Bringing a R850R back to life!
Discussion in 'Some Assembly Required' started by scrminbanshee, Oct 3, 2018.
  1. scrminbanshee
    scrminbanshee Ready to travel
    Apr 14, 2008
    935
    puyallup wa
    No the one in the tool kit works great just want a socket for the tool box.
    Finally got the fireplace installed! That only took a year! Looking forward to projects this winter now!
    #61
    hitmanh, TonyKZ1 and JimVonBaden like this.
  2. Roadracer_Al
    Roadracer_Al louder, louder, louder!
    Aug 5, 2007
    2,507
    Oakland, CA
    :lurk
    #62
  3. scrminbanshee
    Apr 14, 2008
    935
    puyallup wa
    Got the transmission today! Completely rebuilt, gears were in great shape all new seals and a deep cleaning. Looking forward to Sunday, supposedly a big storm so I should be able to spend the whole day in the shop.
    Next question is does anybody have any suggestions on cleaning these? I hit it some with a scotchbrite pad. Also any tips on cleaning the injectors?
    #63
  4. Richarde1605
    Richarde1605 Long timer
    Jan 1, 2015
    7,132
    QLD Australia
    That's what I was going to say, but then again most don't probaby have lathe access, and a box of odd mismatched sockets to use. Fun to make a custom tool ;-)
    Sent from my SM-G950F using Tapatalk
    #64
    scrminbanshee likes this.
  5. scrminbanshee
    Apr 14, 2008
    935
    puyallup wa
    Well after getting roped into helping my buddy finish insulating his master bedroom I got an afternoon of work time in. First off cleaned and lubed everything. The drove shaft was covered in rust, took alittle while to get it all cleaned up. Then onto mounting the transmission!
    Then on to the starter and sarter cover. This was really uneventful. The cover needs some love. I need to find a deal on a clean used one or possibly repaint.
    After that in struggled with the swing arm. I couldn’t for the life of me get the driveshaft to hook into the rear u-joint so I pulled the final drive. Once that was off it was easy to put it all back together.
    I mounted the tire to see if there was any play and luckily there’s wasn’t. I’m pretty sure the seal on the crown bearing is shot? But I want to ride it and see where oil comes out at. I’ll prolly ride about 500 miles after this is back together then do a full fluid change.
    #65
  6. scrminbanshee
    Apr 14, 2008
    935
    puyallup wa
    Then it was time for the rear sub frame to go back on and then fitting Airbox, inner fender, fuel lines, fuse box, shock....
    Note to self, air box before shock...
    The bike came along way, I’m one o ring on the injector away from being able to hear it start. It does kick over really nicely tho! I also need to address the Airbox it’s a nice shade of grey instead of black. Maybe armor all? Lol idk.
    The wire harness was a mess so I had to sort that out. I’m alittle confused on what these two connectors are for. I’m not sure if I’ve ran them to the right place but this seems like where they wanted to go.
    Anybody got any ideas???
    #66
    Eddy Alvarez likes this.
  7. Whale Rider
    Whale Rider Been here awhile
    May 16, 2010
    625
    DownUnderNZ
    #67
  8. JimVonBaden
    Feb 11, 2005
    91,762
    Alexandria, VA
    For the airbox, a light sanding and paint. Or, I have been successful with simple black shoe dye.
    #68
    Richarde1605 likes this.
  9. scrminbanshee
    Apr 14, 2008
    935
    puyallup wa
    Got a few mins tonight on the bike! Fixed the wiring harness finished installing the pressure regulator to injectors! Turn the switch and...... nothing not a peep. No fuel coming out the lines nothing no fuel pump kicking on. Disconnected the lines and nothing then all of the sudden fuel just came pooring out. Tapped the back of the fuel pump and now it just makes a chunk sound. Also realized that I installed the pressure regulator upside down. Any body have any thoughts? I think the fuel pump is gunked up, any thoughts on how to clean it? Is there a rebuild kit, or do you just buy a new one? I saw on beemer boneyard that they have two options anybody with any experience?
    Jim, I didn’t think about shoe polish but that sounds like it would do the trick!
    #69
  10. JimVonBaden
    Feb 11, 2005
    91,762
    Alexandria, VA
    For the fuel pump. hit the ground and hot with 12V, then reverse the polarity and do it again. Do it several times to break it loose. Often, if fuel sits in it for a while, it gunks up the pump. This can break it loose.
    BTW, looking good! :thumb
    #70
    Eddy Alvarez and scrminbanshee like this.
  11. scrminbanshee
    Apr 14, 2008
    935
    puyallup wa
    Should I pull it out of the fuel tank? Do I really need to flip the pressure regulator?
    #71
  12. scrminbanshee
    Apr 14, 2008
    935
    puyallup wa
    #72
  13. scrminbanshee
    Apr 14, 2008
    935
    puyallup wa
    After further consideration the pressure regulator is pointed in the correct direction. So I don’t think it was installed backwards, the manuel shows the longer arm flipped from the way it is on the bike.
    #73
  14. JimVonBaden
    Feb 11, 2005
    91,762
    Alexandria, VA
    You can try it in the tank. You will know if it works by the sound. Stuck it clunks if anything. Broke loose it makes a whirring sound.
    Yeah, you can't get the regulator in backwards of your uel lines will be on the wrong side.
    #74
  15. scrminbanshee
    Apr 14, 2008
    935
    puyallup wa
    I tried your method today Jim, and nothing so I thought I would pull the pump out. Its in ruff shape I’m going to need a new one.
    So off to beemerboneyard I go. Anybody have any experience with their two different kits they off?
    #75
  16. scrminbanshee
    Apr 14, 2008
    935
    puyallup wa
    Also thought I’d try some plastic restorer and this stuff brought the plastic right back!
    #76
    TonyKZ1 and Richarde1605 like this.
  17. mr bones
    mr bones Been here awhile
    Feb 14, 2010
    429
    Lake Macquarie NSW
    Nice
    #77
  18. JimVonBaden
    Feb 11, 2005
    91,762
    Alexandria, VA
    #78
  19. scrminbanshee
    Apr 14, 2008
    935
    puyallup wa
    #79
    JimVonBaden likes this.
  20. AZ Pete
    AZ Pete Been here awhile
    Mar 11, 2013
    186
    looking good!
    Sent from my iPad using Tapatalk
    #80
