BMW R100GS & R100, bolt on Brembo 4 Piston Caliper Upgrade
Discussion in 'Vendors' started by One Less Harley, Oct 10, 2010.
  1. chlowden
    chlowden Adventurer
    Feb 11, 2019
    13
    Paris
    Thank you for the confirmation
  2. chlowden
    chlowden Adventurer
    Feb 11, 2019
    13
    Paris
    I have made the modification using a R1100GS caliper and the brembo PS13 master cylinder. I have purged the system completely, set he brake lever screw as far possible, but I am getting a very soft lever action with the lever touching the handle bar. The caliper has been completely rebuilt and I don't have any leaks. Would anyone have any other suggestions? Many thanks
  3. windypoint
    windypoint Been here awhile
    Feb 4, 2012
    718
    Walla Walla
    Sure sounds like air in the system to me.
  4. chlowden
    chlowden Adventurer
    Feb 11, 2019
    13
    Paris
    I have had 2 different mechanics drain the system with the same result. They both said that I need a bigger master cylinder, maybe a 15mm but I am not so convinced.
  5. windypoint
    Feb 4, 2012
    718
    Walla Walla
    I had a hard time getting air the air out. After force bleeding from the bottom, I wire tied the brake handle to the grip and let it set over night. Next day all was good and firm.
  6. chlowden
    chlowden Adventurer
    Feb 11, 2019
    13
    Paris
    After 24 hours of having the lever cable tied to the hand grip, I have tangibly better result. I have not tried to lock up the front wheel as it has been raining these last few days, but I am confident that I have a safe braking system. So thank you so much for this simple suggestion. In the end, it is a real time saver.
    windypoint likes this.
  7. One Less Harley
    One Less Harley OH.THAT'S GONNA HURT
    Nov 16, 2006
    6,643
    Bowling Green, Ky
    4/19/2019- I have one set with pads on hand.
  8. gordongraham
    gordongraham Been here awhile
    May 13, 2013
    384
    East Wemyss, Fife, Scotland, UK
    what thickness of material needs milled off the mounting tab? I have a couple of spare 1100 calipers here (in Scotland) and would like to mod one to fit my r100gs
  9. Goomicoo
    Goomicoo Rubber Cow
    Nov 4, 2010
    950
    Here & There
    On my R80ST I left 8.5 MM on the tabs and milled the mounting side of the tab. (the side contacting the fork)
  10. One Less Harley
    Nov 16, 2006
    6,643
    Bowling Green, Ky
    the ST is a completely different animal....not really the subject of this post.
  11. One Less Harley
    Nov 16, 2006
    6,643
    Bowling Green, Ky
    sent you the info
  12. gordongraham
    May 13, 2013
    384
    thanks OLH
  13. pfestus1
    pfestus1 Slash 5er
    Dec 4, 2001
    748
    Roanoke , Virginia
    One Less,
    can you hook me up with a 4 pot caliper? I recently bought a 1992 R100GSPD. Can you supply the stainless brake line also? Thanks
  14. One Less Harley
    Nov 16, 2006
    6,643
    Bowling Green, Ky
    No lines on hand but can get them...banjo fitting at MC? Stock length?? Silver or black color? Do you want pads?. I have two calipers but they need to be machined. PM me
  15. One Less Harley
    Nov 16, 2006
    6,643
    Bowling Green, Ky
    7/26/2019- I have one set of calipers with pads on hand. If needed I can get a braided line in about 1 week.
  16. pfestus1
    pfestus1 Slash 5er
    Dec 4, 2001
    748
    Roanoke , Virginia
    THANKS One Less Harley! I got my 4 pot Brembo and new brake line installed and bled today. Process went well. No bleeding issues. Prior to starting the install I performed an unscientific test so I could compare stock setup with the new caliper. On the street in front of my house I rode the GSPD at 25 mph, and at a crack across the street I braked hard with just the front brake. Bike stopped in about 22 feet. Then after the install I re-enacted the test. This time the bike stopped in about 20.5 feet. Brake feel is much more solid. My guess is about 35% better braking. I feel it is definitely worth doing. Brembo 4 pot.jpg
  17. One Less Harley
    Nov 16, 2006
    6,643
    Bowling Green, Ky
    thanks for the evaluation, should preform better once pads bed in....
  18. bykpimp
    bykpimp Live and let ride
    Oct 18, 2006
    1,439
    Santa Cruz Ca
    Caliper and pads wanted 92 R100GSPD
  19. One Less Harley
    Nov 16, 2006
    6,643
    Bowling Green, Ky
    8/28/2019-None left, but three available soon....
    bykpimp likes this.
  20. One Less Harley
    Nov 16, 2006
    6,643
    Bowling Green, Ky
    pfestus1 likes this.
