BMW's new EnduroGuard suit
Discussion in 'Equipment' started by Sailorlite, Oct 28, 2016.
  1. rider1150gsadv
    rider1150gsadv Long timer
    Oct 6, 2003
    8,496
    Ft Likkertail , USA
    From what I gather, wash the suit with tech wash and treat with Nikwax TX direct for improved waterproofness..
    IMHO, using regular laundry detergent is what kills the fabric's waterproofing as it doesn't rinse out cleanly enough...YMMV
    tupdegrove and SmittyBlackstone like this.
  2. cblais19
    cblais19 Long timer
    Nov 3, 2017
    2,436
    VA
    None of that affects the waterproofing, which is provided by the membrane laminated between the layers. "normal" detergent can clog the pores of ePFTE membranes of older designs, which reduce the ability for moisture to transpire through from the inside out, and also cover up the external factory applied DWR. Likewise, DWR attempts to prevent "wetting out" of the face fabric to allow moisture to get out.
    Failures of waterproofing on a suit like this would likely be from seam tape failures, water-resistant zippers being overwhelmed (they're not using fully waterproof zippers on this suit, hence the flaps/gutters), or water pressure potentially overcoming the membrane's rating.
  3. rider1150gsadv
    Oct 6, 2003
    8,496
    Ft Likkertail , USA
    ^ I see.. Well so far my suit is still dry for now... Keeping fingers crossed..:patch
    SmittyBlackstone likes this.
  4. Sailorlite
    Sailorlite Long timer Supporter
    Feb 18, 2006
    1,210
    So. Calif.
    The little BMW manual that comes with the EG says to wash with their Functional Detergent 83.19.2.359.101 (and then spray on Waterproofing Agent 83.19.2.359.102). Nikwax says one of the benefits of their Tech Wash product is that it's a soap, not a detergent. So you might conclude that the Tech soap product is not recommended for the EG.
    Here's a theory I haven't seen mentioned: the gray EG fabric is more waterproof than the black fabric. In my case I replaced black with gray under BMW warranty but haven't had a chance to definitively test the gray. The black was not waterproof and couldn't be made so with the BMW products above.
  5. RoundTrip
    RoundTrip Unintentional deerslayer Supporter
    Sep 11, 2006
    3,617
    Sunny Tucson AZ
    Interesting how fit is different for each of us. I am 5'8" and weight 180 and wear a 54 jacket.
    tupdegrove likes this.
  6. rider1150gsadv
    Oct 6, 2003
    8,496
    Ft Likkertail , USA
    The soap based Nikwax rinses out quit well when you use an extra rinse cycle. I agree that a detergent leaves no residue and that BMW wants you to use their stuff, but having used Nikwax for many years on much of my outdoor gear I'm quite pleased with the results including previous BMW gear. YMMV
    PS: I have the grey EG suit, maybe your theory about the black fabric has merit, as so far in 18 months my suit hasn't leaked...yet...:D
  7. RoundTrip
    Sep 11, 2006
    3,617
    Sunny Tucson AZ
    I have had my black jacket since they first came out. No leaks. Washed with Nikwax products. No issues.
  8. Candubrain
    Candubrain Been here awhile
    Jan 13, 2018
    432
    Kincardine, ON, Canada
    I've washed mine twice with Nikwax, but haven't re-applied the TX. No issues riding in hard rain for hours. Very happy with that aspect of the suit
  9. Steve G.
    Steve G. Long timer Supporter
    Oct 30, 2004
    16,659
    West is the Best
    Now owned 1.5 years, i've had a chance to use my EG through every form of weather. My experiences, aligned alongside the jacket's purchase price, has left me disappointed. Disappointed not in the jacket, but in me, for choosing the jacket without the usual research I do, 'crazy ass research' as my sister calls it, on most every product I end up buying. i'm sure this very well made product works great for many, but it's not working for me, and i'll end up selling it.
    For me, it's not a comfortable jacket.
    It's collar is abrasive on the neck, it's stiffness refuses to soften up even after 1+ full riding season. It's so stiff, it hooks on the bottom of the helmet, often preventing me the ability to shoulder check on the street. I almost always use my fleece neck gaiter, with top neck fastener unfastened, to prevent rub rash.
    It's not a warm jacket in temps below 55F. As it does not have any kind of warmth liner built in or zip in, i have to use one of my several liners made for warmth, including a heated vest with heated collar. The problem with this is, the cut of this jacket around the shoulder, upper arm, and underarm, is a tight fit, for me anyways, with my big hockey shoulders, and allows a minimum layering without literally cutting off blood circulation to the arms. This is really the kicker for me, as with a jacket of this price, i should have taken notice of the fact that there was no warmth liner engineered into this format. It's velcro wrist strap is very inadequate, comes loose often. It should be 4 times the width, much like my 15 year old BMW Streetguard which still hooks up without coming loose.
    It does have very good points. It is still completely waterproof, and it's waterproof aspect on surface 1 [outside surface] is still of the highest priority for me with its eventual replacement. It is very well made, and it's fabric and armour are of such a heavy duty nature and build quality that I have no doubt will serve me well should I drop my bike at speed on the street, and still be in perfectly good shape.
    Alas it wasn't meant to be. Another learning experience that I really learned from.
  10. Kmendez
    Kmendez Been here awhile
    Dec 6, 2017
    213
    Lighthouse Point Fl.
    Finally got my Alpinestar air vest working with my enduroguard jacket
    Bought the racing unit
    Had the sleeve unit with the lights from one of the jackets removed and attached to top of the vest as seen in picture.
    I wore the combo air vest jacket on my last 3 k miles trip from Fort Lauderdale to Pennsylvania.
    It’s a snug fit without removing endutoguard jacket back protector but not uncomfortable.
    Heat wise wasn’t any worse than without it (airvest)
    The beauty is when off road can disconnect air vest but open front Velcro’s so bags don’t deploy in case of minor fall.
    Also you can switch programs from street to racing with the help of computer
    With the racing algorithm bags can deploy two times
    With street only once but also protected against rear impacts in case someone rear ended you on a stop sign etc
    Overall very happy with setup I can wear the air vest with my enduroguard and rallie jacket
    View attachment 1933657 View attachment 1933656
    Valentino likes this.
  11. rider1150gsadv
    Oct 6, 2003
    8,496
    Ft Likkertail , USA
    Looks like a good set-up. :thumbup Your attachments however give me a error code.....
  12. Kmendez
    Dec 6, 2017
    213
  13. Kmendez
    Dec 6, 2017
    213
    Here are the other two pics
    rider1150gsadv likes this.
  14. SidewinderX
    SidewinderX Hey, watch this! Super Supporter
    Nov 3, 2009
    2,316
    NW North Carolina
    Best suit I have ever owned!!
    I82l8 and SmittyBlackstone like this.
  15. toramorgan
    toramorgan Adventurer
    Aug 30, 2018
    40
    Barcelona
    Hi,
    I need to repair my enduroguard pants. I used them with my Husky (wrong decision) and I burned them around the inner part of the right ankle. They were too close to the exhaust collector.
    Since the hole is quite big, I do need to use some fabric. I guess it’s going to be quite difficult to get schoeller dynatec fabric.
    Taking them to the dealer seems a waste of time.
    What would you recommend?
  16. Nickhob
    Nickhob Armchair adventurer
    Nov 7, 2013
    1,502
    Nyon, Switzerland
    SmittyBlackstone and toramorgan like this.
  17. toramorgan
    Aug 30, 2018
    40
    Barcelona
    Thanks Nickhob.
    I totally agree. It’s easy to buy a piece of Cordura 1000d but I can’t find Schoeller’s fabric.
  18. 3Putt
    3Putt Been here awhile
    Sep 21, 2007
    848
    Colorado Springs, CO
    Could someone please tell me how these fit length wise compared to other BMW pants? I think I remember trying these on and they seemed short.
  19. RoundTrip
    Sep 11, 2006
    3,617
    Sunny Tucson AZ
    Unless you want to buy a couple of thousand yards I don't think Schoeller is going to open an account for you. As @Nickhob said, a piece of black cordura in that spot will do the job.
  20. Candubrain
    Jan 13, 2018
    432
    What about a patch of leather similar to what is above the hole?
    I"m wearing a 106 size trouser and jacket, with 36" arms and legs. Length is perfect
    Side note, my dealer replaced my trousers as there were some quality control issues (few threads back)
    All is good again
    brian
