BMW R NineT Urban G/S
Discussion in 'Road Warriors' started by wegimex, Nov 8, 2016.
  1. danketchpel
    danketchpel Long timer
    Jun 1, 2010
    4,662
    Camarillo, CA
    That's pretty close to how I did it, though I didn't wait the 15 minutes, more like 5 minutes or so as I readied the front chock stand to hold it upright. Next time I'll wait a bit longer.
    Thanks a bunch for the official reference!
    It seems my guestimate was pretty close.
    I went and dug up that page from the OM and the level was at the "min" when I added and now it's at "max". I will probably drain about just a bit so it's at say 3/4 the way up between min and max and take the filling slower next time, especially now that I have a pretty good idea of what amount might be needed.
  2. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    18,306
    Zer0-Zer0-Zer0-Zer0
    No worries... Knowing that Min to Max is half quart/liter, I'd guestimate how much to add and follow guidelines on the side of 1 qt oil bottle to add approx. amount I'd need to be at ~half way mark on the oil sight glass... :thumb
  3. Zoul
    Zoul No Comment Supporter
    Feb 7, 2002
    1,503
    Back In Santa Rosa, CA
    Oh, no... This is turning into another oil thread...:becca
    vagueout likes this.
  4. sizzlingbadger
    sizzlingbadger Boxer Fan
    Jan 28, 2013
    680
    New Zealand
    Just picked up my Urban GS, I was given the tool kit separately along with paperwork and spare keys etc. but I can't see a space under the seat for it. The manual does show it but there are other electronic sensors/connectors in that area so I'm not sure it will fit !
    danketchpel likes this.
  5. atctag
    atctag Adventurer
    Oct 11, 2010
    48
    Washington DC area
    I was just under there today attaching a light bar. I stuck my tools under the plastic cover. Since those are very few tools they fit fine.
  6. Zoul
    Feb 7, 2002
    1,503
    Mine sits in the bottom drawer of my toolbox in the garage.
    sizzlingbadger likes this.
  7. sizzlingbadger
    Jan 28, 2013
    680
    New Zealand
    I managed to fit the tool kit in the rear section by taking the C spanner out and leaving it at home.
    I removed the charcoal canister today and moved the starter relay up into the tray under the seat.Then I removed the Rox Risers and fitted a Quadlock for my phone.
    MAM X-Heads and Aliexpress hand guards ordered today.
    Bike is a 2019 model and has 4,200km on it, still has original TKC80's, receipts for 3 services despite hardly being used. Loving it so far.
  8. danketchpel
    Jun 1, 2010
    4,662
    Camarillo, CA
    I'm thinking to remove my canister and probably the flapper valve later.
    I'd like to know more about moving the starter relay, do you have any pictures?
  9. sizzlingbadger
    Jan 28, 2013
    680
    New Zealand
    The OEM muffler is pretty loud, it sounds great. I was just wondering if it had been modified by the previous owner as I can straight through it, no baffles ?
  10. sizzlingbadger
    Jan 28, 2013
    680
    New Zealand
    I re-used the rubber hose from the canister to extend the one from the tank (originally went to the canister) down the left hand side of the frame. You just cut the U shaped ends off. One hose has a larger end and will fit over the hose from the tank. Then it will clip in next to the other hose from the tank so that they both exit under the bike. One is a breather and the other is the over-fill.
    Check out the video below for the starter relay relocation. I just used a 5mm drill and a cable tie to hold it down to the plastic pan.
    heyyrick and danketchpel like this.
  11. danketchpel
    Jun 1, 2010
    4,662
    Camarillo, CA
    Thanks for the info and video link!
  12. danketchpel
    Jun 1, 2010
    4,662
    Camarillo, CA
    No, it's stock. The OEM muffler is straight through, the primary "silencer" is the CAT in the header pipes and the flapper valve which has a mind of it's own as to when to flap and quiet things down. In some ways it's kinda cool that BMW tried to use the flapper to meet sound regs while still allowing for a nice sounding stock system. I have no plans to change my pipe, but I might well remove the flappy valve mostly in the interest of simplifying / cleaning things up. I don't want it any louder as I'm pleased with how it is now. It's not a high priority right now.
  13. sizzlingbadger
    Jan 28, 2013
    680
    New Zealand
    Thanks for checking. It does sound good, I was just surprised that BMW got away with it. I'll be removing the flapper shortly just to tidy it up really.
    knary likes this.
  14. New englander
    New englander Adventurer
    Dec 3, 2012
    102
    Springfield, MA
  15. tennessee thumper
    tennessee thumper Long timer Supporter
    Nov 3, 2007
    2,874
    Arkansas Ozarks
    nicely packed/prepped
    well done
    New englander likes this.
  16. Baloo
    Baloo Itinerant jackass Supporter
    Jan 12, 2006
    8,348
    I cover the waterfront in Norfolk Virginia.
    Well packed. The symmetry is magnificent.
  17. danketchpel
    Jun 1, 2010
    4,662
    Camarillo, CA
    A little upgrade today. I really wanted the adjustability and when I took the stock unit off I realized how stiff it's "setting" was!
    Baloo likes this.
  18. vagueout
    vagueout Long timer
    Mar 3, 2010
    5,231
    sydney, east
    I removed my steering damper for a see how it goes effort, never went back on, just handles better without the stock item.:*sip*
    Baloo and knary like this.
  19. knary
    knary sunshine and puppies
    Jun 27, 2002
    30,153
    portland, or
    I’d put it up there with most any other upgrade for improving the feel of these bikes.
  20. LVmotorcop1
    LVmotorcop1 Been here awhile
    Sep 9, 2014
    149
    SE Michigan
    I couldnt resist and had to buy one. I have only added some bar risers and a Unit Garage rear rack that will mount a top case from a GSA.
    Been looking at some engine guards but with the Option 719 valve covers, it may be tough. They stick out a bit more.
    Has anyone noticed the turning radius is not as tight as it should be? I havent measuerd it yet but my GSA turns tighter. Come to think of it., my dept RTP may have a better radius. Will give it a go on the course and will report back.
