Broken inner clutch case and water pump with mystery floating pieces
Discussion in 'Dakar champion (950/990)' started by tksmith, Oct 18, 2019.
  1. 3legs
    3legs Real men ride sidecars Supporter
    Oct 3, 2007
    2,013
    Adelaide,South Oz
    I know I maybe "clutching" ( pardon the pun ) at straws but have you had the clutch basket off yet.
    That broken piece looks like it might be from the back of the basket.
    At least take the plates out for an initial inspection. Can't hurt.
    #21
  2. badmanners
    badmanners Umm, yeah, no.
    Nov 28, 2008
    611
    Sydney, Australia
    Yep. That second pic of the "Unidentified Fcuked Object" looks to have a couple of gear tooth imprints on it.
    Good luck!
    #22
  3. tksmith
    tksmith Another GS Freak
    Jan 16, 2007
    1,206
    Peachester State Forest..Usually :-D
    Yep 3legs that was my first port of call. Maybe the oil pump drive or something. Have the Granddaughter over today so sheds out of bounds :lol3
    Tomorrow night if its not too hot I will tear the clutch basket out and have a look. It must be from that side of the motor as I can't see how anything could migrate from the internal main cases or the alternator/starter case side. Not something that size approx 30mm x 10mm x 3mm and bent to shit :imaposer
    #23
    3legs likes this.
  4. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    4,498
    Here and There
    Be keen to hear what you discover when you get to dig deeper.
    #24
  5. tksmith
    Jan 16, 2007
    1,206
    Thats a great idea and I would Whodatschrome but how would one do that?
    #25
  6. Whodatschrome
    Whodatschrome Long timer
    May 4, 2015
    3,010
    North of North Plains
    I have no idea. Maybe get a moderator to move it for you? I don’t know how to contact a moderator either...
    #26
    lentil likes this.
  7. sages
    sages Been here awhile
    Sep 23, 2008
    334
    Perth, West Australia
    post something nasty or pornagrphic.
    Or hit the contact link at the bottom of each page
    #27
    Whodatschrome likes this.
  8. tksmith
    Jan 16, 2007
    1,206
    Just did that thanks sages, see what happens. Cheers mate.
    #28
  9. lentil
    lentil King of the Dad Joke and Senior Status Legume Super Moderator
    Sep 1, 2006
    13,269
    Not Gunnedah
    we contact you :D
    #29
    Team Vegas and nk14zp like this.
  10. lentil
    Sep 1, 2006
    13,269
    Not Gunnedah
    here would you like it TK ?
    #30
  11. tksmith
    Jan 16, 2007
    1,206
  12. lentil
    Sep 1, 2006
    13,269
    Not Gunnedah
    #32
  13. tksmith
    Jan 16, 2007
    1,206
    Legend, thanks mate.
    Hopefully someone may shed some light on this. I'l try get back to the shed tonight and pull the clutch basket out. Might find something broken in behind there Oil pump drive gear maybe?? She was running fine though, no oil light just hot?
    #33
    lentil likes this.
  14. Whodatschrome
    May 4, 2015
    3,010
    You might get more traffic if you change your thread title around some. Using key words in the title; such as broken, failure, cracked, loud band, and blood are all good ones to incorperate.
    #34
  15. 3legs
    Oct 3, 2007
    2,013
    Adelaide,South Oz
    So what was the verdict with the broken part?
    #35
  16. tksmith
    Jan 16, 2007
    1,206
    Good point Whodatschrome, done :-)
    #36
  17. tksmith
    Jan 16, 2007
    1,206
    Still not been out in the shed. Weekend job I think.
    I'll keep ya posted
    #37
    3legs likes this.
  18. uk_mouse
    uk_mouse Aquatic adventurer
    Jul 20, 2006
    1,942
    UK
    Have you looked at the cam drive gears in the heads?
    The damage to the casing behind the impeller looks like the balance shaft has shifted? I'm not sure what else could exert the force to crack the case like that. But the balance shaft can't move due to the weights and sprockets on either end. So if it has moved, you need to check the main cases for damage around where the shaft bearings are.
    My guess is something broke in the head, and the debris got caught in a cam chain and applied to the balance shaft at high speed :(
    Why a hardened steel component would break in the first place is a mystery though.
    I had a similar problem, in my case it was a cam chain guide that snapped, the plastic fragment got stuck in a cam chain, and caused it to jump a few teeth. Still got that engine in bits, really must get around to doing something with it...
    #38
  19. DirtyADV
    DirtyADV Long timer
    Jan 13, 2007
    4,237
    SWEDEN, Norsjö
    Steel band on clutch basket was my initial guess even if it looks like the piece had some holes drilled into it.
    And not sure if the early baskets had that?
    And there should be alot more pieces since engine cover is off.
    Sprag bearing? But that is on the other side of the engine.
    Hope we get an update soon.
    /Johan
    #39
  20. tksmith
    Jan 16, 2007
    1,206
    DirtyADV I think you have it. You beat me to it. A mate and I did another look through the Service Manual and I think this is what I'll find when I get over the shed and pull the basket out
    It matches the piece I have albeit chewed up. :dirtdog
    #40
    sidetrack one likes this.
