BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. snooker
    snooker AttitudeIsEverything
    Feb 19, 2010
    2,141
    Loveland, Colorado
    OK JJ and Zac you guys are scaring the crap out of me since I'll be riding Hwy 285 to Gunnison next week! I've got almost 30k miles and have never touched my fuel pump OR the dreaded 4-pin connector on the top of it but I want to know more...
    I've got a bunch of clarifying questions, let's start at the basics. So the wiring connector you unplug has female terminals with wires colored: Green/brown, white/blue, brown, brown.
    And the connector on the fuel pump assembly has male terminals:
    PROBLEMS:
    1) One common problem is when you unplug the connector that the brown wired connection (on the end) does not unmate and tends to pull the male pin out that is part of the fuel pump assembly, which also leaves a hole. I'll call this the "Brown #4" connection. Is this correct so far?
    2) Zac you said in your case this brown wire was frayed at the connector and shorted against the frame. I'm thinking it is very far (1/2") from the connector to the metal ring (frame) so this must have been a very long fray (not just 1/8" or short, but longer?). I think I see a short frayed wire in the pic below (ignoring the totally uninsulated long replacement bare wire for now). Can you explain how it could touch the frame being so far away?
    As to the long bare replacement wire, I assume you somehow covered it up for your temporary patch so it wouldn't short to the frame again?
    And the leaking gas was coming out of this "Brown #4" hole that was no longer sealed well? SCARY.
    3) JJ you said: "I must also note that ALL of the wires inside the fuel assembly ( read the ones in petrol, soaked ) had exposed wires from rubbing against the zip ties. Sorta scary."
    Uh YEAH SCARY!
    So is the picture below a nice new "good" fuel pump assembly? And the exposed wires on your older bad one would have been the ones we see below that are Black, White, Green, Red? If so, then the zip ties you mention are around behind just out of view in this picture?
    If so then you are saying your original fuel pump is the one that had partially exposed (bare) wires sitting in the fuel itself??? Is anyone else concerned about this???
    :eekers :eekers :eekers :eekers :eekers :eekers
    waylongway and seasider like this.
  2. snooker
    Feb 19, 2010
    2,141
    Loveland, Colorado
    A kneejerk idea is to not unplug the suspect connector and cut the 4 wires and insert in series a second connector that would be the only one to unplug. Something like a Delphi Weatherpack 4-pin connector. This would keep the male pin connector on the fuel pump assembly intact so nothing could leak out or fail. That might be a preventative measure for at least the connector pin issue?
  3. jjmead1
    jjmead1 now THAT"S a bike!
    Sep 8, 2010
    879
    don't boulder my Golden, CO
    I blame the dealers because both of the ones I called didn't take the time to find the pigtail assembly that they actually sell and stock. They could not be bothered to assist me, just sell me the whole assembly.
    I had a rear tail light that would not work. Told me I needed a whole new wiring assembly. $1500
    I called an out of state dealer and found the part I needed.
    I am only blaming Denver dealers, they are very bad.
  4. OZZY-DUCK
    OZZY-DUCK Been here awhile Supporter
    Nov 2, 2009
    542
    Curled up in the corner
    Hi guys,
    I'm new to this thread.
    I'm looking at possibly swapping my fully farkled F800 for a reasonably farkled XC.
    I have never riden one as there are not many around and this one is about 1200 miles away.
    What is the seat height like?
    I'm only about 5 ft 9.
    I would like a bit of an idea before I go ahead and bite the bullet.
    Cheers
  5. seasider
    seasider Just a rider Supporter
    Oct 27, 2007
    1,235
    Virginia
    FWIW...... I had an f800 and find the x way way better off road an only marginally inferior with the typical hwy riding. Dualsport in general the x is hands down a great fit unless you are prone to packing much more than needed.
    As far as seat height I am 5-10 and have no issues still or riding. Seat sucks but thats an easy fix coming soon for me.
  6. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    5,037
    NYC
    Fun fact: part # 34 51 2 345 822 front wheel ABS sensor is an exact replacement for our rear wheel sensor. So, just hypothetically, if you're riding and a rock hits your wheel sensor and it bends a tiny bit so that you're getting the speedo goes to 0 issue you can just swap one out from basically any of the 650s for the last fifteen years or the 800. It's cheaper and much easier to find used and in excellent condition this way.
    DGR and Dutchgit like this.
  7. mtncrawler
    mtncrawler Long timer Supporter
    May 17, 2003
    1,698
    Fort Collins, CO
    Got it - yep I always set the trip meter at fuel ups - was just curious if there was a quick fix. Sadly, the thought of the 90 MPG I MUST be getting has been shattered....
    One from the road...
  8. OZZY-DUCK
    Nov 2, 2009
    542
    Cheers mate,
    That's what I was hoping.
  9. motorrat
    motorrat Been here awhile
    Mar 21, 2012
    249
    For everyone
    http://advrider.com/index.php?threads/bmw-g650x-issue-log-xcountry-xchallenge-xmoto.487473/ page 39
    mtncrawler and keepshoveling like this.
  10. jjmead1
    Sep 8, 2010
    879
    @snooker
    Yeah my Brown#4 male pulled out badly leaving the mess you described. ( one could read that wrong I think :eek2) As for the exposed petrol soaked wires. Yeah, they were the oem ones. The very same ones you see in the lower portion of the picture. They are oem zip tied to the aluminum support structure in the fuel pump assembly. I did not replace the whole pump assembly nor do I plan to tis time. I plan on ordering the $89 pump I got last time and hoping I find the reason it only lasted one year. I also plan on making sure those wires are still covered and not exposed again.
    Thinking my male to female wiring connector problem could not be solved in a reasonable fashion, I went a little bonkers. I did try to google similar connectors, and went to the dealers. Apparently my google fu was as bad as the dealers desire to actually help. So, I went full redneck. I drilled a small hole in the top of the fuel assembly. I then soldered brown #4 wire to its mate after I pulled it thru the drilled hole. Sealed up the hole and away I went. Super redneck knee jerk reaction,but it worked very well and seemed solid in its logic until I saw the above posts from you and a few others ---- who have much better google fu than I apparently. :fpalm
    Now I will try to un redneck my redneck fix and go do it the more civilized manner.
  11. motorrat
    Mar 21, 2012
    249
  12. MJS
    MJS Long timer
    Dec 23, 2005
    3,046
    Off the grid in San Felipe, Baja
    The bare wires are not an issue in the fuel tank. It takes the proper ratio of fuel / air AND an ignition source to create a problem. The atmosphere inside the tank is to rich, i.e. not enough oxygen.
    The brown wire is a ground wire. It is probably failing due to high a current draw from the fuel pump. I've seen this on cars/trucks (GM especially) when fuel filters don't get changed on schedule. The pump has to work harder and pulls more current. The connector is sized without much excess current capacity and overheats. The more it heats up the higher the resistance. The higher the resistance, the more it heats up. Until the connection burns up and the fuel pump "fails". If you change your fuel pump be sure the screen and filter are clean. Otherwise the new pump will be working extra hard and require additional current.
  13. MJS
    MJS Long timer
    Dec 23, 2005
    3,046
    Regarding the replacement connectors from BMW. Don't expect your parts guy / gal to know much / anything about them. They are in the parts diagrams but it is the service department that usually deals with them (the part number defines it as a service item). In most of the dealerships I've dealt with the service department will have a stock of the various connectors, the parts department may or may not know about or deal with them. Talk to the Service Manager if you can't get anywhere with the parts counter.
  14. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    5,363
    Mesa, AZ
    They a
    The dealeralso has to have a mechanic that is BMW trained to work on wiring harnesses to be allowed to fix this problem.
    Look in to using Rescue Tape to insulate your wiring in the fuel tank.
  15. snooker
    Feb 19, 2010
    2,141
    Loveland, Colorado
    MJS your explanation the higher current in the ground connection (on Brown #4 pin) makes sense to me. As to bare wires that could touch each other inside the fuel area, even if there is not a spark or fire issue, surely you would be concerned about 2 bare wires touching each other, especially if one is ground. This could at least prevent the pump from working?
  16. snooker
    Feb 19, 2010
    2,141
    Loveland, Colorado
    That thread is very interesting regarding the fuel pump ground pin on the connector problem, where they basically use a fatter bolt for ground to handle the higher current better.. It also pointed to this NHTSA Bulletin but I don't remember the fuel pump connector recall # 07V376000 being something the dealers were fixing - did I miss that? Has anyone had this done - what did they do?
  17. MJS
    MJS Long timer
    Dec 23, 2005
    3,046
    Well yes, shorted wires would keep the pump from working. Hopefully due to a blown fuse.
    I'm not saying that the bare pump wires are OK. They are an obvious sign of a problem that needs attention. Just that I would not be concerned about the bike exploding under my butt. There have been bare wires in gas tanks since they started putting electric fuel gauges in cars.
    Dutchgit and Len like this.
  18. Meriden
    Meriden Yea whatever
    Oct 26, 2010
    1,368
    In the garden behind the dacha
    Timely link. On a side note, the wife and I come from a German speaking area of Texas and recently started speaking German in the home. This should help wake up some old circuits in the brain.
    Danke
    m
    Dutchgit likes this.
  19. PaulyD
    PaulyD Been here awhile
    Dec 9, 2014
    178
    help! I replaced my clutch friction plates and springs with the EBC ones, and I replaced the clutch cover with a TR650 one, for the updated cover, I looked everything over to make sure it was the same before installing.. everything is installed, and now I can't get the clutch to disengage. At first I thought that maybe the splines on the cover shaft and the shaft on the basket weren't lining up correctly, so I pulled the cover, looked it over, and reinstalled. the clutch pulls fine, albeit a bit heavier with the new springs. I tried to rotate the piece that the cable hooks onto to get some more throw, but the results are the same.. any ideas? The TR650 cover has been used on the g650x before with no problems..
    edit: I should also mention that I've messed around with the cable adjustments at the lever as well.
  20. MJS
    MJS Long timer
    Dec 23, 2005
    3,046
    Since you say the clutch pulls fine but a bit heavier, I'll assume you can feel the proper resistance of the clutch springs. Did you soak the friction plates in oil before installing? I put them in a zip-lock bag of oil for a day before installing.
    keepshoveling likes this.
