouble free now. I post as an FYI to the next pilgrim having either or both issues. Thanks for the great ideas, guys.
  4. Meriden
    Meriden Yea whatever
    Oct 26, 2010
    1,251
    In the garden behind the dacha
    That passenger is in trouble. It looks like there is only one peg!
    Mosko shipped. The bags should be in next week.
  5. snooker
    snooker AttitudeIsEverything
    Feb 19, 2010
    2,017
    Loveland, Colorado
    Ah gee c'mon Tim, you never know who you might want to give a ride to, if you know what I mean.
    keepshoveling likes this.
  6. snooker
    Feb 19, 2010
    2,017
    Loveland, Colorado
    Want To Buy an XTank. Must be in good condition. PM me....
    Hell I might even buy an X-Rack too if you have a good price... -matt
  7. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    1,765
    Герма́ния
    Just make sure you'll be buying the updated version of the X tank which has the bit taken out at the bottom on the inside to make room for the rear sprocket and chain on full compression ;-)
    BIKE-R, keepshoveling and Len like this.
  8. Len
    Apr 3, 2015
    5,918
    North Alabama
    With the bike at rest, how far above the chain is the notch in the X-Tank? I've never seen one in person, only in pictures.
  9. Dutchgit
    Jun 24, 2012
    1,765
    Герма́ния
    I'll measure tomorrow.
    Len likes this.
  10. Stromius
    Stromius Part time danger seeker
    Jan 28, 2011
    131
    Seattle, WA area
    Feeling nearly complete. TT rear rack, 31L waterproof bag and bash plate plus HB rack. Any recommends for a minimalist, reserve tank mounting on the right inside side.
    ElectroMoto and keepshoveling like this.
  11. Dutchgit
    Jun 24, 2012
    1,765
    Герма́ния
    Measured down from a 90 degree angle in relation to the two bolts of the passenger grab handle/rear rack mounting points, it's about 22 cms (8" 3/4) to the notch, the notch itself is about 5 cms (2").
    The notch is about half that on earlier tanks if I remember right.
    I've seen damage on an earlier tank where the rear sprocket/chain had hit the tank.
    Not sure if that would have been due to someone fitting a larger rear sprocket or a damaged shock or such.
  12. Dutchgit
    Jun 24, 2012
    1,765
    Герма́ния
    Rotopax looks like it might fit. The 1 Gallon one.
  13. Cruz
    Cruz Lost but laughing.
    Nov 3, 2008
    11,347
    Northside Brisbane, Qld Australia
    Early tanks had no notch at all.
    keepshoveling and Dutchgit like this.
  14. Len
    Apr 3, 2015
    5,918
    North Alabama
    Thanks Dutchgit, that gives me something to work with!
    Dutchgit likes this.
  15. seasider
    seasider Just a rider
    Oct 27, 2007
    1,047
    Virginia
    Chain advise please:
    Having just refreshed the sprockets at 11k miles on what may be the original chain what is the consensus on clipped or riveted chain for this bike?
    I personally have never had an issue in the past with either but would prefer a clipped do to the fact that I want to check/lube swingarm parts this winter.
    As long as its out there whats the best chain for the money and longevity with the steel sprockets. There are too many selections for my knowledge as I look at the online options.
    gr8grins likes this.
  16. gr8grins
    gr8grins Been here awhile
    Nov 6, 2011
    395
    PNW Dry
    I had the same problem. Some kind folks here suggested I check my exhaust system for tension and be sure it's not touching the frame or coolant line(s)- it solved the problem. Loosen up all the fasteners on the system including the header bolts. Be sure it doesn't touch the frame or coolant lines and snug from front to back then tighten to spec.
    Hopefully this does it for you as it did for me. Great choice of bikes!
    keepshoveling and SIF like this.
  17. Dutchgit
    Jun 24, 2012
    1,765
    Герма́ния
    I use DID x-ring chains (endless ones so you have to take the swing arm out and you check/grease the bearings at the same time) and JT sprockets.
  18. hugues
    hugues Adventurer
    Apr 10, 2009
    29
    XC won't start. The horn caused a fuse to blow. When looking for it I pulled each fuse out one by one, checked it and replaced it. The horn was fixed. However, when putting back in the fuse at the front of the 15A fuse box (F) the dashboard lit up, flashed different text, ABS, etc, then went off. The ignition was not on... and the fuse is fine. All electrics such as lights, horn, GPS, etc, work fine. However the bike will not start. The starter motor turns the engine but nothing. It sounds as if there is no ignition but I have no real facts for this and I am not mechanically minded. Can anyone pls help? Thanks
  19. gqelements
    gqelements Been here awhile
    Oct 26, 2012
    900
    T-Dot, Canada
    ^the dash behaviour you describe is normal when re-establishing electeical connection. I'm not a mechanic so not going to offer unqualified advice other than that.... Your sparkplugs are fine right?
  20. Len
    Apr 3, 2015
    5,918
    North Alabama
    Side stand switch got me good one time, double check.
