    Dismiss Notice
BOOM! a Grom Clone
Discussion in 'Electric Motorcycles' started by brian72, Jan 2, 2016.
  1. BobDz
    BobDz Adventurer
    Dec 23, 2017
    21
    Chicago area
    With all those cells, what will be your end voltage? I wanted to get a controller that was more than I needed. I was lucky that it fit. With work being slow, I was able to weld on the mounting brackets and paint them. Hopefully the wiring will go easy.
  2. roadpupp
    roadpupp Adventurer
    Jan 22, 2012
    13
    New haven CT
    BOB-
    Should be 83-84v . Each cell measures 7.6v. I have a Lithium battery charger made for 72v lithiums. I am planning to use that to slightly under charge the pack of 11. It would be perfect for 10 cells but I figure since I have it, the extra cell will give me more range and by not topping off the pack (for now) I should be ok until I get a BMS installed.
    Open to any suggestions about how to charge a nominal 83 V pack of Lithiums!!
  3. Gfranqui
    Gfranqui n00b
    Oct 16, 2020
    2
    Florida
    Noob here. I want to thank all you who have contributed to the site and to this topic. Recently upgraded from a Lectric xp electric bike to the BD 578z to commute to work about 9miles each way and contribute to the environment. I Bought it from safer wholesale. Remarkably positive experience although they lack product knowledge, that's why I'm here. The motor is a QS Motor 72v1980W2020070060, 72V 50a controller, dc rated for 60 and 72v. Does 20-25mph on the first setting, 28-30mph on the second setting and tops around 37-38mph on the third setting. Here comes the question. Can I over volt to 84v without upgrading anything? Could I use the same charger since it says 88v on the screen? I know this topic has been discussed a couple of pages back but wanted to know if someone had done it recently. Thank you kindly for your patience.
  4. roadpupp
    roadpupp Adventurer
    Jan 22, 2012
    13
    New haven CT
    Franqui-
    I don't get 40MPH on my Grom Clone. I had the same motor and set up (stock from Belmonte bikes). I was planning to add two 12V batteries to my set up but before I did, I ripped it all apart. I heard anectdotally that the new controller may not work at 96v. A few newer purchases said it just wouldn't go with an overvolt.
    That said, there are many controllers out there more powerful than the stock one.
    I would try it but then again you may "let the magic smoke out" and fry the controller.
  5. Gfranqui
    Gfranqui n00b
    Oct 16, 2020
    2
    Florida
    Thank you for responding so quickly. Coming from an ebike is an improvement and is fairly quick for my commute. I may just leave it stock and replace the batteries higher ah SLA batteries or 72v lithium when the time comes. I haven't been able to register it yet I'm waiting for the certificate of origin to go to the DMV. How many miles were you getting from a full charge. Good luck with your build
