Broke off a sprocket bolt, looking for some advice (KLR650)
Discussion in 'The Garage' started by Kino, Feb 10, 2021.
Tags:
  1. Kino
    Kino Adventurer
    Oct 8, 2018
    42
    Europe
    Broke off a bolt on my rear sprocket while tightening. How would you fix this ?
    first pic is the back and other pics are front.
      File size:
      293.5 KB
      148
      File size:
      279.6 KB
      149
      File size:
      286.1 KB
      144
      File size:
      336.7 KB
      142
  2. trials935
    trials935 Been here awhile
    Sep 21, 2011
    501
    Southwest Ohio
    Little bit of heat from a propane torch and a pair of vice grips, should come right out.
    Ducky 149 and SmittyBlackstone like this.
  3. H96669
    H96669 A proud pragmatist.
    Nov 20, 2009
    6,428
    Hiding off Hwy 6, B.C.
    Stud not bolt.Heat it and use the ViseGrips on what's left of the stud.
    Heat as in over 350/400F in case of Loctite?
    But 7 left out of 8? Should be plenty?:-)
  4. Kyron
    Kyron Purveyor of Thneeds
    Jun 11, 2007
    1,477
    Phoenix Arizona ATR > Pacifica Ca PMA
    That’s what I was going to say :jack
    But yeah, plenty of heat and vice grips should do it
    Plan B is to use a small drill from the back side
  5. roger123
    roger123 Long timer Supporter
    Jun 23, 2007
    2,548
    VA Beach, VA
    Dude, it's a KLR, you're good, what, 25Hp??? LOL
    I'd either go with a nice new set of vice grips and a ton of heat (thread locker) or grind a slot in it and use a very large perfectly fitting screw driver (with a wrench/ vice grips on the shaft) in the slot with a lot of heat.
    When you get it out ask yourself, "Self, why did I break this stud?"
    SmittyBlackstone likes this.
  6. Beezer
    Beezer Long timer Supporter
    Oct 26, 2004
    10,956
    Anchorage, formerly Spenard (hub of the universe)
    they are installed with thread locker.... needs heat to remove. the nuts had locker too, and they need heat too. as above Vicegrips will do it. re-install with locktite red
  7. Wasser
    Wasser Spilt my beer Supporter
    Oct 31, 2009
    9,625
    Colorado
    Tack weld a nut to the broken off stub of threads sticking out. Use a socket to remove afterwords.
    It will come right out. Done it a bunch of times on exhaust manifold bolts in aluminum heads. The heat from welding loosens it up and the nut provides grip for a socket.
    wee-twin, tbarstow, Plaka and 2 others like this.
  8. veetwo _tls
    veetwo _tls RENOVATIO:
    Nov 14, 2005
    2,879
    THE MALLEE OUT BUSH IN Sth Oz
    Heat & stud extractor
    #8
  9. veetwo _tls
    Nov 14, 2005
    2,879
    if all fails drill from back with a "COBOLT drill bit"
    #9
  10. KirkN
    KirkN Long timer Super Supporter
    Mar 25, 2010
    4,707
    Northeast Orlando
    What @H96669 and @Kyron said: don’t bother to do anything. 7 outta 8 will be fine forever! :D
    #10
    Kyron likes this.
  11. KirkN
    Mar 25, 2010
    4,707
    Northeast Orlando
    Wow, really!? I’ve never yet had a bike that used threadlocker that need heat on sprocket bolts! And, OP said he broke it while installing it, not while removing.
    #11
  12. Beezer
    Oct 26, 2004
    10,956
    don't have to use heat on blue Locktite.... hell of a lot easier on red locktite if you do. there are parts on BMWs that used locker that is stronger the Locktite red ( Locktite makes some too) these you HAVE TO use heat or the threads will pull out
    I didn't say anything about why the stud broke.
    and I will repeat, the nuts have (red) thread locker from the factory. I've owned 3 KLRs, one I bought new
    #12
  13. dtysdalx2
    dtysdalx2 Just send it!
    Aug 1, 2004
    29,606
    Moneyapolis, MN
    Right hand drill bit through the back side since it's a through hole. Heat and penetrant first of course.
    #13
  14. Kino
    Kino Adventurer
    Oct 8, 2018
    42
    Europe
    Thanks, i got this fixed :)
    #14
    KirkN likes this.
  15. KirkN
    Mar 25, 2010
    4,707
    Northeast Orlando
    What technique? We gots to know!!
    :D
    #15
    Kyron and dtysdalx2 like this.
  16. dtysdalx2
    Aug 1, 2004
    29,606
    Moneyapolis, MN
    Yeah, buying a new hub doesn't count. Or getting a machine shop to do it.
    Bonus points if you used your teeth. :D
    #16
  17. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    4,692
    North of North Plains
    Well we know it wasn’t with a welder because, well, because KLR.
    #17
  18. Kyron
    Jun 11, 2007
    1,477
    We are waiting ....... :wave
    #18
  19. KirkN
    Mar 25, 2010
    4,707
    Northeast Orlando
    @Kino yer killin’ us down here! :lol3
    #19
  20. roger123
    Jun 23, 2007
    2,548
    VA Beach, VA
    Those are studs set in the hub and nuts hold on the sprocket. They’re not bolts, I think he snapped the stud while tightening the nut.
    #20
