1. eNewsletter Sign Up
BMW's new EnduroGuard suit
Discussion in 'Equipment' started by Sailorlite, Oct 28, 2016.
  1. rider1150gsadv
    rider1150gsadv Long timer
    Oct 6, 2003
    8,666
    Ft Likkertail , USA
    Do NOT use regular laundry detergent, but a product like Nikwax or similar!
    Steve G. likes this.
  2. LopezXC
    LopezXC Been here awhile
    Sep 24, 2015
    118
    Madrid
    Didn't know about that... And it's easy to find in Madrid. Thanks!
  3. rider1150gsadv
    Oct 6, 2003
    8,666
    Ft Likkertail , USA
    You're welcome!
    I also have the EG suit and after washing don't use a dryer, just drip dry and spray with the BMW waterproofer when the suit is almost dry to keep the suit in shape..
  4. PRW
    PRW living @ 11.5740741uHz
    Mar 3, 2003
    4,163
    North Branch of the Chicago River
    So only use the Nikwax Tech Wash and not the Nikwax TX.Direct afterward, but use the BMW waterproofer instead?
  5. rider1150gsadv
    Oct 6, 2003
    8,666
    Ft Likkertail , USA
    Yes that is what my dealer told me to do.
    SmittyBlackstone and PRW like this.
  6. RoundTrip
    RoundTrip Unintentional deerslayer Supporter
    Sep 11, 2006
    3,627
    Sunny Tucson AZ
    Either way will be fine.
    bnsutton likes this.
  7. rider1150gsadv
    Oct 6, 2003
    8,666
    Ft Likkertail , USA
    If you have done that and it works, than yes either way will be fine.
  8. RoundTrip
    Sep 11, 2006
    3,627
    Sunny Tucson AZ
    I have. It was. :-)
  9. toramorgan
    toramorgan Adventurer
    Aug 30, 2018
    42
    Barcelona
  10. Sailorlite
    Sailorlite Long timer Supporter
    Feb 18, 2006
    1,218
    So. Calif.
    BMW, in the little booklet that comes with the EG, recommends washing with "BMW Motorrad functional detergent", p/n 83 19 2 408 161. And then spraying it with "BMW Motorrad waterproofing agent, p/n 83 19 2 408 162.
    What's interesting to me is that the Nikwax site specifically says don't use a "detergent" but instead use a soap product before spraying with their own waterproofing agent.
  11. Candubrain
    Candubrain Been here awhile
    Jan 13, 2018
    448
    Kincardine, ON, Canada
    Except the waterproofing agent is not available in Canada. According to my dealer, Cdn environmental protection prevents the import.
    What is a suitable alternative? My dealer couldn't recommend one
    thanks
    brian
  12. RoundTrip
    Sep 11, 2006
    3,627
    Sunny Tucson AZ
    NikWax Tech wash will do the trick in one step. I have never used anything else on any of my BMW gear including my ComfortShell and my EnduroGuard.
    Candubrain likes this.
  13. PRW
    Mar 3, 2003
    4,163
    Nikwax Tech Wash instructions say that you must re-waterproof after washing, with Nikwash TX.Direct, after the garment is fully dry. This implies that, while Tech Wash is gentle to the waterproofing agent, it likely still removes some of it and thus, the fabric needs to be resealed to be fully waterproof again.
    Sailorlite likes this.
  14. RoundTrip
    Sep 11, 2006
    3,627
    Sunny Tucson AZ
    OK. I don't but you can for sure.
  15. Sailorlite
    Feb 18, 2006
    1,218
    So. Calif.
    The Nik products seem to be highly recommended and are easily available on Amazon.com and elsewhere. However, in my case, the BMW rep suggested I use only the BMW products if I wanted to remain "eligible" for their warranty consideration - so I did just that but have not yet ridden the jacket in rain. This was in response to my complaint that the jacket was not waterproof.
  16. rider1150gsadv
    Oct 6, 2003
    8,666
    Ft Likkertail , USA
    The inconsistency of waterproofness or water resistance of this suit is amazing to me. Some, like myself so far, are bone dry in deluges, while others are soaked in a drizzle..:scratch
    SmittyBlackstone likes this.
  17. LopezXC
    Sep 24, 2015
    118
    Madrid
    I can tell you that all my buddies here in Spain are absolutly happy with waterproofness. Even those living in north Spain, where only see the sun on tv.
  18. Patch
    Patch Long timer
    May 4, 2011
    2,512
    Southwestern New England
    :scratch
    You complained that its not waterproof but have not ridden in rain?
    NikWax products are fine. The key is that you use a non-detergent cleaner. The TX Direct essentially replenishes the efficiency of a fabrics DWR coating after cleaning, thats why they (Nikwax) recommend it.
  19. Sailorlite
    Feb 18, 2006
    1,218
    So. Calif.
    After I complained, BMW told me to "maintain" the EG using their two products, which I have now done. No rain here so I don't know yet whether their products worked - I hope so and am optimistic.
    Patch and SmittyBlackstone like this.
  20. cblais19
    cblais19 Long timer
    Nov 3, 2017
    2,625
    VA
    Just make sure you’re using the Nikwax spray on DWR, not their wash-in one. The latter is meant for hard shell jackets that don’t have a moisture wicking inner layer like motorcycle jackets do - you don’t want the mesh that’s supposed to be wicking sweat away to be water repellant :p.
    I’m assuming the BMW branded spray-on DWR product uses hydrofluorocarbons, which are extremely toxic (so spray outside!), hence why it’s not available in Canada. Nikwax and a couple others do not.
    Just a note, DWR has nothing to do with waterproofness really, the membrane sandwiched between the face and inner fabrics handles that. However, the pores which are meant to expel moisture vapor from inside the jacket (the “breathes” part of waterproof/breathable membranes) can’t do so if the face fabric is wetted out. Some non-membrane products rely entirely on a DWR coating, hence the “water repellant” statement you see on some garments.
    Oh hey, happy 1k posts to this thread.
    vanha and SmittyBlackstone like this.
