BMW R1200GS as project bike
Discussion in 'GS Boxers' started by turtlespeed, Aug 31, 2019.
  1. turtlespeed
    turtlespeed Been here awhile
    Feb 15, 2016
    376
    NJ
    Dear All, I have been thinking of buying a R1200 GS for some time. And this showed up on Craigslist near me. I have never repaired a motorcycle, but am mechanically & electrically ok.
    https://newyork.craigslist.org/jsy/mcy/d/jersey-city-2005-bmw-r1200gs/6968429634.html
    $1500
    I am ZERO knowledge about the R1200GS, so request more experienced people to chip in on the viability (effort and cost, if possible per issue) for fixing this bike. Plan to wok over in the winters...
    Things that need fixing:
    1. ABS pump/servo is out. Brakes work fine manually but the brake light routes through the ABS and therefore doesn't flash when brake is applied.
    3. No spare key.
    4. There is a short somewhere in the fog lights.
    6. Starter relay spliced in.
    7. Front fender has a big chip.
    9. Tank was repainted by previous owner.
    10. Swingarm bolt sheared (but has been ridden like this for 40K miles).
    12. Ring antenna needs to be installed.
    14. Bark Busters have a broken attachment.
    15. Rear fender guard missing.
    Idea is to get it fixed to do MABRD next year.
    TIA.
  2. JimVonBaden
    Feb 11, 2005
    91,396
    Alexandria, VA
    I'm very familiar with the R1200. Good bikes, easy to work on. If you can't hear it run, and can't verify that it will, I would give no more than $750 for it. Running and ridable, $1000. Need lots of work, but could be done pretty cheaply.
  3. JimVonBaden
    Feb 11, 2005
    91,396
    Alexandria, VA
  4. turtlespeed
    Feb 15, 2016
    376
    NJ
  5. JimVonBaden
    Feb 11, 2005
    91,396
    Alexandria, VA
  6. GB
    GB . Administrator Super Moderator Super Supporter
    Aug 16, 2002
    67,923
    Moved. What a mess!
    MGV8 likes this.
  7. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    6,965
    Zer0-Zer0-Zer0-Zer0
    While this may not be the perfect bike complexity-wise for you to start grinding your mechanic's teeth, with good literature, factory service manual and decent tool set you should be able to address majority of the issues except the first one...
    Servo ABS pump out will pose few chosen directions:
    - find out if anyone can service it and have it repaired;
    - get a replacement one (won't be cheap);
    - attempt to remove ABS altogether - GS of that vintage was available without ABS brakes so ABS bike can be "downgraded" to non-ABS bike due to failed pump...
    As for brakes currently working "fine" and yet ABS servo pump is out - well, that's one big load of crap to put it mildly. Failing ABS pump will leave residual braking only which will require extreme effort in other to stop the bike - equivalent of trying to turn the wheel of a car without engine running (ie. no power steering)...
    Not impossible to made right but you'll have quite few road-blocks to overcome - good luck!! :thumb
  8. JimVonBaden
    Feb 11, 2005
    91,396
    Alexandria, VA
    The ABS pump out means it is no longer there. It is well documented that the brakes work fine bypassed. The key is to set up the brake lights to work. Here is how: https://advrider.com/f/threads/how-i-removed-servo-iabs-brakes-on-my-05-clap.993562/
    #8
  9. PerazziMx14
    PerazziMx14 Been here awhile
    Oct 9, 2011
    932
    Hard to believe there is a short in the fog light wiring after seeing how neat and tidy the wring is under the seat. The seller must be an automotive electrician.
    #9
