BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. Zac Cutler
    Zac Cutler n00b
    Sep 29, 2015
    6
    Columbia MO
    Sorry for the delay in getting back, finally back in town and have caught up around the house.
    In response to your questions:
    1.) Correct on the wire in question being "brown #4".
    2.) Looking at the setup again, I agree that it must not have been a short against the frame. Correct on insulating the bare wire before riding. I had stripped it back to get it fed through the plug but taped it up once all setup.
    3.) Didn't see a question to me here, but I will note that the wires inside my pump assembly did not have any signs of wear around zip ties or otherwise. Minus the hole in the top, the pump assembly looked good.
    For what it's worth, my bike has around 24,000 mi at this point.
    Reg York likes this.
  2. snooker
    snooker AttitudeIsEverything
    Feb 19, 2010
    2,141
    Loveland, Colorado
    Thanks Zac.
  3. octopusenvy
    octopusenvy gravel grommit
    Aug 29, 2012
    438
    Aotearoa, Te Hiku o Te Ika
    Awesome, I love this community! I know where Ventura is, and I might have something sorted from another inmate, but I will let you know in a PM if I'm still without a place to store 'Bernie'. Sorry I only saw this message now...
  4. jjmead1
    jjmead1 now THAT"S a bike!
    Sep 8, 2010
    879
    don't boulder my Golden, CO
    I'm over 50,000 miles on mine.
  5. tester1
    tester1 Adventurer
    Jul 5, 2016
    16
    looking for info on turn signal indicators. Right hand indicator flashes but the green light on the instrument cluster does not light up. Has anyone had the dash light fail or is it a possible bad wire somewhere between the switch and the light?
  6. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    2,142
    Герма́ния
    Forks are done now on both our bikes.
    Fitted all KTM axle nut as well. I've machined the end cap off so it doesn't keep water in it at the front one.
    And...... I picked up my Lynx fairing today ! Wooot wooot ! Only propped it up on the front fender here but you get the idea :D:clap
  7. snooker
    Feb 19, 2010
    2,141
    Loveland, Colorado
    Now that's a good idea. The one thing I didn't like. I put a black plastic cap over the right side but it really doesn't work well. Once again just shows I'm not a machinist so I don't think of these things... :)
    Dutchgit likes this.
  8. Dutchgit
    Jun 24, 2012
    2,142
    Герма́ния
    I'm not a machinist either but I'll have a go at almost anything given the chance :-)
    You could take it off with an angle grinder if you can work precise.
  9. snooker
    Feb 19, 2010
    2,141
    Loveland, Colorado
    What problem does this solve? Why would I want to do this between an XTank and the breather hose to the main tank? Or is there a good example of some kind of filter at the gas cap itself on the XTank? Seems like overkill or I'm missing something.
  10. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    5,363
    Mesa, AZ
    Or you could send them to me and I'll bore them out for you on the lathe.
    I have an extra that I could bore out and do an exchange program with.
    seasider and keepshoveling like this.
  11. Reg York
    Reg York Boet
    Jul 17, 2016
    14
    South Africa (Port Elizabeth)
    Have had a similar issue, cleaned the switch and sprayed some Q20, problem Was sorted, seems to appear when the weather has been hot and muggy.
    This might help could well be an issue on the instrument panel as they are inclined get moisture in them....
  12. Dutchgit
    Jun 24, 2012
    2,142
    Герма́ния
    I've often thought about this but never done anything about yet.
    There could get dirt into the X-tank while filling up, a paper filter would reduce the amount of dirt getting into the main tank.
    A Filter on the breather of the X-tank would be good too as the volume of fuel in both tanks will be replaced by outside air which will contain dust if you ride in dusty conditions.
    jonnyc21 and Zac Cutler like this.
  13. Meriden
    Meriden Yea whatever
    Oct 26, 2010
    1,368
    In the garden behind the dacha
    Rather than a fuel filter, I use a quick disconnect that shuts off on the tank side. With this the tank can be removed without spilling much fuel and the stock tank can still breath through the tube.
    m
  14. Meriden
    Oct 26, 2010
    1,368
    Okay guys, I think BMW "needs to be more explicit in step two." I'm adjusting the valves and the BMW DVD say to use a "suitable tool" to depress the bottom of the tensioner and then "secure it in place." It seems that both the BMW DVD and the zip tie method need to have the chain tensioner relaxed to work. I've been through Matt's page, F650, the BMW DVD and your tube. Good stuff all, but without a clear answer on this one issue. Any help is appreciated.
  15. gqelements
    gqelements Been here awhile
    Oct 26, 2012
    974
    T-Dot, Canada
    Just curious if anyone who has fabbed up their own fender eliminators could post up the drawings for their recipes?
  16. PaulyD
    PaulyD Been here awhile
    Dec 9, 2014
    178
    tail tidys? I posted a few pictures of the one I made on the last page or two. I still have my template if you would like a copy, one other person wants one as well.
  17. TobyG
    TobyG SlothRacing.eu - Travel and Racing Products
    Dec 27, 2011
    1,602
    Germany
    Just unscrew the tensioner. Or rather the bolt that's holding it in place.
  18. Meriden
    Oct 26, 2010
    1,368
    Trust me, I've been looking at that tensioner bolt behind the oil tank since I began the work. Since removing it is not listed as a step in the DVD, it is implied that there is an alternative. I just want to make sure that there is not something I'm missing before I start removing parts to get to the bolt.
  19. Dutchgit
    Jun 24, 2012
    2,142
    Герма́ния
    You'll have to get creative here. A Spanner ? Piece of wood ?
    You need to push the chain guide/tensioner in (so towards the oil reservoir) and block it from returning out so to keep tension off the chain.
    You could take the tensioner out but that requires removing the oil reservoir and that is something you'll want to avoid.
    Reg York and Meriden like this.
  20. Meriden
    Oct 26, 2010
    1,368
    Got it. I just had to up the force a bit.
    Dutchgit and Reg York like this.
