Bringing the color back to sun faded plastics
Discussion in 'Thumpers' started by markk53, Dec 30, 2008.
  1. markk53
    markk53 jack of all trades... Super Supporter
    Dec 20, 2007
    20,165
    Delaware Ohio
    My KLX has some pretty bad sun fade on side covers. I am about to do some new graphics, but the fade will be some issue.
    I am aware of Krylon's Fusion paint, so I don't need that suggestion. I am looking for a method besides painting.
    I have wondered if anyone has ever used heat to bring back color - does it work and what is used?
    The other possibility is some sort of buffing. Anyone done that?
    I'm open to hearing about anything, but paint. I already know about paint and don't need information about that. Don't take it that I rule it out, I just don't need the information.
  2. kruzuki
    kruzuki Gear in the Machine
    Apr 2, 2008
    1,045
    Toronto, ON
    The problem with fading is that the sun has actually bleached out the color from plastics so the color is gone; you can't really 'bring it back'. Paint or replace plastics, they're not that expensive.
  3. Racerman27410
    Racerman27410 Been here awhile
    Jun 25, 2008
    751
    Greensboro NC
    sand off the oxidized top layer of the plastic using fine grit sandpaper.
    propane torch...... dont hold it too close or in one spot too long!
    the plastic will shine like new money!
    a heat gun will probably give the same effect with less risk of melting the plastic.
    KOokaloo! :norton
    Frank
  4. GordMounce
    GordMounce Been here awhile
    Dec 1, 2005
    189
    Calgary, Alberta
    Maybe mine weren't too far gone, but on my old KLR there was a lot of bleaching in the green plastic. It looked really dated. But it actually came back to good as new with a bit of Armor All. I was as surprised as anyone.... Anyway, worth a shot.
    If that fails - I agree, painting infused plastic with Krylon looks like shit. Might as well just replace the pieces. They're cheap enough.
  5. Yossarian™
    Yossarian™ Deputy Cultural Attaché
    Jul 9, 2007
    12,841
    the 'Ha
    I've used a heat gun to experiment on my KLR's faded plastics. It does bring back some color and shine.
  6. crazybrit
    crazybrit Defying any self identifying Super Moderator
    Mar 16, 2006
    9,447
    Portland, OR
    This is what I used on my 08 KLR also. Don't use too much heat, move the gun around constantly and don't touch the plastic until it's totally cooled. Obviously make sure it's thouroughly clean before you start.
    The blue coloured plastics on mine had been whitened by some cleaning agent the previous owner used. Was almost perfect after.
  7. Jack D
    Jack D Been here awhile
    Sep 3, 2008
    207
    Albuquerque
    I had a faded green KLR that also had white streaks where the plastic had been stressed. I used a heat gun on the white streaks to restore SOME of the green color. You must be careful as it appeared to me that the green would not return util the plastic was on the verge of liquifying. The only thing I found that helped to restore the fading was Sumner 210. This is a cleaner/protector for windshields. I bought mine through Tulsa Windshields. I could not find it locally but that is normal in New Mexico.
  8. jonpcovington
    jonpcovington Long timer
    Mar 22, 2006
    1,061
    Northern NV
    I have had some success with drenching the plastic in Bel-Ray 6-in-1. It also softens dashes and seats. seems to restore some of the volatiles to plastic that UV bleaches out. Spray it on and let it sit, spray again, etc.
    #8
  9. NOTAR_520
    NOTAR_520 Been here awhile
    Jun 17, 2008
    602
    Salt Lake City
    Before you break out the heat gun or Propane torch,
    Linseed oil and mineral spirits in a 50/50 mix, apply twice then armor all. It's worked great for me on sunfaded red plastic on a KLR. If needed, you can use a green scratch pad LIGHTLY to remove any old polish or treatment.
    #9
    Clointy McFlofton likes this.
  10. markk53
    Dec 20, 2007
    20,165
    Delaware Ohio
    You obviously don't know about KLX650C plastic - unobtainable new and very rare used. That's why the question. Like I said, I know I can paint it as last ditch. So I'm reading on...
    But thanks for the input. I do appreciate it and am not dissing you by any stretch. I only wish I could use your "replace" suggestion. I may on the fenders, but even then I am limited to black, white, and green for the KLX, that's what has been made for the 300, which is a bolt on. I've thought about doing the black, having red/black combination, because I'd like to have the Maier MX style rear fender over the "broken leg" look of Kawasaki's rear fenders... Just looks old and clunky.
    Again, thanks for the input.
    Respectively,
    klx678
    #10
  11. crazybrit
    Mar 16, 2006
    9,447
    Portland, OR
    Hmmn. Belray Oil, linseed oil and mineral spirits. Lots of good ideas to try here. :thumb
    #11
  12. LILBIT
    LILBIT Ride you must.
    Oct 17, 2007
    1,675
    Lake Placid, FL
    Being how hard it is to get replacements try the heat gun in a hidden spot first. It works pretty good but if you get a spot too hot it will leave a mark,blister. The second you see the gloss show up move the gun fast.
    2000 grit sand paper and plastic buffing compound should work great but i haven't tried it. You have to polish plastic at a super low speed or it will blister. I'd start with 600 and get the big uglies off before going to a finer paper.
    #12
  13. fixer
    fixer KLR-riding cheap bastard
    Oct 9, 2003
    7,439
    Lost Wage$, NV
    i've seen people dye gray rifle stocks black with Rit fabric dye.
    dunno about other colors... but black dye should cover up almost any other color.. it's cheap, won't flake, simple to do... i'd use a Rubbermaid or Sterlite tote to dye the plastics in.
    #13
  14. DirtyDog
    DirtyDog Omnia mea mecum porto Supporter
    Apr 27, 2007
    13,719
    Tulsa... it's OK
    Dang, that's an interesting suggestion, fixer. Wish I'd heard it before I spent several days painting mine black. I'd like to see some images of dyed plastic though.
    #14
  15. deadbird
    deadbird Very Large Bird
    Jun 14, 2002
    153
    santa cruz,ca
    Use "pro honda spray cleaner and polish".
    I have also gotten good results covering the plastic part with a paper towel soaked in the stuff to marinate the part.
    #15
  16. Clointy McFlofton
    Clointy McFlofton n00b
    Dec 20, 2019
    3
    Boston, MA
    I'm coming in very late on this, but I want to thank NOTAR_520 for the linseed oil & mineral spirits tip he proferred 12 years ago! My KLR650 (see avatar) had turned light pink over the years and his suggestion really improved the look. Not totally back to stock, but looking really good nonetheless. Much appreciated!
    #16
    pvwheeler likes this.
  17. AloneInTheHills
    AloneInTheHills Been here awhile
    Apr 23, 2019
    678
    Nevada, USA
    Check this video (half way in). Dry wall sander and a buffing wheel...
    #17
  18. MOTOS and TACOS
    MOTOS and TACOS Adventurer
    Dec 11, 2012
    44
    Iowa
    I used the Sand, heat gun, and polish method on my baked KLR. Doesn't look quite like a new bike but they turned out pretty damn good and they were very, very bad.
    #18
  19. Clointy McFlofton
    Dec 20, 2019
    3
    Boston, MA
    Wow, yours was even worse than mine and looks great! Nice to see the before and after.
    #19
  20. Gibster
    Gibster high desert roamer
    Mar 29, 2014
    188
    Reno, NV
    Used Pledge furniture polish on a KLR. Worked good and lasted quite a while. There is these wipes too, but no experience with them. IMG-1230.jpg
    #20
