BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. PaulyD
    PaulyD Been here awhile
    Dec 9, 2014
    178
    Hot rod welding, hepco Becker, and dirt bagz make standoffs. Congrats on the purchase!
    hansi likes this.
  2. snooker
    snooker AttitudeIsEverything
    Feb 19, 2010
    2,141
    Loveland, Colorado
    Mosko Moto Scout or Backcountry PANNIERS require racks that support ALL the weight of each pannier on each side, this is a lot more of a requirement than their Reckless 80 bag that is slung over the seat/top rack which takes most of the weight. Plus there are clearance concerns for sliding the MM Scout up. The HotRod was not intended for pannier weight, nor the DirtBagz. Investigate thoroughly, just saying it's not obvious.
    hansi and keepshoveling like this.
  3. jjmead1
    jjmead1 now THAT"S a bike!
    Sep 8, 2010
    879
    don't boulder my Golden, CO
    IT worked out well for one year. Then it failed. Mounted up pretty easily, not an exact fitment but so close. The bag pre fuel filter does not fit so well. Nothing that would cause me to want to spend BMW money on it. Plus that warranty was exceptional, and the customer service. The fuel filter itself is found cheaply enough, but only from europe. Found a company who will ship it and take care of customs for you, for near $60 total.
    crash a-ron likes this.
  4. PaulyD
    Dec 9, 2014
    178
    Can you explain how the hotrod welding xrack isn't designed for panniers? It says right on the website that it was designed around the macadam panniers, but suited for all kinds of soft luggage. It also connects to the front part of the subframe, as well as the rear, certainly looks plenty stout to support the Mosko panniers.
    http://www.hotrodwelding.nl/product.php?id=8
    Obviously the dirt bagz are just standoffs. Not trying to start a pissing contest, just curious why you say they aren't built to support panniers?
    Yukon Ho! likes this.
  5. Meriden
    Meriden Yea whatever
    Oct 26, 2010
    1,375
    In the garden behind the dacha
    With the Magadan, like the Dirtbagz, the weight rests on the seat via a harness between the two bags. The bag is attached to the rack only to hold it in place. Personally, I started with the Dirtbagz and didn't find them satisfactory. Since then I've used a Great Basin and now a Reckless 80 which looks to be the more practical adventure touring setup.
    Reg York likes this.
  6. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    2,166
    Герма́ния
    The Hotrod rack was indeed designed for the Magadan bags. The weight is spread over the whole rear of the bike. The rack might not be suited for the Mosko's.
    I have the rack and the Magadans.
  7. PaulyD
    Dec 9, 2014
    178
    Has anyone used a fender bag on their x? I'm thinking about trying one out but it looks like it would probably block the headlight pretty bad. Anyone have any experience?
  8. PaulyD
    Dec 9, 2014
    178
    I guess I'm just curious as to why they wouldn't work with a set of panniers that don't have the straps to go across the top of the bike. They look very stout, and built in a way to spread the load. I could be very wrong, I just wonder why they wouldn't work?
  9. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    5,398
    Mesa, AZ
    With the OEM fender, a fender bad is worthless, as it blocks the headlight and makes the floppy fender flop worse.
    PaulyD likes this.
  10. PaulyD
    Dec 9, 2014
    178
    I was afraid of that
  11. Dutchgit
    Jun 24, 2012
    2,166
    Герма́ния
    It might work with panniers (soft or hard) as I've crashed my bike on them quite a few times and they've held up very well.
    You might try and use a strap connecting the bags over the rack.
  12. Dutchgit
    Jun 24, 2012
    2,166
    Герма́ния
    Try an Acerbis fender. (85cc MX KTM +/- 2012 model) they come in various colours and are very strong. You need to drill two holes between the factory 4 but that's enough. Then you'll have space between the fender and the light for a bag.
    Kiharaikido likes this.
  13. PaulyD
    Dec 9, 2014
    178
    What did you do for the lower headlight mounts that attach to the fender?
  14. Dutchgit
    Jun 24, 2012
    2,166
    Герма́ния
    Nothing as I've got two XCountry's turned Challenge. The Country has a different headlight (mounting) so you'll have to improvise there.
    PaulyD likes this.
  15. Shmikes_1
    Shmikes_1 Perpetual Novice
    Jan 9, 2013
    54
    Ridey Bikes Moto
    Hey guys, quick question... I'm gonna install a usb port thingy on my handlebars before I head off around Europe for a month.
    I don't want to connect it directly to my battery as i'll likely drain it dry. The product i've ordered has a single usb port and a cigarette lighter port. I'd like there to be NO current draw when the key is off. Can i just connect it inline with the ignition cables?
    Cheers in advance..
    Shmikes
  16. Len
    Len Long timer Supporter
    Apr 3, 2015
    9,309
    North Alabama
    That would work, make sure you get a USB port that supplies 2.1 amps. I have a Samsung Galaxy 5 and it will barely stay charged running maps on a 1 amp USB. I'm in process of upgrading now.
    Shmikes_1 likes this.
  17. Shmikes_1
    Jan 9, 2013
    54
    Ridey Bikes Moto
    Cheers bud, so running it inline with the ignition switch isn't a bad idea electrically?...
    adventure5101 likes this.
  18. Len
    Apr 3, 2015
    9,309
    North Alabama
    No problem, 2 amps at 5 volts is less than 1 amp at 12 volts so it isn't much of a load in the big picture.
    keepshoveling and Shmikes_1 like this.
  19. Shmikes_1
    Jan 9, 2013
    54
    Ridey Bikes Moto
    Boom, thanks again.
  20. jjmead1
    Sep 8, 2010
    879
    Warranty fuel pump arrived. It is a different shape than the first, which is different from the OEM. The latest one included and new two wire plug, Neg and Pos to pump unit. It included a newer pre filter that seems to fit much better than the last, and a few rubber sleeves.
    I got creative with zip ties to mount it, as the included sleeves won't work for our application/oemfitment . Re did my redneckery and she fired right up!
