BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. PaulyD
    PaulyD Been here awhile
    Dec 9, 2014
    178
    Correct, I can feel the resistance of the springs. I didn't soak them but for maybe five minutes... The clutch feels completely normal when pulling the lever, it does disengage somewhat, to the point where I can push the bike a bit, but definitely not completely disengaged
  2. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    2,142
    Герма́ния
    Did you put them in the right order ?
    Steel plate goes in first, a friction plate goes in last before the cover.
    keepshoveling likes this.
  3. PaulyD
    Dec 9, 2014
    178
    I did, the only thing I changed was I swapped the position of a steel plate. The spring length was the same, my thought currently is maybe the springs are just too stiff and not allowing the clutch to fully disengage.. If I have time tonight I may put the stock ones back in and try that
  4. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    5,037
    NYC
    Are you sure you have the clutch release fork lever on far enough back?
    Dutchgit likes this.
  5. PaulyD
    Dec 9, 2014
    178
    I certainly believe so, I played around with a few different positions, to get the farthest throw. I even unhooked the cable, moved it so I could get a pair of pliers on it to twist it by hand, twisted it as far as it would go and still nothing..
  6. PaulyD
    Dec 9, 2014
    178
    so, I pulled it apart again, the new springs were maybe twenty thou longer than stock, so I put the stockers back in even though that shouldn't have made a large difference.. I also double checked that everything was in the correct order.. reassembled everything yet again, and the same thing... I decided to fire it up in neutral to get oil flowing, and it seems fine once running, it can be in gear, pull the clutch and the bike pushes fine. strange. I think I'm going to put some miles on it and see what happens..
  7. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    5,037
    NYC
    Let us know if it ends up being fine after getting some more oil circulating. That'd be some interesting information. When I replaced my clutch plates I soaked them for a day before and didn't have the same issue.
  8. Butters
    Butters Kwyjibo Supporter
    Oct 10, 2008
    9,200
    NoVA
    I took my cover off to inspect it (was fine) and when I put it back on the clutch was dragging regardless of how I adjusted it. So I ordered a new cover, installed it, and it still was dragging. Turned out the throwout bearing wasn't seated properly. Might be your problem. I posted some pics about it in this thread a year or two ago.
    Edit: I forgot I had them on Picassa
    jonnyc21 and keepshoveling like this.
  9. PaulyD
    Dec 9, 2014
    178
    Will do! I plan on reinstalling the HD springs as well, so I'll put some miles on it, pull it apart and re inspect it when I put the new springs back in.
    very interesting! the clutch doesn't seem to be dragging unless it's not running, and has been sitting for a little bit. it shifts fine, and neutral is certainly easier to find than with the old cover. I did see a wear spot on the old cover, the bike only has 6k miles on it.
  10. Butters
    Oct 10, 2008
    9,200
    NoVA
    Yep. I don't know how wide spread of a problem it is, but it made my brain melt for awhile. My clutch had a very slight drag before I took it apart, which is why I was inspecting the cover. When I put it back together I clearly did something to unseat the bearing even more. It is a snug fit, but definitely not immovable. Even though I had the older style, it actually was in perfect shape. I guess the new cover is a good preventative measure, but I would have preferred to save the money until I needed it. On the plus side, I never would have found the unseated bearing.
    PaulyD likes this.
  11. jonnyc21
    jonnyc21 Trials Ninja
    Feb 8, 2011
    4,169
    Boise aria
    I had the same unseated bearing issue with my clutch as well as the clutch cover issue. Fixed both and love my clutch again. :thumb
  12. eaglescan
    eaglescan Borrego rocks
    Jun 17, 2009
    746
    Langley,B C
    I found the wear problem starts at about 25000 km. It was near impossible to see ,until measuring the hole . I went through 3 actuating shafts and 2 more years before finding the problem. Cover bushed and still good, now 750000 km.
    crash a-ron, PaulyD and Dutchgit like this.
  13. PaulyD
    Dec 9, 2014
    178
    My bike was getting a little tough to get into neutral every once in a while, and I came across the complete husky cover for just under $60 shipped so I couldn't pass it up
    crash a-ron likes this.
  14. jjmead1
    jjmead1 now THAT"S a bike!
    Sep 8, 2010
    879
    don't boulder my Golden, CO
  15. Yukon Ho!
    Yukon Ho! Vaccinated! But Canada no want our money Supporter
    Oct 2, 2011
    387
    Warshningtun
    Does the Husky (tr650?) cover require modifying the shaft? (...on an '07 XCo?)
    Where'd you get the cover, PaulyD?
  16. PaulyD
    Dec 9, 2014
    178
    nope! the TR650 cover is the exact same as the updated '09 xcountry cover, bolts right on, no mods needed at all.
    I bought it on eBay, used. luckily it included everything, so all I had to do was bolt it on and go. I took a few pictures I will upload in a day or two
    Yukon Ho! and crash a-ron like this.
  17. Reg York
    Reg York Boet
    Jul 17, 2016
    14
    South Africa (Port Elizabeth)
    Hi, something to check is a spring on the shaft they call a Diaphragm Spring, Our end of the world we have found that these need to be replaced especially when we have had issues with the covers and breaking shafts..... In South Africa this part cannot be bought separate but part of the clutch kit from BMW.... you guys may be more fortunate with the bigger markets......
    In My city of Port Elizabeth we are fortunate enough to have a guy who has become quiet inventive in reproducing/re purposing these which seem to be working.... at this stage...
    PaulyD likes this.
  18. treps
    treps Adventurer
    May 27, 2013
    13
    Sorted. Thanks all
    Reg York likes this.
  19. crash a-ron
    crash a-ron mmm...burnt steel Supporter
    Jan 11, 2006
    417
    The Great Pacific Northwet
    I am super curious how that pump works out! Seems like a great and way less expensive option than BMW. Is there a solution for the built in filter too??
  20. hansi
    hansi Teurer Abenteurer Supporter
    Jan 1, 2010
    1,335
    State of Jefferson
    Hi everybody, just bought a 07 X Challenge with less than 8000 miles on the clock. It is mainly going to be my wife's bike, who is a seasoned rider, coming from a Kawasaki Versys and Yamaha WR250R. Just wondering who is still making side racks for this bike to carry soft luggage (mosko moto scout panniers) ?
