Bmw k75 gsa
Discussion in 'Some Assembly Required' started by flipflopdog, Dec 8, 2014.
  1. flipflopdog
    flipflopdog Youth & Talent, no match 4 Old Age & Treachary
    Mar 27, 2011
    576
    Gateshead the Grim North of England...!!!
    Why thank you so much…….
    To be very honest, I've built a few bikes in my history but this one has got out of hand a tad. Only achievable by the mere fact that I met a guy who could turn my thoughts into a reality with his fabrication skills. Not long to go for some proper testing, family and work priorities delaying proceedings.....
    #81
  2. flipflopdog
    Mar 27, 2011
    576
    A little view from the cockpit...…. The auxiliary control pod housing the heated clothing/grips controls, altitude switch, fan override, 2 x 12v sockets, low fuel indicator and a spare switched 12v feed which rests under the seat waiting for a purpose....!!
    #82
  3. Eddieb
    Eddieb Long timer
    Nov 14, 2006
    1,571
    Hamilton, New Zealand
    Did you have to do anything besides a longer shock to get more ground clearance at the rear?
    #83
  4. flipflopdog
    Mar 27, 2011
    576
    It has a 50mm CNC spacer block between swing arm and bevel box and extended shaft which from a geometry aspect reduced ride height but the thing is the whole rear end is 'none standard' K75. It was fabbed to take the GS12 seat base plus luggage set-up. The Hagon shock came with several bottom mounts of varying lengths for ride height tweaking anyhow.
    #84
  5. flipflopdog
    Mar 27, 2011
    576
    And so it begins...……. This is gonna be painful but it has to be done, electrics is my thing but this will really test me getting these relay/ fuse blocks into place. IMG_5715.JPG IMG_5716.JPG IMG_5712.JPG IMG_5713.JPG
    #85
  6. Roofchop
    Roofchop Hands up mother stickers, this is a f**k up!
    Jan 9, 2016
    692
    Carool, NSW
    Excellent work!
    How come your mixing mil spec Cannon style plugs with "chocolate block" connections inside?
    There will be a good reason no doubt!
    Cheers
    Dave
    #86
  7. JimVonBaden
    Feb 11, 2005
    91,762
    Alexandria, VA
    Exterior plugs are watertight, inside doesn't require that? :dunno
    #87
  8. flipflopdog
    Mar 27, 2011
    576
    The choc blocks are not normal choc blocks. They have push on counter halves so you can pull apart and test without disconnecting individual wires plus for ease of installation. Two friggin days it has took me to cram that lot inside but it all works a treat. IMG_5787.JPG IMG_5799.JPG IMG_5782.JPG IMG_5790.JPG
    #88
  9. Roofchop
    Jan 9, 2016
    692
    Carool, NSW
    Nice one! I knew there was tech logic going on!
    Over on the Australian forum some (many) have a thing with bikes that have beaks....
    This beast out beaks them all!
    Cheers
    Dave
    #89
    flipflopdog likes this.
  10. flipflopdog
    Mar 27, 2011
    576
    That there beak hinges up to take a bedding roll, hence the forward lights.. A tad bonkers but heyho...!!!
    #90
    Roofchop likes this.
  11. tinwelp
    tinwelp Professional Idiot
    Dec 5, 2010
    731
    Deepest Southern France
    Hold on. Wait. "Altitude switch"... What?
    Please explain!
    Cheers... Paul
    #91
  12. flipflopdog
    Mar 27, 2011
    576
    The k75 American import version has a jumper plug for altitude riding, I mirrored that jumper using a switch, just broke the loom back found the wires and hacked in...
    #92
  13. Bonnie & Clyde
    Bonnie & Clyde Wishing I was riding RTW
    Jan 10, 2006
    4,077
    Gardnerville NV
    Really amazing craftsmanship
    #93
    msahern5 and flipflopdog like this.
  14. flipflopdog
    Mar 27, 2011
    576
    Again thank you, much appreciated
    #94
  15. flipflopdog
    Mar 27, 2011
    576
    So folks, first off I hope everyone is doing ok during these strange and uncertain times, I have found myself in the workshop almost every day and my 'K' project has benefitted as a result since all focus has been switched due to the cancelled full TCAT ride/trip due in June. Here She is.... 20200405_181828.jpg 20200405_181619.jpg 20200405_181657.jpg 20200405_181716.jpg 20200405_181741.jpg 20200405_181640.jpg
    #95
  16. JimVonBaden
    Feb 11, 2005
    91,762
    Alexandria, VA
    That has got to be the most insane K75 I have ever seen! So much work! I look forward to your ride report!
    #96
    Jeff Sichoe and Ginger Beard like this.
  17. damurph
    damurph Cold Adventurer
    May 2, 2012
    3,629
    The far east of the far east of North America
    What has the fuel capacity been upped to and what range do you figure you can do? Impressive build.
    #97
  18. flipflopdog
    Mar 27, 2011
    576
    It's around 40l/ 42l so around 400 miles @ 40mpg
    #98
    snake-eyes likes this.
  19. Lajning
    Lajning Been here awhile
    Apr 22, 2017
    119
    Sweden
    That's just bonkers! If you convert it to run on hydrogen, hey presto: new Mars rover!
    Is that an air snorkel going through the windscreen?
    #99
  20. flipflopdog
    Mar 27, 2011
    576
    Yes and the tank...!!!
    Lajning likes this.
