BMW R****R Thread
Discussion in 'Road Warriors' started by ninepeaks9, Nov 28, 2012.
  1. EZ OUT
    EZ OUT Sneaky Slow Cheap Bastid
    Dec 13, 2004
    937
    NE Ohio Vacation land of the Midwest
    Nossir
  2. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    14,846
    Zer0-Zer0-Zer0-Zer0
    Did you mean that you change the oil in FD when you replace the tire? :hmmmmm
    You can't be possibly changing the FD every 5K mi... :eek7:eekers
    SmittyBlackstone likes this.
  3. Lead Wrist
    May 26, 2007
    14,846
    Zer0-Zer0-Zer0-Zer0
    You were 2/3 there so it would've been a good opportunity to do it as you were changing FD oil...
    Oh well, your labor is free so you'll do it some other time... :lol3
  4. EZ OUT
    Dec 13, 2004
    937
    It was serviced by PO prior to its hibernation so it should be fine until i hange tires
  5. Lead Wrist
    May 26, 2007
    14,846
    Zer0-Zer0-Zer0-Zer0
    No worries - not that many owners do lube the splines and, since splines are prone to rust, it's good to inspect/lube splines sooner rather than later... :thumb
  6. EZ OUT
    Dec 13, 2004
    937
    I
    Should have said the prior owner had the dealer service it.
  7. Lead Wrist
    May 26, 2007
    14,846
    Zer0-Zer0-Zer0-Zer0
    Lubing splines isn't part of regular maintenance intervals so one extra reason to get to them sooner rather than later - ymmv...
  8. Idrinktea
    Idrinktea Adventurer
    Dec 11, 2015
    27
    Dublin, Ireland.
    I'm not sure if this is of interest to anyone but I have had to replace one of the fuel quick disconnects on my R1150r. I have looked into replacing them with metal connectors but couldn't justify the price. Anyway I found LPG connectors on fleabay for less than €8 a pair. They seem to work fine and the plastic cover fits over them. IMG_20210612_123911.jpg
  9. Idrinktea
    Dec 11, 2015
    27
    Dublin, Ireland.
    IMG_20210612_123919.jpg I have also worked out if you need to replace a brake light switch, and the ABS on(off) isn't an issue. You can fit a hydraulic switch meant for a Suzuki 10mm X 1. This one was about 5mm too long so I cut it and dressed up the end with a grinder and a thread file. It cost around €6 or €7 on fleabay but I have seen them on amazonn
  10. eric_the_bald
    eric_the_bald Gnome
    Feb 15, 2002
    471
    Colorado Springs, CO
    After reading some of the debate about yellow vs. other spring suspension, I’m ready to dive in to the yellow kool aide.
    Where are you getting Ohlins for a 2009 R1200r?
    Thanks !
  11. Lead Wrist
    May 26, 2007
    14,846
    Zer0-Zer0-Zer0-Zer0
    Debate? There's no debate about it - yellow springs (and shocks) FTW... :D
    You could've read actual testimonials even from those demoing 2 otherwise identical bikes, back-to-back, one w yellow Ohlins and one w KLR silver springs - difference was night-and-day... :-)
    One of the sources for Ohlins: Ohlins, Pro Pilot Ohlins Suspension, Ohlins Wholesale and Retail Supplier, Service and parts, WP, MX, Gncc, Showa , KYB Pro Pilot Suspension, Ohlins , Suspension, WP, KYB, Showa, Ktech, Elka, Fox , Shocks, Parts, Service WP, MX, Gncc, Showa , KYB
  12. jeffyjeff
    jeffyjeff Adventurer
    Oct 6, 2013
    47
    left of center
    Suggest you reverse one of your connectors (end to end) to avoid misconnection the next time you remove and install your tank.
  13. eric_the_bald
    eric_the_bald Gnome
    Feb 15, 2002
    471
    Thanks! I’ll look into Pro Pilot…Ohlins USA no longer lists my ‘old’ steed.
  14. south east okie
    south east okie Adventurer
    Dec 17, 2020
    65
    ringold ,oklahoma
    2002 R1150R input shaft question.
    I picked up a '02 R1150R a couple months ago with 36k on the clock. After reading about all the input shaft problems . my question is. Does anybody know what % of the 1150r have this problem?
    Looks like some do , some [most???] don't .
  15. David R
    David R I been called a Nut Job..
    Oct 16, 2009
    3,913
    Hamlin NY
    I had a 2000 R1100RT which has the same transmission as the 1150
    At 100,000 miles the input shaft was looking good. @ 136,000 there were almost no splines left, as in paper thin,
    I have pictures of both.
    SO since my bike was purchased used, the first 100,000 miles were easy on the splines.
    If you want to spend at least 8 hours working on your bike, go for it.
    David
  16. Idrinktea
    Dec 11, 2015
    27
    Dublin, Ireland.
    I figured that out too. I was going to put a little paint on one line to avoid confusion but I fitted the lower clamps with the screw under the clamp and the upper one with the screw over. Only the female connector has a cutoff so they have to be that way round.
  17. elmontanero
    elmontanero Practicing...
    Aug 4, 2006
    2,977
    San Diego, CA
    any link to those?
  18. Idrinktea
    Dec 11, 2015
    27
    Dublin, Ireland.
    Type this in ebay. 2 sets 8mm Gas Hose Copper Nozzle Quick Release Connector for Motorhome BBQ Nice
  19. elmontanero
    Aug 4, 2006
    2,977
    San Diego, CA
    Idrinktea likes this.
  20. south east okie
    Dec 17, 2020
    65
    ringold ,oklahoma
    David , are you saying 8 hrs to look at the splines?
