BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. PaulyD
    PaulyD Been here awhile
    Dec 9, 2014
    169
    Quick question, replacing the front sprocket, is the bolt right or left hand threads? Also, do you guys use any thread locker, and do you torque the bolt when tightening it?
  2. PaulyD
    Dec 9, 2014
    169
    Post up some pics but I would think around 6k maybe?
  3. mtncrawler
    mtncrawler Long timer Supporter
    May 17, 2003
    1,507
    Fort Collins, CO
    1) Right-hand
    2) I don't, but others I believe have used Loctite blue 242/243 (Semi-perm). Not sure what the service manual recommends.
    3) I do. But in a pinch you don't have/own a torque wrench, you could tighten (don't over tighten) - then ride your nearest AutoZone (or parts store) and rent/borrow one to torque (or do it before the job starts). I recently changed mine out on the road (far from home) and rented one - which cost "net" $0. Just had to put a deposit worth the tool while I borrowed for two hours.
    PaulyD and Reg York like this.
  4. PaulyD
    Dec 9, 2014
    169
    What do you torque it to?
  5. mtncrawler
    May 17, 2003
    1,507
    Fort Collins, CO
    I don't have my specs in front of me at the moment - but I believe it's 40 n/m. Other may need to chime in here....
  6. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    1,814
    Герма́ния
    I do it up tight by hand and ise one drop of Loctite. Have done it the same without Loctite for years without any ill effect though.
    PaulyD likes this.
  7. Reg York
    Reg York Boet
    Jul 17, 2016
    14
    South Africa (Port Elizabeth)
  8. Reg York
    Reg York Boet
    Jul 17, 2016
    14
    The Manual spec is 40Nm.... and Loctite 243 (Med)
    PaulyD likes this.
  9. BikerBobber
    BikerBobber Trying to get lost
    Feb 28, 2011
    1,306
    Seeleys Bay, Ontario
    Use the torque wrench....
    You'll get a very sick feeling when you feel it break off while you over tighten it... Ask me how I know....
    Bob
    Kiharaikido, Reg York and PaulyD like this.
  10. PaulyD
    Dec 9, 2014
    169
    Sounds good, I've been looking for something to use my new torque wrench on anyways
  11. BikerBobber
    Feb 28, 2011
    1,306
    If you don't like the filter, box it up and send her here
    Bob
  12. jamie92j
    jamie92j Been here awhile
    Oct 12, 2013
    200
    So I changed my front sprocket today
    The JT I had was a poor fit compared to a BMW, so I have decided not to use JT
    I now have a genuine BMW 15t front sprocket
    Does anyone know if there are any 14t genuine BMW sprockets that fit?
  13. tester1
    tester1 Adventurer
    Jul 5, 2016
    14
    I'm in need of a new handle bar. Do any of you have any thoughts on oem vs. aftermarket? Is there any size / bend that would be preferred? If I go aftermarket?
  14. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    4,769
    NYC
    Not according to maxbmw.
  15. PaulyD
    Dec 9, 2014
    169
    What about it didn't fit well? I'm getting ready to install a JT 14t myself
  16. jamie92j
    Oct 12, 2013
    200
    It was looser on the splines compared to a BMW sprocket
  17. tbarstow
    tbarstow Two-wheelin' Fool Super Supporter
    Jul 9, 2007
    4,799
    Mesa, AZ
    BMW does not make a 14T front sprocket for the X bikes.
    The JT spline fitment seems to come and go, some fit, some don't. Good that you checked it first. Too loose and you'll damage the splinea.
    Go to a 49T rear. Very similar gearing change and easier to do.
    Kiharaikido, BikerBobber and Reg York like this.
  18. tbarstow
    Jul 9, 2007
    4,799
    Mesa, AZ
    Aftermarket is less expensive. You can buy used handlebars for almost nothing to try different bends to find one that suits you.
    Remember that you have to pull the locating pins out of the BMW controls to use them on aftermarket bars.
    seasider likes this.
  19. jamie92j
    Oct 12, 2013
    200
    But do they make any others that fit, I.e sprockets from a g650, f650 etc can fit
    Any other 650 rotax run a 14t sprocket?
  20. tbarstow
    Jul 9, 2007
    4,799
    Mesa, AZ
    The X bikes and the new Sertao are the same engine. They have unique output shafts, so they do not have cross compatability with other rotax engines.
