BMW G650X Challenge Thread Index
Discussion in 'Thumpers' started by GB, Apr 24, 2008.
  1. Kiharaikido
    Kiharaikido Been here awhile
    Dec 22, 2016
    605
    Edit*
  2. Kiharaikido
    Dec 22, 2016
    605
    keepshoveling, eaglescan and Armyguy like this.
  3. Gravel Seeker
    Gravel Seeker Thomas
    Apr 27, 2002
    7,640
    Dreary old Norway, dreaming of adventures past
    Snake Oiler likes this.
  4. Meriden
    Meriden Yea whatever
    Oct 26, 2010
    1,195
    In the garden behind the dacha
    Go the the auto parts store and get an inline fuse to bridge the gap between the wires. Then you can pull the fuse if you need to leave the bike anywhere while you eat, etc. I think that TBarstow originally came up with that idea. It's worked for me while I had a ignition switch on order.
    m
  5. Meriden
    Oct 26, 2010
    1,195
    Ribfest BMW Rally is coming up in Tennessee the 19th-22nd. There will be at least one X there...
    Snake Oiler and Kiharaikido like this.
  6. Kiharaikido
    Dec 22, 2016
    605
    I just used male to female electrical connectors. Its easy enough to pull them apart.
  7. Wyocrawler
    Wyocrawler Been here awhile
    Oct 25, 2013
    669
    Marietta ohio
    Wish I could get away that weekend.
  8. Delta61
    Delta61 Been here awhile
    Dec 4, 2007
    359
    Southeast Alabama
    That will make Two of us as i will be in from SE Alabama. It will be easy to spot us as the Alabama Gang will have our usual camp spot half way up the meadow on the right. Lookin' forward to meetin' another X owner. Stop by and have a beer.
    Jim
  9. eaglescan
    eaglescan Borrego rocks
    Jun 17, 2009
    325
    Langley,B C
    Back to broken key wires. It already happened to me, stranded on the Apache trail. Could not find the problem, dealer did and changed the key base.
    So I was thinking of connecting a toggle switch into the 2 wires with a TEE connector, still using the key, but if the wire to key every breaks again, I should be able to use the toggle.
    Any comments?
  10. Dutchgit
    Dutchgit Completely clogless
    Jun 24, 2012
    1,510
    Герма́ния
    Strap the wire out of the base to the base/barrel with a zip tie. That should do it.
    You can very easily undo the plug and bridge the wires when you get this again anyway.
    eaglescan likes this.
  11. Snake Oiler
    Snake Oiler If the world didn't suck, we would all fall off
    Apr 22, 2016
    1,731
    Western Pennsylvania
    I agree with Dutchgit. But if you're that worried about it. In the old days on my Harley shovelhead, I mounted a push button switch under the seat and out of site. I still left the ignition switch and key in place just for looks. Anti theft and solved any problems. Plus if your key is in the original location you still have the steering lock.
  12. lolibater
    lolibater Northern California ST/ADV Rider
    Dec 23, 2016
    145
    Bay Area, CA
    So with no commercially available case covers out there these days, are people just riding off road with no case cover protection? I have searched high and low for options, even tried my hand at heat forming some Kydex which didn't go well. What have you guys done in that regard?
    I know touratech makes lower bars,but I have the SW motech upper bars and those mount to the same frame point that the touratech bars would.
    Ideas?
  13. gqelements
    gqelements Been here awhile
    Oct 26, 2012
    802
    T-Dot, Canada
    Don't overthink it. I've become a pro at dropping my bike and the case cover is just fine. If you are worried, the Scheffelmeier skidplate covers the bottom of the case just wonderfully (really protecting from any bottoming out or side rock impact). If you are SUPER worried, cut out a round or semi-circular patch from a sheet of thin of stainless steel and JB Weld it on the case. This works wonders to strengthen the walls of fragile cases on some KTMs.
    eaglescan and lolibater like this.
  14. lolibater
    Dec 23, 2016
    145
    Bay Area, CA
    Yeah my friend has a machine shop I might do that at. But that's what I was wondering; if most just don't think about it. If that's the case, I'll just ride as is with a tube of jb weld lol.
  15. eaglescan
    Jun 17, 2009
    325
    Langley,B C
    I used a piece of 16 ga aluminum , cut out a disc, and can be shaped with some hammering over a block of wood.
    JB weld it on. I used some silicone to hold one on, but it let loose after time, so JB now.
    lolibater likes this.
  16. Meriden
    Oct 26, 2010
    1,195
    I'll try to look you up. Hope y'all are getting through the weather okay. SE Alabama is on the dirty side. Hopefully far enough out to only catch some rain.
    m
  17. tbarstow
    tbarstow Two-wheelin' Fool
    Jul 9, 2007
    4,394
    Plattsburgh, NY
    Yes, discard the POS ignition switch and use a toggle or push button switch. I used a combination of unmarked toggle switches for the ignition and didn't bother with a key.
    eaglescan and Snake Oiler like this.
  18. Eldarog
    Eldarog Adventurer
    Jun 21, 2015
    17
    Russia, Moscow
    Friends!
    could you please provide names on what i can change OEM gear shift lever on my Xchallenge? my was accidentally get broken in the end of enduro day :(
  19. LostInTransit
    LostInTransit Been here awhile
    Sep 23, 2015
    356
    Leeds
    Dutchgit and Eldarog like this.
  20. LostInTransit
    Sep 23, 2015
    356
    Leeds
    For anyone interested the project continues
    Dave
    BearrrX, cgguy09, DGR and 10 others like this.
