broken petcock
Discussion in 'Thumpers' started by bEnt_bars, Sep 17, 2006.
  1. bEnt_bars
    bEnt_bars Been here awhile
    Jan 23, 2006
    143
    Vancouver
    Anyone else manage to mess this up like I did????? :huh
    Guess I dropped it just right....the metal plate was jimmy'd up to keep on movin and complete the ride
    Broken cock:
    Well aside from the gouged tank and busted cock I also gained a scratched side plate & fairing as well as breaking the buddy peg bracket....but the bike now looks broken in :1drink
  2. rjf
    rjf SBS's #1 fan in January
    Nov 21, 2004
    4,378
    Gosford, NSW, Aust. Scrambler, 640Adv, 300EXC
    looks broken in, and chick's dig scars !!:deal
  3. KTMax m AL
    KTMax m AL Fagarwe tribal member AL
    May 31, 2006
    303
    "Halfway" to heaven in Eastern Oregon.
    Your jimmy'd fix looks just like the change I made on my 06 before I even rode it
    for the first time. Kinda dumb place to hang a bulky fuel valve if ya ask me.:tb
    Now - your fall is proof positive. :cry
    Poor location for a fuel valve.
    I just run a line between the 2 inner shutoff valves with a FloPro quick disconnect
    on each side and but a "T" in the middle to the carb. You do
    loose the reserve supply but I use the lowfuel light on
    the speedo and reset one of the trip milage displays to 0 when I fill up as I know
    close to number of miles I get on a tank and then just select the reset
    trip odo when I need to check. I have not been stranded yet. :kurt
    Why didn't KTM but in a 90 deg curved stand pipe and mount that thing on
    the inner side of the tank where it should have been?????????? :shog
  4. meat popsicle
    meat popsicle Ignostic
    Feb 9, 2004
    14,643
    Circumlocution Office of Little Dorrit
    I have read of a couple of folks who managed to get the petcock. It makes most worry, but it is fairly rare. There are aftermarket parts that protect it, but most are expensive. Check the index for them.
  5. sbruton
    sbruton Been here awhile
    Jul 25, 2006
    100
    Calgary, AB
    I had an '01 Adventure and broke the petcock off TWICE!! :huh
    The first time it happened I was in the middle of nowhere. I ended plugging the hole with some old tire tube (gasket) and a rectangular piece of plastic that I cut out of a Coke crate. I punched 2 holes into with my leatherman tool, and bolted it up to the tank. Then I folded the gas lines over and zip tied them --> No leaks!
    It worked great and I rode the bike for months like that. Just used the valve on the right side of the tank. You have to tip the bike over occassionaly if you're getting low on gas but no big deal.
    The price of the OEM petcock was RIDICULOUSLY over priced - big surprise. I found an aftermarket petcock in a Parts Canada book that bolted right up and was a fraction of the cost.
    I snapped the second one off and luckily I had the "patch kit" in my tool kit for a quick repair...and that was the last petcock I bought...
  6. bEnt_bars
    Jan 23, 2006
    143
    Vancouver
    I may just do that as this first break sure didn't take me long to do or maybe I was just 'lucky' :dunno
  7. KTMax m AL
    May 31, 2006
    303
    I feel for ya dinging up your tank like that I bet it made ya just sick. :ddog
    I know it would have me if i'd done that to my tank. :cry Knock on wood.:komet
    :cromag
  8. Dorky
    Dorky n00b
    Aug 4, 2006
    3
    I would suggest to remove the petcock in your garage rather than on the trail.:nod
    #8
  9. bmwktmbill
    bmwktmbill Traveler
    Jul 16, 2005
    5,989
    Traveler
    Anybody found a source for petcocks that is cheaper than KTM, they want $50 a copy.
    b.
    #9
  10. Dorky
    Dorky n00b
    Aug 4, 2006
    3
    As noted above, throw it away and replace with a $1 aluminum plate.
    #10
  11. meat popsicle
    Feb 9, 2004
    14,643
